Thread: Help me about this huge problem
    • Sumit Pramanik's Gadgets
      • Asus Maximus V Formula With ThermalTake Armor A60 Chassis
      • Intel Core i5 2500K 3.3GHz with CoolerMaster Hyper 212X
      • GSkill TridentX - F3-2400C10D-8GTX
      • SanDisk Extreme SSD 120GB, WD Caviar Black 2TB x 2, WD Caviar Green 500GB
      • ASUS GeForce GTX 960 STRIX-GTX960-DC2OC-4GD5
      • LG 22MP68VQ-P 21.5 inch
      • Microlab B70 Speaker System; Sennheiser HD598SE
      • Corsair K95 RGB Platinum
      • Asus ROG Gladius II
      • Don't need one..........
      • Delta EX GPS-650AB B 650W
      • PowerTree S1250P 1250VA
      • Windows 10 Professional
      • Up-gradation Completed. Online. All system stable. Now I can sleep.
      • Quick Online (Earth Telecommunication Pvt. Limited)
      • 4Mbps
      • 4Mbps
    Sumit Pramanik's Avatar
    Oct 2010
    Unhappy Help me about this huge problem
    Hi All,
    I have got a huge problem about my 1000VA RahimAfrooz UPS with my PSU. I recently bought a Armor A60 with Delta 650W PSU. Now when I used this to my PC then My UPS was in "Battery Mode" unfortunately and My UPS just burnt (Because I saw sparking in UPS and get some burnt plastic scent from it and It doesnt work in Battery mode for only 1sec. I bought it 1 month ago only and it gives me perfect 40+min backup before I Attached the PSU) , cant support me any backup in Battery Mode & show Red Indicator but it works well Normally when Electricity is ON and Shows Green Indicator. I also tried to turn ON the PSU by Shorting 16th and 17th Leg in the PSU, but unfortunately 17th Pin is missing from it but as 18th and 19th leg is same as 17th (Gnd.). I thought I have a DOA problem and send it back to Binary Logic from where I bought it. But few hours ago they called me and said My PSU is perfectly well and they checked it in their PC's.
    So my Question is: Can't My UPS backup my 650W PSU or what? It(PSU) also dont work when I used it in a Voltage Stabilizer and it give no response...... Dont know what is my problem....... Plz help me...... I am confident that I connect it perfectly well.
    Again, Do you know anyone who use 650W PSU with RA 1000VA UPS? if yes do they have any problem?
    • shafi's Gadgets
      • Gigabyte Z170 gaming 7, apple macbook pro late 2013 retina/ apple ipad air/iPad pro 9.7 iPhone 7+
      • CORE i7 6700K WITH coolermaster hyper 212 evo/intel haswell i7 2.3 ghz
      • GSkill RipJaws v 3000 32gb ddr4/16 gb ddr3 1600 mhz on mac
      • Samsung 850 evo 250gb+1tb+wd ezex 1tb, trancend 35t3 3 tb, Wd black 5tb, 950 pro, muskin 1tb
      • gigabyte gtx 1080 xtreme sli/ intel iris pro+ nvidia gt 750m 2gb gddr5
      • samsung ku 6290 4k uhd tv, Dell S2716DG
      • Sound blaster zx
      • Akg k7xx,Samson sr 850, audio technica ath m50x, ,dt 990 pro, hd 598
      • corsair vengeance k95 rgb
      • logitech g500s, g700s,g502,g402, deathadder chorma on razer goliathus speed edition
      • ps4, xbox one controller
      • corsair rm i 1000w
      • 32 gb trancend, 64gb sandisk, 16gb kingston
      • Windows 10 education, mac osx maverick 10.9.1
      • wei- cpu and ram-7.6 on stock, gfx-7.9
      • thanks a lot to omnipotent creator(as a muslim allah) for my awesome rig, xbox one and ps4
      • Teksavvy 150mbps unlimited
      • 18.8MB/s
      • Don't upload
    shafi's Avatar
    Vancouver
    well when i game on 3d tv, i use 1500VA apollo ups, and my psu is 850w, but while playing gaming which demands a lot of processing powers both from gfx card section and cpu, it fails to prove itself as uninterrupted ps when electricity goes off, but generally it remains stable in other conditions
    Like if electricity goes off while playing assassin creed revelation, it stays sharp and again again bothers me with its harsh sound
    But while playing nfs run, it goes off(i don't know but i have to admit that ea, for the first time, made a brilliant bullshit, the story and gfx is okay, but it seems that the developers are noob about optimization, constant 30 fps on a sli setup, wtf)
    NFS: The Run has a FPS capping which is set to 30, it will not go higher then that.
    On topic, it seems your UPS is busted, take it to the place of purchase and claim warranty if possible, your power supply is fine, your UPS is most likely the culprit.
    @Sumit Pramanik can u power on ur PC directly from Wall socket (Without UPS)?
    As for RAhima Afrooza UPS.... take it to the motijheel Service center near "Doynik Bangla Mor" Their warranty support is quite good.
  1. Replies: 13
    Last Post: November 24th, 2011, 13:43
  2. Replies: 1
    Last Post: November 20th, 2010, 22:42
  3. Replies: 5
    Last Post: June 17th, 2009, 18:06
Page generated in 0.17252 seconds with 14 queries.
