Results 1 to 6 of 6
Thread: Using the PS3 controller (and/or others) on the PC for games as well as general purpose (USB cable needed)
    Lightbulb Using the PS3 controller (and/or others) on the PC for games as well as general purpose (USB cable needed)
    Hey guys,
    I made an accidental discovery while scouring the web for using my 360 controller on the PC; a way to use the PS3 controller instead as both peripheral and gaming device.
    Download and install the software from this site:
    http://www.motioninjoy.com/
    Installation guide in full: http://www.motioninjoy.com/wiki/en/install/latest
    During the installation, be sure to have your controller connected to the PC; you'll have to provide permissions while it performs driver installations for the controller.
    BTW, the application by default requires internet access. To enable the local interface, download the local UI pack at http://www.hardcoreware.net/how-to-p...ndows-7-vista/ (includes guide for 64-bit installation).
    Hope it's useful, and let me know how you've used your controller on the PC.
    Cheers
    • Franklin's Gadgets
      • Gigabyte z97P D3
      • NIA Wireless Headset
      • A4 tech
      • DS4 Wireless Controller
      • Cooler Master v750W
      • Asus DVD RW 24x
      • Transcend Jetflash v70 8 GB
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    It's nothing new. We're already aware of this software. FYI, I've used two PS3 controllers at the same time using that software for playing BLUR.
    rrolf.... try using pc controllers on ur ps3,i think i should buy a xbox 360 model controller for pc and use on ps3(wonder if it'll work)
    Quote Originally Posted by Kevepeter View Post
    I thought so too; still, a repost can't hurt. BTW, I found the thread that mentioned the software:
    http://banglagamer.com/showthread.php?8544-can-t-connect-ps3-controller-on-my-pc....-(
    The easy method is found here: [out of date on version of motioninjoy]
    http://www.gamefront.com/how-to-use-...oller-on-a-pc/
    • fishd990's Gadgets
      • Intel DH55HC
      • 2 GB DDR3
      • Samsung HD322HJ (320 GB) & Transcend Storejet (TM)25 Mobile (160 GB External)
      • Sapphire HD 5770 1 GB DDR 5
      • Samsung Syncmaster 2243BWX (22")
      • ATI High Defination Audio Bus
      • Microlab 2:1
      • Logitech K400
      • Logitech K400
      • XBox 360 Controller for PC (Chinese)
      • Thermaltake TR2- 500 W
      • Bluetooth, Printer (HP Laserjet 1010), Scanner (HP Scanjet 4370)
      • 800 VA (Gives upto 15 Min to my PC)
      • Windows 7 Ultimate
      • BTCL Broadband 256 Kbps
      • 60 (Avarage)
      • 30 (Avarage)
    fishd990's Avatar
    You can even use PS3 controllers in wireless mode for PC,
    But you will need Bluetooth for that,
    http://www.davieslim.com/ps3/use-ps3...ess-bluetooth/
    This one's a bit complicated though and I never tired it so I can't say whether it actually works.
    try to play pc mmos like wow,and stuff with joypad hehe.. i did that with a program i found from a forum for that game but runs on all..(basicly turns ur whole controls into ps33 type with mouse in analogue and sutff)
  1. Replies: 13
    Last Post: May 19th, 2012, 13:26
  2. PSP Slim USB Cable
    By TRazerK in forum PSP/PS Vita
    Last Post: January 27th, 2012, 21:16
  3. PS3 Games into Internal Drive through USB
    By йЦммєя³¹ in forum PlayStation
    Last Post: October 8th, 2011, 04:14
  4. Closed Xbox 360 usb controller for windows
    By O_o in forum Shop - Gadgets
    Last Post: September 18th, 2009, 01:32
  5. Replies: 2
    Last Post: May 22nd, 2009, 23:52
Page generated in 0.17782 seconds with 14 queries.
