Thread: Microcontroller programing using top 2005+
    Default Microcontroller programing using top 2005+
    hy, i need some help in a microcontroller programing. i have recently brought a top 2005+ universal progamer and programed a pic 16F877a to blink a LED (after 1 sec pulseting).the code is :
    void main()
    PORTD=0;
    TRISD=0;
    while(1)
    PORTD= ~PORTD;
    Delay_ms(1000);
    so there is no wrong in the code. i m facing problem with the loader maybe. do you have any idea how use top 2005+. the product is chinise.and i m using topwin 5.02 to load program.(only fo xp,couldn't find for win 7) please some help to understand how use topwin (specialy the process and configuration setting).
    u should try microcontroller programming forums by searching in google. i have some experience using an ATMega8 microcontroller and i've found searching around the forums very useful.
    i wish i could help with the loader, but the loaders i used were home-made and required no 'configuration'.
    i don't know much about pic microcontroller programming, but i think u should initiate the port D for output first, then output a value to the port.
    Its AIM. Not GG AIM, GG_AIM or GG.
    Hi there; old thread I know.
    But just wanted to mention, that TopWin6 can be downloaded here: http://www.topwin6.com/
    It runs on Win7.
    If you're into burning EPROMs, you can also check out my little project u2Pa: http://code.google.com/p/u2pa/
    Blogpost about the project here: http://elgensrepairs.blogspot.dk/201...universal.html
    Have fun };-P
  1. Top rpg!!!
    By sadi_warhead in forum RPG
    Last Post: December 2nd, 2012, 23:23
  2. [Help] Nokia C3-00 Microcontroller/Microprocessor information
    By Ricka in forum Miscellaneous Topics
    Last Post: August 9th, 2011, 01:40
  3. Replies: 3
    Last Post: June 30th, 2011, 22:16
  4. Top Scorers
    By abir in forum Real Life Soccer
    Last Post: June 2nd, 2009, 22:35
  5. Closed want to sell a 2005 pc! without monitor,speakers and soundcard
    By Mohaan in forum Shop - Gadgets
    Last Post: March 9th, 2009, 22:17
Page generated in 0.15823 seconds with 14 queries.
