Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 53
Thread: Mouse stutters, need Help.
    Default Mouse stutters, need Help.
    Okay, so after testing with frame rates and refresh rates, I've figured out that the Camera movement in any game is very smooth with gamepad [Xbox 360 Controller] but moving camera with mouse looks stuttery mess if I don't set FPS to 30 or 60. This happens with both Mouse acceleration on/off.
    So, I've been recently using 53 Hz+ Vsync to lock games to 53 FPS and play without stutters. Games like Assasin's Creed Unity, Resident Evil 6 are working just fine. But most of the games like ROTR, Witcher 3, Quantam Break, Watch Dogs 2, etc feels super stuttery and unsmooth with mouse. This has been bugging me a lot.
    I don't know if it's my mouse or this is how some games are designed.
    @aayman you have Gsync monitor, right? Do you have any of the games I mentioned? Can you lock your frame rate to 53 FPS/ 54 FPS/ 50 FPS and make sure your G-sync monitor sets at 50/53/54 Hz aswell. Do you get the same stutters too? Compare it with gamepad and see if the mouse feels unsmooth.
    First use gamepad to move camera at 53 FPS and then use Mouse and if it feels unsmooth, then I'll know its an mouse issue with all games.
    I will highly appreciate it if you can test it for me.
    I am not planning to use gamepad, and if it turns out that its an issue with all the mouse, then there's no point in buying G-sync for me.
    Also if it turns out be an issue with my mouse, could you tell me what mouse you're using? I will have to buy that.
      • Asrock Z370 Extreme4
      • Intel 8700K @5.0ghz w/ Cryorig R1
      • 2x8GB Trident Z 3600Mhz @3200CL14
      • Phillips x2 HR
      • Zowie Celeritas II
      • Razer Viper Ultimate
      • Xbox One
      • Corsair AX860
      • Windows 10 1909
      • AalokIT
    No I don't have any of those games.
    You can try overclocking your mouse to 500hz or 1000hz and see if that helps.
    Can you name some of the games you got?
    Do you have Metal Gear Solid V, Arkham Knight, Resident Evil 7?
    Thanks about the info by the way. I'll try to overclock my mouse and see what results I get. According to my mouse's specs, it's 1000Hz already. I will try to to lower it down to 500Hz and see what happens.
    Edit: Ok, so my mouse is already on 1000Hz.
    I kinda getting the feeling that this is problem with all mouse. Sucks then cause I hate gamepad.
    • Sybaris Caesar's Gadgets
      • MSI Arsenal Gaming B450 Tomahawk
      • AMD Ryzen 5 3600
      • Team T-Force Delta RGB 2x8GB 3200CL16
      • WD Black WD1003FZEX 1TB + Crucial MX500 500GB
      • Colorful GeForce RTX 2060 6G V2
      • LG 22MP68VQ-P 22" 75hz IPS
      • Onboard Realtek ALC892
      • HyperX Cloud X | iVOOMi iVO-169SUFBT 2.1
      • Fantech MK871 RGB TKL Outemu Blue mechanical keyboard
      • Logitech G402 | Logitech G102
      • Xbox 360 Wireless
      • Cooler Master G550M
      • Windows 10 Enterprise x64 1903
    Sybaris Caesar's Avatar
    Nowy Warsaw
    mouse ta ki?
    nvm. Get the Logitech G102 @ 2.5k. I've been eyeing that mouse for weeks. goyta sell my G402 somehow tho.
    Quote Originally Posted by Sybaris Caesar View Post
    mouse ta ki?
    Will probably have to buy a gaming mouse.
    I prefer claw grip. I got two mouse by the way, two shitty mouse. The other one is connected just for the sake of being connected but I dont use it.
    The one I use is Logitech M105.
    The other one is A4Tech OP-620D
    I need halp. I like the mouse I currently use because its so easy to grip it like a claw. But if its the cause of stutters, then I will get a new one.
    But first, I need the evidence of others. That's why I asked aayman if he played the games I am having issues with.
    So, BattleField 1 also suffers from the mouse stutter at 53 Fps, which gets reduced to some extent by using Raw input. But its still there and gamepad just feels smooth at 53 FPS.
    What's the refresh rate of your monitor dude? Can you downclock to 53/54 Hz and see if you are getting the stuttery mouse movement in those games?
      • AMD Ryzen 5 3600
      • Xbox 360 Wireless
    Nowy Warsaw
    Quote Originally Posted by Sami 1999 View Post
    Use smaller mouse. G102 is a small mouse. Perfect for claw grip. Although Deathadders are quite popular, they're more palm grip mouse.
    I think you're facing input lag? It's the reason people play at highest available FPS specially true for online gaming. But alas, for some reason you think 36 fps is smooth.
    Gamepads don't face this cause their travel speed is fixed unlike mouse.
    Here's a good article to read about it : https://displaylag.com/reduce-input-...initive-guide/
      • Phillips x2 HR
      • Xbox One
      • Corsair AX860
      • Windows 10 1909
      • AalokIT
    I have BF1 and I don't get stutters, but I never played it at 53fps. If I remember, I'll try this later tonight.
    If you have several mice connected, then disconnect all but one. Some motherboards have issues with multiple high polling rate devices, including the keyboard.
      • AMD Ryzen 5 3600
      • Xbox 360 Wireless
    Nowy Warsaw
    So wait, you're actively locking the games' framerates? SMH
    How is stutter related to input lag by any means? Please explain.
    I've clearly mentioned that the camera movement is smooth but when I move camera using mouse, the camera movement feels stuttery.
    So you haven't understood the thread at all. I'm sorry, but you won't be able to help me with this issue because you don't even understand what the problem is.
    Atleast aayman understood. Too bad he doesn't have the games I have, but he gave some useful suggestions.
    Ofcourse I shall lock FPS to 52 Edit: I meant 53 with Vsync at 53Hz if I get only 55-58 FPS. I've explained this before. But then again, I doubt you people even understood. So nopoint in explaining further. But I know that this is a severe issue before I make jump to Gsync. Don't wanna waste money only to find out G-sync wont help mouse users.
    Thanks.
    I'll disconnect the other mouse and see how well it goes now.
    Okay, so I have removed the other mouse.
    No improvements so far.
    I give up. Looks like this issue can't be fixed. So these game's aren't optimized for the mouse. In Resident Evil 6 there is no stutter at all with 53Hz.
    Edit: Surprisingly among the games I'm having these issues, Batman Arkham Knight shows the least amount of mouse stutters, kinda feels like it's the most optimized one among other graphics heavy games.
      • AMD Ryzen 5 3600
      • Xbox 360 Wireless
    Nowy Warsaw
    Upload a 20-30s video on YouTube and then post it here. Imma watch it. Frankly I don't believe a word you say anymore.
    Don't believe. I don't need your help. You can't help me. Your monitor doesn't even do 53Hz or you didn't even bother to test it.
    Only other person that can do 53Hz is aayman since he has Gsync monitor. So yeah, don't bother helping me.
    If you're wondering why I am not uploading video, its because Shadowplay records at 30 FPS/ 60 FPS. So when I record my games at 53Hz @ 53 FPS, the captured footage still records at 60 or 59 FPS and then the whole video stutters. Thus making it useless.
      • ASUS P8Z77-V Pro
      • Core i5 3570 @4.0 GHz
      • G.Skill ARES 2400 MHz 8GBx2
      • SAMSUNG 850 PRO 256GB
      • AMD RX 570 4GB 1300/1750 1.03v
      • HP Compaq LA26306x 23"
      • Realtek ALC898
      • GAMDIAS Hephaestus P1
      • Cougar Minos X2
      • Skylark
      • 5 Mbps
      • 5 Mbps
    I can do 50 Hz.
    I can do 50 Hz.
    I need help.
    Do you have those games where I'm having these problems?
      • ASUS P8Z77-V Pro
      • Realtek ALC898
      • Cougar Minos X2
      • Skylark
      • 5 Mbps
      • 5 Mbps
    Apart from Watch_Dogs 2, I have the rest. But I don't have enough free space on my HDD to install all of them at the same time, I can test them one by one. RE6 is the only RE game I haven't touched from the franchise, so I guess that makes it worth installing.
    I don't have problems in Resident Evil 6. Didn't you read the first post?
      • Phillips x2 HR
      • Xbox One
      • Corsair AX860
      • Windows 10 1909
      • AalokIT
    I once faced the reverse of this situation, where my controller caused stutters and mouse was fine. Changed batteries and everything was fine. I'm guessing you've tried changing USB ports by now?
    Yeah, I tried. Didn't helped unfortunately.
      • Phillips x2 HR
      • Xbox One
      • Corsair AX860
      • Windows 10 1909
      • AalokIT
    http://www.resplendence.com/latencymon
    Try that and see if your latency is normal during idle.
    Okay, I'm testing it now and I'll let you know what happens.
    @aayman
    Edit: I tried mouse with different USB ports, disconnected Gamrpad but no luck so far. Only thing left to test is a PS/2 mouse.
      • Phillips x2 HR
      • Xbox One
      • Corsair AX860
      • Windows 10 1909
      • AalokIT
    Latency looks perfect. I'm running out of ideas. How about power plan in High Performance mode? If it's W10, that should disable a Core Parking.
Page generated in 0.24770 seconds with 14 queries.
