Results 1 to 20 of 20
Thread: Help me to build my pc
    Question Help me to build my pc
    My Old pc is not working anymore , So i am in need of buying a new pc
    I am not a hardcore gamer, but i play rts type of games & do some cpu intensive work
    I am in tight budget thus i will be using Some parts from the old pc . and will upgrade them later.
    Note that though i am in tight budget i am looking for some good build
    So here's is my current selection of new parts that i will buy .
    MainBoard: not sure but looking for some z68 based board . (~12k)
    Processor: intel core i3 2100 . enough for my need i guess and these is the minimum i can get in sandybridge architecture, right ?) (~10k)
    Chassis: Thermal take V3 black edition with psu . i like these but maybe there are some better alternative (~5k)
    Ram: G, skill DDR3 1330 (2x2GB) not sure about the price & availability
    My budget is around 30k . and i will keep using the old gpu (Radeon HD 4650) and the Harddisk .
    I was thinking about switching to ivy bridge if possible and get a better cpu maybe core i7 in the next year.
    well these are my thoughts but you are welcome to change it
    and please if you know the current price of any product that i have mentioned above let me know .
    srry for little offtopic.. but apnar cpu budget(10.5k) e 1st hand 2100 pawa jay!
    r mobo budget e 1st hand z68 pawa jay (asrock). tobe ota obosso asus/msi na
    i am looking for new parts not second hand .
    ohh srry... i3 should be in 10.5-11k
    asrock z68 12-12.5k
    ddr3 2x2gb 2.2k 4gb 2k
    any suggestion for casing ? and for mb , asrock z68 or Gigabyte Z68MA which one will be better? is it possible to get G skill's ram ?
    • shafi's Gadgets
      • Gigabyte Z170 gaming 7, apple macbook pro late 2013 retina/ apple ipad air/iPad pro 9.7 iPhone 7+
      • CORE i7 6700K WITH coolermaster hyper 212 evo/intel haswell i7 2.3 ghz
      • GSkill RipJaws v 3000 32gb ddr4/16 gb ddr3 1600 mhz on mac
      • Samsung 850 evo 250gb+1tb+wd ezex 1tb, trancend 35t3 3 tb, Wd black 5tb, 950 pro, muskin 1tb
      • gigabyte gtx 1080 xtreme sli/ intel iris pro+ nvidia gt 750m 2gb gddr5
      • samsung ku 6290 4k uhd tv, Dell S2716DG
      • Sound blaster zx
      • Akg k7xx,Samson sr 850, audio technica ath m50x, ,dt 990 pro, hd 598
      • corsair vengeance k95 rgb
      • logitech g500s, g700s,g502,g402, deathadder chorma on razer goliathus speed edition
      • ps4, xbox one controller
      • corsair rm i 1000w
      • 32 gb trancend, 64gb sandisk, 16gb kingston
      • Windows 10 education, mac osx maverick 10.9.1
      • wei- cpu and ram-7.6 on stock, gfx-7.9
      • thanks a lot to omnipotent creator(as a muslim allah) for my awesome rig, xbox one and ps4
      • Teksavvy 150mbps unlimited
      • 18.8MB/s
      • Don't upload
    shafi's Avatar
    Vancouver
    whats the need of z68 board if ur using a non overclockable core i3 2100k?
    ---------- Post added at 01:14 ---------- Previous post was at 01:07 ----------
    and what abt gfx card?
    • Reznov's Gadgets
      • Gigabyte G31M-ES2C
      • Intel Core 2 Duo E8400
      • 3GB DDR2 800mhz (2GB+1GB)
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Adata UV150 (16 GB USB3)
      • windows 7 Ultimate 64bit
      • Mobile ISP
      • Vashae Prokasher Ojoggo
    Reznov's Avatar
    Dinajpur
    Quote Originally Posted by shafi View Post
    whats the need of z68 board if ur using a non overclockable core i3 2100k?---------- Post added at 01:14 ---------- Previous post was at 01:07 ----------and what abt gfx card?
    He has a plan to change his cpu later. So he is planned out for a z68. And for the gpu, he wishes to keep his current one. Dont you see that these infos are written in the first post?
    • shafi's Gadgets
      • Sound blaster zx
      • 18.8MB/s
      • Don't upload
    shafi's Avatar
    Vancouver
    sorry my bad
    • Ork7O's Gadgets
      • Gigabyte b75-D3H, rev-1.0
      • Asus Xonar DGX
      • HP dvd1270 24x DVD Writer
      • Luminous 1000VA
      • Windows 8 Enterprise, x64
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    An Ivy cpu on a Sandy mobo huh!!! Cool.... AFAIK all the z68s won't support Ivy Bridge....... So be extra careful on that issue.... ..... But I would suggest go buy a h61 with the 2100 and heck.............. Sell those and buy a new pair when u feel like it..... ......
    if i were you i would get i5 2320/2400 with simple h61 mobo... 1year later when upgrading i would have bought new mobo+cpu
    Quote Originally Posted by rk7 View Post
    Who said that? Z68 is the only chipset which is more viable of supporting Ivy Bridge, with newer UEFI/BIOS from their respective manufacturers. There are already Z68s available on the market which support Ivy Bridge "out of the box", and more and more are getting updated.
    Try to buy a Gen3 board, that way once you have Ivy Bridge in the markets, you can pop one in on the Z68 boards, and have PCIe 3.0.
    • Ork7O's Gadgets
      • Asus Xonar DGX
      • Luminous 1000VA
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    Bro u dint get my point. I never said z68 wont support Ivy Bridge, Its just some specific models (U see by z68s i meant those models......) which mayb wont support IV.
    Anyway here are the links where I stumbled upon:
    http://forums.tweaktown.com/asrock/4...herboards.html &
    http://www.fudzilla.com/processors/i...th-socket-1155
    ok i will go for asrock z68 extreme 3 gen 3 and core i3 2100 . does any one know the current price of thermaltake v3 casing ? who sells them, and best place to get the cpu and mb.
    thanks to everyone for their suggestion .
    • pre's Gadgets
      • Gigabyte H61-DS2
      • Intel Corei5 2320 3.0Ghz
      • Twinmos DDR3 4gb 1333bus
      • Samsung 500gb sata
      • ATI Radeon 6670 GDDR5 1GB
      • Dell s1909w 18.5inch LCD
      • Realtek HD
      • Delux 2:1
      • A4TECH . 2.4G wireless keyboard (GR-152)
      • A4TECH 2.4G wireless PADLESS MOUSE (G9-730FX )
      • Logic
      • ValueTop [Blue] 400w
      • ASUS 24x Sata DVD Writter
      • Ipod Classic 2GB,4gb Siliconpwer Pendrive
      • Windows 7 Ultimate 64bit
      • CPU : 7.4 RAM : 7.4 GAMING GRAPHICS : 7.1 GRAPHICS 7.1 HDD : 5.9
      • I LoVe My RiG nd It Will Be More Updated Soon ;)
      • Banglalion Wimax 1mbps Pre-paid
      • 120 kbps
      • 20 kbps
    pre's Avatar
    Jan 2012
    tt v3 is 3700tk @ucc
    Quote Originally Posted by pre View Post
    including the psu ?
    • pre's Gadgets
      • Gigabyte H61-DS2
      • Realtek HD
      • Delux 2:1
      • Logic
      • 120 kbps
      • 20 kbps
    pre's Avatar
    Jan 2012
    no without psu .. Branded case doesnt c0mes with psu excpt the chnese ones
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    Quote Originally Posted by bioshock View Post
    you will not get that in bd...
    • pre's Gadgets
      • Gigabyte H61-DS2
      • Realtek HD
      • Delux 2:1
      • Logic
      • 120 kbps
      • 20 kbps
    pre's Avatar
    Jan 2012
    450wt + v3 = 9k (approx) in bd..
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    you will get this >>>http://www.ucc-bd.com/thermaltake-v3...-win-secc.html <<a different model
  1. Help Me Build My First Gaming PC =)
    By Profolic in forum Help - PC Buying
    Last Post: June 11th, 2011, 11:37
  2. BDGamers Help Me Build A New Rig
    By Evil Ryu in forum Technical Support
    Last Post: November 7th, 2010, 09:02
  3. Help me to build a new rig, please. :)
    By Nahid in forum Technical Support
    Last Post: October 7th, 2009, 20:33
  4. Need help with i7 build
    By Dissent in forum CPU
    Last Post: August 27th, 2009, 21:06
  5. i need IDM 5.15 Build 6
    By CHR.Satiator in forum Software
    Last Post: February 25th, 2009, 03:56
Page generated in 0.29534 seconds with 14 queries.
