Thread: Having trouble with installing screws for chassis fan
    Default Having trouble with installing screws for chassis fan
    I recently had to change my PC chassis and I bought a new 120mm fan for the new one as it has only one outtake fan in the rear side. Everything is going just fine but I’ve just noticed that the technician installed only 2 screws for the new fan and it seems he used the screws that came with the case. Since I got all the screws that came with the chassis so I tried installing the missing two myself and found they get stuck in the screw hole after few spins and don’t go in anymore. I am afraid that the fan probably came with its own screws and unfortunately I don’t have them. Is there anyway to solve this problem?
      • Asrock Z370 Extreme4
      • Intel 8700K @5.0ghz w/ Cryorig R1
      • 2x8GB Trident Z 3600Mhz @3200CL14
      • Phillips x2 HR
      • Zowie Celeritas II
      • Razer Viper Ultimate
      • Xbox One
      • Corsair AX860
      • Windows 10 1909
      • AalokIT
    The screws that came with my fans don't screw in all the way into the fan either.
    my phantom 240 .... the long screws have problems.... i might have to buy some long screws from newegg or just ignore it.
    aayman The 2 installed screws seem to be fitted perfectly fine but when I try to install the other two screws, they won't go all the way in the hole and they just look like they weren't meant to be installed in that place.
    furiousTaher I guess I might have to just ignore it.
    Off-topic: Do you have any idea where can I buy USB dust covers in Bangladesh? I know it is silly but it would be cool to have it.
    what is usb dust cover?????
    and i think there is no dust filter in BD. vanguard imported some dust filter for himself and some other friends several years back.
    @furiousTaher The front panel USB ports of the chassis collect quite a bit of dust (unless the chassis has some sort of door/panel to cover them) so I googled a bit and found they actually make female USB cap/cover to protect USB ports from dust, I was wondering if this is available in BD.
    • Sybaris Caesar's Gadgets
      • MSI Arsenal Gaming B450 Tomahawk
      • AMD Ryzen 5 3600
      • Team T-Force Delta RGB 2x8GB 3200CL16
      • WD Black WD1003FZEX 1TB + Crucial MX500 500GB
      • Colorful GeForce RTX 2060 6G V2
      • LG 22MP68VQ-P 22" 75hz IPS
      • Onboard Realtek ALC892
      • HyperX Cloud X | iVOOMi iVO-169SUFBT 2.1
      • Fantech MK871 RGB TKL Outemu Blue mechanical keyboard
      • Logitech G402 | Logitech G102
      • Xbox 360 Wireless
      • Cooler Master G550M
      • Windows 10 Enterprise x64 1903
    Sybaris Caesar's Avatar
    Nowy Warsaw
    plug in a pendrive all the time, simple.
    Quote Originally Posted by Sybaris Caesar View Post
    Protidin USB port er kache ektu zore fuuu dilei to dhula balu shore zai. Eto kosto kore pen drive othoba capdom use korar dorkar ki?
    • Dracu_JeF's Gadgets
      • Gigabyte B360 D2V
      • Core i5 8400
      • 8GB
      • 1TB SATA
      • Gigabyte GTX 1050ti
      • LG 22MP68VQ-P
      • You cant get cheaper than this (probably) ~
      • Dhakacom
      • 260
      • 200
      • 136
    Dracu_JeF's Avatar
    Quote Originally Posted by Sami 1999 View Post
Page generated in 0.19913 seconds with 14 queries.
