Results 1 to 8 of 8
Thread: Overheating problem.
    Thakurgaon
    Default Overheating problem.
    My gpu and mobo has gone mad.When I play games like bf3 or crysis 2 or any 3d game my gpu temp goes to 110c and mobo temp to 88~90c and game stucks. After some time when the temp is down then the games run fine.I have opened the side panel of my casing and tried to lessen the heat with a table fan but it doesn't work.Why my mobo and gpu getting this hot?
    • king_showrav416's Gadgets
      • Gigabyte H55M-S2V
      • Intel Core i3-530 @3.3GHz
      • TwinMOS Twister @1600Mhz 4GB with Heat Sink
      • SAMSUNG HD502HJ 500GB
      • MSI R6850 Cyclone PE/OC
      • SAMSUNG 20" LED SA300
      • Realtek HD audio Built in
      • Creative inspire 2:1|| A4tech HS-28
      • Logitech Y-SZ49
      • A4TECH K4-28D
      • ThermalTake Tr2 380w 80+ Bronze
      • Samsung DVDRW SH-S223c
      • Team 4GB Pen drive
      • Windows 7 Ultimate SP1 64bit
      • HaPPY :)
      • BTCL 512kbps
      • ~64
      • 28
    king_showrav416's Avatar
    Oct 2011
    Quote Originally Posted by Zamil View Post
    gfx card, case, mobo konta?????
    • Dee's Gadgets
      • Asus Maximus VIII Ranger
      • Intel Core i5 6600k
      • Dell S2216H
      • Cooler Master V650 Gold
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Have you ever disassembled the card?
    Thakurgaon
    Ami kheal korlam game na kheleo mobo 80c e thake.Amar mobo er jonnoi mone hoy gpu heat hoche.Mobo er temp nia ki korbo? Ar amar mobo intel dg41rq ar gpu 9500gt.
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    which soft do you use to measure mobo temperature? better post a screenshot, that may clear the matter. whats your psu and how long have you been facing this overheating issue?
    Thakurgaon
    Quote Originally Posted by @nonymous View Post
    Speccy dia temp dekhi.BIOS eo eki temp dekhae.Age gpu 104c porjonto jeto akhon severe issue hoe gese.Ami normal 400w er psu use kori.
      • A4Tech KRS-86
      • Antec VP450P
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    anything beyond 100c was never safe. and for entry level cards like 9500gt afaik it should be around ~60c. that means something was faulty from before....
    are the fans working properly? did you ever open or clean the heatseank ? disconnect the card & boot your pc using IGP and then check mobo temperature. try a different psu if you can...
    Thakurgaon
    anything beyond 100c was never safe. and for entry level cards like 9500gt afaik it should be around ~60c. that means something was faulty from before....are the fans working properly? did you ever open or clean the heatseank ? disconnect the card & boot your pc using IGP and then check mobo temperature. try a different psu if you can...
    All the fans are working.I have also used to charger fan to lower the temp.Guess I have to take my cpu to a pc repair shop? But thanks for helping.
  1. Nvidia Driver Problem or Graphics Card Problem ??
  2. Having Problem
    By all_izz_well in forum BTCL
    Last Post: March 24th, 2011, 03:36
  3. IP looking Up Problem
    By rakibmukitur in forum Garena Central
    Last Post: October 8th, 2010, 20:29
  4. help MSI N9800GX2 overheating problem
    By Cyber_Shot in forum GPU
    Last Post: August 21st, 2010, 05:50
  5. dl problem in RS
Page generated in 0.19832 seconds with 14 queries.
