Results 1 to 20 of 20
Thread: Pc rebooting automaticaly.need help.
    • Nahid neywaz's Gadgets
      • DH55PJ
      • Core i 3 540 3.06ghz
      • ATI 5670
      • Crt 18 inch
      • on boaed
      • MICROLAB TMN3
      • A 4 tech usb
      • ps2 port dell mouse
      • USB DUAL SHOCK
      • generic psu 450 watt
      • BLUTOOTH
      • Windwos 7 64 bit
      • Kono-moto cole.
      • GP /QUBEE/ZOOM ULTRA
      • GP-20,QUBEE-64 KBPS
    Nahid neywaz's Avatar
    Aug 2011
    PABNA
    Default Pc rebooting automaticaly.need help.
    Amar pc bar bar reboot nisse.start e hosse na.ami pc start hober beep sunte pai thik tar porei pc reboot kore.jodio ba start hoi 5-10 min er moddhe abar reboot ney.need help urgent.
    Useing i3 540 , 4 gbram, 500gb hdd, ati 5450 oc in 450 watt generic psu.win 7
       0 Mobile
    Member Riese's Avatar
    Bogra, Bangladesh
    Quote Originally Posted by Nahid neywaz View Post
    Amar pc bar bar reboot nisse.start e hosse na.ami pc start hober beep sunte pai thik tar porei pc reboot kore.jodio ba start hoi 5-10 min er moddhe abar reboot ney.need help urgent.Useing i3 540 , 4 gbram, 500gb hdd, ati 5450 oc in 450 watt generic psu.win 7
    BSOD right? Naki direct reboot.
       1 Mobile
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Your ram or the graphics card is gone. thats why its restarting after beeping. But arekta karon hote pare loose connection. Try to remove the ram then re install it again.
       1
      • DH55PJ
      • ATI 5670
      • Crt 18 inch
      • on boaed
      • MICROLAB TMN3
      • A 4 tech usb
      • USB DUAL SHOCK
      • BLUTOOTH
      • Windwos 7 64 bit
      • Kono-moto cole.
    Aug 2011
    PABNA
    Quote Originally Posted by riese View Post
    bsod right? Naki direct reboot.
    no bsod.direct reboot.---------- Post added at 11:25 ---------- Previous post was at 11:22 ----------
    Quote Originally Posted by hrishat View Post
    your ram or the graphics card is gone. Thats why its restarting after beeping. But arekta karon hote pare loose connection. Try to remove the ram then re install it again.
    ok .doing as u say.-AFTER 1 HOUR GAMING ITS AGAIN REBOOT.IS IT PSU BRO OR TEMPERATURE PROBLEM.
       0 Mobile
      • Asrock Z370 Pro4
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Ram remove kore abar laganor por ki cholse 1 hour?
    Possible causes :
    1. Cpu Fan heatsink moyla & thermal paste dried causing overheating (had live experience) .
    2. Weak Ram
    3. PSU
       1
    Try a different stick of RAM, or remove additional modules and use the first DIMM slot. Clean the DIMM slots if possible, with a small cloth(no agents). Last but not least, try a new PSU or a different one to see if it boots properly. For temps, install Coretemp/HWMonitor/Realtemp, and see the log, if it crosses >80C, you need to reapply TIM properly/or heatsink.
       2
      • DH55PJ
      • ATI 5670
      • Crt 18 inch
      • on boaed
      • MICROLAB TMN3
      • A 4 tech usb
      • USB DUAL SHOCK
      • BLUTOOTH
      • Windwos 7 64 bit
      • Kono-moto cole.
    Aug 2011
    PABNA
    ram remove kore abar laganor por ki cholse 1 hour? Possible causes :1. Cpu fan heatsink moyla & thermal paste dried causing overheating (had live experience) .2. Weak ram3. Psu
    ram reinstall korar por 1 hour colse.ar cpu fan and thermal paster beparta cheak kore janas si.
    ---------- Post added at 15:31 ---------- Previous post was at 15:30 ----------
    try a different stick of ram, or remove additional modules and use the first dimm slot. Clean the dimm slots if possible, with a small cloth(no agents). Last but not least, try a new psu or a different one to see if it boots properly. For temps, install coretemp/hwmonitor/realtemp, and see the log, if it crosses >80c, you need to reapply tim properly/or heatsink.
    doing as u sayed.
       0 Mobile
    • SheikhItBaby's Gadgets
      • Gigabyte B75-D3H Rev 1.1 | Housed in (Chassis) : In Win Track
      • Corsair Vengeance 4GB DDR3 @1600mhz
      • OCZ Vertex 2 90GB SSD | Samsung Spinpoint 320GB 7200RPM
      • EVGA Geforce GTX 770 ACX SUPERCLOCKED
      • Samsung SyncMaster T240 24inch | 16:10 | WUXGA 1920x1200
      • Creative Labs Soundblaster X-FI XtremeGamer
      • Creative Inspire M4500 4.1 Speakers
      • Lexma LiFEKEY 8400 Keyboard
      • Lexma AM546 Laser Mice
      • Asus DVD-RW 24X
      • Windows 8.1 Professional | 64 bit
    SheikhItBaby's Avatar
    My PC used to hang after 1 hour of gaming.
    Then I over volted my RAMs to 2.1v.
    Worked like a charm, but first you need to root the problem out.
       0
    • Rajmi's Gadgets
      • MSI H61M-E33 [B3]
      • Corei5 2500k
      • GSkill Ripjaws 2x2 => 4gb
      • intel 3000
      • 19" LCD LG Flatron
      • Creative 2.1
      • A4tech slim
      • Delux T6 :: Dragon
      • Delta 550W
      • BTCL - ADSL
      • 64KBps
      • 15KBps
    Rajmi's Avatar
    amar ekbar heat sink loose kore lagaisilam, pore emon hoisilo...do make sure ur heat sink is fitted properly! and there is good air flow in the casing....
       0
    psu te jodi prob na thke tahole ram chang kore dakha jete pare
       0
    Mar 2012
    Mone hoi psu al pc parts(pro,mobo,hd) er pura load nite partese na.80% chance je psu change korle problem solve hobe.Ar ram tao check koren.Tobe eitar chance kom.Amar ekbar ram e problem hoisilo tokhon pc beep o korto na.
       1 Mobile
    Quote Originally Posted by The Prophet View Post
    Overvolted to 1.2v from 1.8v, DDR2 I presume? Don't do these on SB/Nehalem/AMD CPUs, you won't like the consequences. More likely you should have RMAed ram, it's clearly a sign that it's dying if it's at stock/if not OCing.
       1
      • Asus DVD-RW 24X
    Well C2D chalai, RAM jonmer thekei ei prob disilo, onek lazy ami, tai RMA niye lafalafi kori nai. Ekbar gesilam RMA korte kinto halara bole PC shuddho niye ashte karon oder PC te kono stressing soft ba game nay. Mejaj gesilo kharap hoye, tai oi dokane ar jai nai.
    And I overvolted it to 2.1v from 1.8/1.9
    The RAMs are DDR2.
       1
    The RAMs are DDR2.
    C2D dekhei kono problem kore nai, jodi oi CPU gula hoto god knows what would have happened to the IMC.
       0
      • Asus DVD-RW 24X
    What is the worst case scenario?
       0
    The worst case scenario the CPU will be damaged or won't properly after prolonged periods. The CPUs after C2D have their IMC integrated on the die itself, the more voltage you push, the greater load on the IMC and it's only designed to work within a certain range, and 2.1v is way too much even for Nehalem, but since that is DDR2 it's a different case.
       0
      • DH55PJ
      • ATI 5670
      • Crt 18 inch
      • on boaed
      • MICROLAB TMN3
      • A 4 tech usb
      • USB DUAL SHOCK
      • BLUTOOTH
      • Windwos 7 64 bit
      • Kono-moto cole.
    Aug 2011
    PABNA
    Possible causes :
    2. Weak Ram
    3. PSU
    apnar kothai thik. thermal paste sukai gese.tar jonno over heat hoie reboot kortesilo. thanx for help.
    ---------- Post added at 17:22 ---------- Previous post was at 17:19 ----------
    all of u thanx to every one. problem solved. it was the thermal paste problem.vaia ra bolen to yhread kivabe close korte hoi.again thanx for your help.
    I WILL SEND ALL OF YOU BACK TO THE HELL...FROM GOD OF WAR.
       1
    • Reznov's Gadgets
      • Gigabyte G31M-ES2C
      • Intel Core 2 Duo E8400
      • 3GB DDR2 800mhz (2GB+1GB)
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Adata UV150 (16 GB USB3)
      • windows 7 Ultimate 64bit
      • Mobile ISP
      • Vashae Prokasher Ojoggo
    Reznov's Avatar
    Dinajpur
    apnar kothai thik. thermal paste sukai gese.tar jonno over heat hoie reboot kortesilo. thanx for help.---------- Post added at 17:22 ---------- Previous post was at 17:19 ----------all of u thanx to every one. problem solved. it was the thermal paste problem.vaia ra bolen to yhread kivabe close korte hoi.again thanx for your help.
    cpu temp max koto esechilo check korsilen bro? Korle ek2 janan temp koto porjonto geslo.
       0 Mobile
      • Asrock Z370 Pro4
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Good to hear that. keep it safe.
       0
    Glad to know it's solved. Closing it then, if you want it re-opened, just PM me.
       0
Page generated in 0.29179 seconds with 13 queries.
