Results 1 to 2 of 2
Thread: Monitor Buying Help!
    Exclamation Monitor Buying Help!
    Currently im using Samsung P2250, 22" LCD monitor with mere 50,000:1 contrast ratio in 1920x1080 at 2ms response time. But im not satisfied with it. Because while playing Skyrim, in menu when the smoke comes, the part of the smoke looks seperate, wavey type. Im not sure whether it occurs in the LEDs too. Need to know it. And i aim for a 20" eqaul or plus monitor. Or should i buy a 20" LED with 1600x900 res? Would it look bad cause im switching from a higher res? Or should i just stick with my one. My budget is ~15k.
    *bump
  1. Monitor Buying help
    By roushonul in forum Help - PC Buying
    Last Post: February 26th, 2012, 23:17
  2. Need Help Buying Monitor
    By hemal77 in forum Help - PC Buying
    Last Post: February 3rd, 2012, 21:00
  3. Buying monitor help
    By Artion33 in forum Help - PC Buying
    Last Post: September 18th, 2011, 14:56
  4. Buying Monitor
    By gamefreak in forum Help - PC Buying
    Last Post: September 10th, 2011, 14:59
  5. Monitor buying help
    By Aziz37 in forum Help - PC Buying
    Last Post: June 16th, 2011, 14:23
Page generated in 0.16206 seconds with 14 queries.
