Thread: Which 20" LED monitor uses least power?
    Default Which 20" LED monitor uses least power?
    Which 20" LED monitor uses least power? Please suggest me a monitor!
    • ochin's Gadgets
      • MSI H61
      • intel core i3 2100 3.1ghz
      • 2gb ddr3 1333mhz
      • 500gb
      • sapphire 7850 OC
      • philips 224el2sb 21.5"
      • Thermaltake smart 550w
      • qubee
      • 124kpbs
    philips 224el2sb 21.5 led hd monitor.consumes 17w(active) 0w(display off)
    http://www.amazon.co.uk/Philips-224E.../dp/B00447C3QY
    Vanguard bhai I hope you won't mind, can anyone tell me the current price/model of 22-24'' monitors currently available, from Dell/Asus/Samsung?
    21.5 nibo na.
    ---------- Post added at 22:37 ---------- Previous post was at 22:36 ----------
    Samsung~16, LG~13, AOC~17, Acer~15
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    any ips panel 20" available???
    • Rorschach's Gadgets
      • MSI B85 GAming
      • Core i3 4130 3.2Ghz
      • Corsair vengeance 2*4gb = 8gb Ddr3 1600Mhz
      • 128Gb Crucial M4 SSD + 2TB Hitachi HDD + 2* 2TB Seagate HDD+2TB Seagate HDD+(4TB+3TB) Seagate HDD
      • EVGA GTX 980 SC ACX cooler
      • Sony Bravia W670A 32inch
      • Sound Blaster X fi Titanium
      • Panasonic HTF600 + Creative 4:1 Speaker
      • Ducky
      • V3
      • Xbox 360 Controller In PC via Receiver
      • TT Toughpower XT 675W 80+Bronze
      • Asus Dvd-RW ; NZXT Sentry 2
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • BUCT 2Mbps real ip
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    Asus ml229h --- 18k
    বাট রিমেমবার, জলিল নেভার ডাই, আর মরলেও ডাই এনাদার ডে।
    please someone provide me link of a good 20" LED
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    sigh!!! kew 20" choke dekhe na
      • ASROCK h81-GL
      • Core i3 4130 @3.40ghz
      • WD 1tb BLUE
      • Radeon r7 260x (2gb) GDDR5
      • Hp 18.5"
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    A place Where U Belong >:/
    hardware specifications for the E2008HDD-B are as follow:Model name ProLite E2008HDD-B
    Model number PLE2008HDD-B1
    LCD panel LCD Panel Type TN
    Drive system a-Si TFT active matrix
    Size Diagonal: 50.8cm (20 inches)
    Maximum display range Horizontal: 442.8mm Vertical: 249.1mm
    Pixel Pitch 0.2768mm
    View angle Each side of 80 º, 80 º upper and lower
    Response speed 2ms (G to G) ? 3,5 ms (black → white → black)
    Brightness 250 cd / M 2 (standard)
    Contrast ratio 1000:1 (typical) 30.000:1 (ACR 4 ? time function)
    Colors Millions of colors
    Scanning frequency analog Horizontal: 31 ~ 83kHz Vertical: 56 ~ 75Hz
    Digital scanning frequency Horizontal: 31 ~ 83kHz Vertical: 56 ~ 75Hz
    Visible resolution 1600 × 900 (maximum) 1.44MegaPixels
    Input Connector Analog 15-pin mini D-SUB
    Digital DVI-D24 pin connector (HDCP function with)
    Plug & Play VESA DDC2B support
  1. Help Me Buying LED Monitor 21.5"
    By Abdur Rafi in forum Help - PC Buying
    Last Post: January 23rd, 2012, 03:56
  2. Monitor: AOC i2353 23" IPS LED
    By Leaving BG in forum Others PC Hardware
    Last Post: December 28th, 2011, 00:53
  3. Samsung SyncMaster BX2250 21.5" LED monitor....is it available in BD ???
    By Codename-Scorpion in forum Help - General Shopping
    Last Post: January 4th, 2011, 22:13
  4. 20" LED monitor
    Last Post: November 23rd, 2010, 01:39
  5. HDD LED/Power LED on casing always on.is it bad?
    By knroeoueqisk in forum Others PC Hardware
    Last Post: March 19th, 2010, 08:53
Page generated in 0.19654 seconds with 14 queries.
