Results 1 to 20 of 34
Thread: CRT monitor problem
    • Cpt.Mactavish's Gadgets
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Cpu:5.4,Gpu:7.1,HDD:5.9
      • Happy with it!
    Cpt.Mactavish's Avatar
    Default CRT monitor problem
    Bros,i've got another faltu problem.i've samsung 17" inch monitor.it's native res was 1024x768.u know.kisu din age,mathay kan jani ekta vut chaplo je res 1280x1024 korlam.then monitor r charpashe black bar ashsilo.monitor r r8 side r button gula diye tene tune black bar remove korlam(jara crt use koren tara to valomotoi janen).shob ektu choto choto lagtesilo.then ajke abar 1024x768 e back korlam.then black bars came.again button tipe tupe scale korlam.kintu dekhi shob kisui ektu boro boro.normally monitor r res 800x600 dile jemon boro boro lage thik temon.now how can i fix it.how can i get back the display like before?help!pls.respond quickly.
    • pre's Gadgets
      • Gigabyte H61-DS2
      • Intel Corei5 2320 3.0Ghz
      • Twinmos DDR3 4gb 1333bus
      • Samsung 500gb sata
      • ATI Radeon 6670 GDDR5 1GB
      • Dell s1909w 18.5inch LCD
      • Realtek HD
      • Delux 2:1
      • A4TECH . 2.4G wireless keyboard (GR-152)
      • A4TECH 2.4G wireless PADLESS MOUSE (G9-730FX )
      • Logic
      • ValueTop [Blue] 400w
      • ASUS 24x Sata DVD Writter
      • Ipod Classic 2GB,4gb Siliconpwer Pendrive
      • Windows 7 Ultimate 64bit
      • CPU : 7.4 RAM : 7.4 GAMING GRAPHICS : 7.1 GRAPHICS 7.1 HDD : 5.9
      • I LoVe My RiG nd It Will Be More Updated Soon ;)
      • Banglalion Wimax 1mbps Pre-paid
      • 120 kbps
      • 20 kbps
    pre's Avatar
    Jan 2012
    i thnk apne atodin 1280x1024 e use kre kre ovvosto hoe gesen,tai resltn komay deoate boro boro lagtese..use krte thaken kisudn por atae n0rmal m0ne hbe
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    Quote Originally Posted by pre View Post
    are na vai,just 2 din 1280x1024 use korsilam.jokhon ei 1024x768 prblm holo tokhon arekjoner 17"crt dekhe ashlam.asholei boro!
    • pre's Gadgets
      • Gigabyte H61-DS2
      • Realtek HD
      • Delux 2:1
      • Logic
      • 120 kbps
      • 20 kbps
    pre's Avatar
    Jan 2012
    monitor er sob settngs default + gpu drvr reinstall die dakhen..
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    monitor setting default dibo kivabe?
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    17' crt er highest res may be 1280. u should use this resolution. ar visual problem hole oita maybe tomar GPU driver er karone(if ati), monitor er o problem hote pare. try to give us some screenshots.
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    Quote Originally Posted by hrishat View Post
    ha amd r 6670ddr5.ok screenshot dibo
    • pre's Gadgets
      • Gigabyte H61-DS2
      • Realtek HD
      • Delux 2:1
      • Logic
      • 120 kbps
      • 20 kbps
    pre's Avatar
    Jan 2012
    monitor er menu button e pres kre khuje ber krte hbe .. Default setngs
    Thakurgaon
    Eita monitorer shomosha.Amar crt monitor tao eki shomosha dey.1024x768 te monitorer side e black bar asto.Setting e thik korle 1280x1024 e black bar ashe.1280x1024 e thik korle 1024x768 te black bar ashe.
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    • Reznov's Gadgets
      • Gigabyte G31M-ES2C
      • Intel Core 2 Duo E8400
      • 3GB DDR2 800mhz (2GB+1GB)
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Adata UV150 (16 GB USB3)
      • windows 7 Ultimate 64bit
      • Mobile ISP
      • Vashae Prokasher Ojoggo
    Reznov's Avatar
    Dinajpur
    bro screen refresh rate ta ektu check kore koto ase dekho. Try to set the highest value.
    ---------- Post added at 12:48 ---------- Previous post was at 12:44 ----------
    hrishat bro, 1280 dia amr 17"crt er refresh rate maxm 60 te set kora jae. Ami ki ai res ai chalabo?
    • pre's Gadgets
      • Gigabyte H61-DS2
      • Realtek HD
      • Delux 2:1
      • Logic
      • 120 kbps
      • 20 kbps
    pre's Avatar
    Jan 2012
    i thnk 1280 tmr native..so u better keep the res @1280
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    nope,1024 was my native.
    • pre's Gadgets
      • Gigabyte H61-DS2
      • Realtek HD
      • Delux 2:1
      • Logic
      • 120 kbps
      • 20 kbps
    pre's Avatar
    Jan 2012
    Driver re-install diye dekso??
    • proton_chain's Gadgets
      • Gigabyte GA-P55-UD3
      • 4x4GB DDR3-1600MHz
      • 6.5TB (3TB+2TB+1TB+.5TB)
      • Nvidia Geforce GTX 760 4GB
      • Samsung Syncmaster 22 inch
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
      • Sony Optiarc DVD burner
      • Blue Yeti USB Microphone
    proton_chain's Avatar
    Looks fine to me. Its probably your eyes.
    And about the black bars... sounds like an improper refresh rate. You may want to post the model number of your monitor so that we can check its native resolution. Most 17" CRTs can do 1280x1024.
    Windows 7 recommends 1024X768 as the native resolution for all the CRT monitors I've come across so far, I'm using a 17" Apollo DX monitor myself, upon changing refresh rate and resolution, you might have to adjust the picture for the first time you switch to particular resolution/refresh rate combo, but afterwards it shouldn't be necessary as the settings and adjustments made through the monitor's OSD remains saved.
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    My monitor is samsung 793DF.ar win e reinstall kortesi.ar ami dvi to vga converter diye chalate hocche as my gfx 6670 doesn't have any vga.so my refresh rate stucks @60hz.---------- Post added at 11:43 ---------- Previous post was at 10:56 ----------Win+driver reinstall korlam but no luck! :'(---------- Post added at 14:16 ---------- Previous post was at 11:43 ---------- @Reznov bro pls.take a screenshot of res 1024x768.and save it in jpeg format.
    ---------- Post added at 19:11 ---------- Previous post was at 14:16 ----------
    Any help?
      • Shure SRH440
      • TT Challenger Pro
      • A4tech Bloody V3M
    My monitor is samsung 793DF.ar win e reinstall kortesi.ar ami dvi to vga converter diye chalate hocche as my gfx 6670 doesn't have any vga.so my refresh rate stucks @60hz. bro pls.take a screenshot of res 1024x768.and save it in jpeg format.
    Any help?
    According to the specs, your monitor can do 1280x1024 @ 65Hz even though the recommended resolution is 1024x768 @ 85 Hz. I think you should go back to 1280x1024 @ 60 Hz (or whatever was working) if you feel uncomfortable with 1024x768. Here is a 1024x768 crop of my desktop.
Name:	Dwm 2012-03-05 19-37-44-08.jpg
    • SadmanBD's Gadgets
      • Asus VX229H 21.5" LED IPS
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • XFX 850W Core Edition
      • Luminous Solo 1000VA
      • Windows 8.1 Pro WMC
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    Amar 17" monitor eo 1280x1024 dile sob choto dekhai jotoi boro kori na keno. Tai 1024x768 @ 85Hz e chalate hosse :/
  1. ps2 on crt monitor?
    By offcutter in forum PlayStation 2
    Last Post: November 24th, 2011, 16:03
  2. Sale (Used) CPU+Monitor (CRT)
    By Manzoor in forum Shop - Gadgets
    Last Post: July 13th, 2011, 00:47
  3. playing game on crt monitor.
    By sakinsarwar in forum GPU
    Last Post: October 18th, 2010, 22:23
  4. Sale (Used) Samsung 15" CRT Monitor
    By shuvo89 in forum Shop - Gadgets
    Last Post: June 8th, 2009, 12:52
  5. Want to Buy 17" CRT monitor with warranty
    By Tian in forum Shop - Gadgets
    Last Post: March 10th, 2009, 00:43
Page generated in 0.81748 seconds with 15 queries.
