Results 1 to 20 of 23
Thread: Power LED blinking...help!!!!!!!
    • Md. Asif's Gadgets
      • ASRock Z68 extreme3 Gen3
      • Core i5 2500k(4.4 GHz) with coolermaster hyper 412 slim
      • 8 GB Transcend 4*2(1600 MHz)
      • Hitachi 1 TB
      • Gigabyte gtx 670 oc Windforce 3x
      • Samsung syncmaster 943 19"
      • Creative inspires 2.1
      • A4 tech office
      • Logitech F310
      • Thermaltake smart modular 550 W
      • DVD ROM
      • Luminous solo 1200 VA
      • Windows 8 pro X64
      • Banglalion wimax
      • 64
    Md. Asif's Avatar
    mirpur-13,dhaka
    Arrow Power LED blinking...help!!!!!!!
    Really a weird problem.my pc suddenly stops and the power led blinking all the time.then reset or power switch doesn't work.only the way to start or stop it to switch off the power source or keep pressing down the power button.sometimes it happens after few seconds of starting the pc or even before showing the motherboard.
    it started since i change my dokker casing and using armor A60.is it possible that casing can do such problems.please help!!!!
    • SheikhItBaby's Gadgets
      • Gigabyte B75-D3H Rev 1.1 | Housed in (Chassis) : In Win Track
      • Corsair Vengeance 4GB DDR3 @1600mhz
      • OCZ Vertex 2 90GB SSD | Samsung Spinpoint 320GB 7200RPM
      • EVGA Geforce GTX 770 ACX SUPERCLOCKED
      • Samsung SyncMaster T240 24inch | 16:10 | WUXGA 1920x1200
      • Creative Labs Soundblaster X-FI XtremeGamer
      • Creative Inspire M4500 4.1 Speakers
      • Lexma LiFEKEY 8400 Keyboard
      • Lexma AM546 Laser Mice
      • Asus DVD-RW 24X
      • Windows 8.1 Professional | 64 bit
    SheikhItBaby's Avatar
    So your PC shuts down?
    Is anything appearing on your monitor?
      • Hitachi 1 TB
      • A4 tech office
      • Logitech F310
      • DVD ROM
      • Windows 8 pro X64
      • Banglalion wimax
      • 64
    Md. Asif's Avatar
    mirpur-13,dhaka
    Quote Originally Posted by The Prophet View Post
    pc shutdown completely.
    • optimus prime's Gadgets
      • MSI K9A2C-ff v1
      • AMD 64X2 5200+
      • Transend 4GB DDR2 800MHz
      • 1T Hitachi+750GB Samsung+500GB Hitachi
      • Sapphire ATI 4850 512MB DDR3 & 4830 512MB DDR3 in Xfire
      • ASUS MS228
      • Built-in Realtek
      • F&D F6000(5:1)
      • A4TECH
      • A4TECH 747H
      • Chinese
      • Valuetop 500W
      • ASUS
      • MICRO 1000VA(Customized)
      • 256
    try taking off the the front panel connetors of the casing from your mobo and start pc by shorting the pins(the ones of the power switch) in the mobo and see if the problem still exists
      • Hitachi 1 TB
      • A4 tech office
      • Logitech F310
      • DVD ROM
      • Windows 8 pro X64
      • Banglalion wimax
      • 64
    Md. Asif's Avatar
    mirpur-13,dhaka
    Quote Originally Posted by optimus prime View Post
    the problem occurs randomly sometimes after 2 or three days,sometimes several times within few minutes.anyway i will give it a try.
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Quote Originally Posted by engapu View Post
    same thing happened to me a long year ago and the culprit was PSU. It was generic though. problem find out na hole test ur psu.
      • Hitachi 1 TB
      • A4 tech office
      • Logitech F310
      • DVD ROM
      • Windows 8 pro X64
      • Banglalion wimax
      • 64
    Md. Asif's Avatar
    mirpur-13,dhaka
    Quote Originally Posted by hrishat View Post
    i thought about PSU so i gave it to warranty.but they said psu is ok.thinking about mobo but dont want to ask for warranty(at least one month) right now as my exam is going on and i need my pc.
    • Ork7O's Gadgets
      • Gigabyte b75-D3H, rev-1.0
      • Asus Xonar DGX
      • HP dvd1270 24x DVD Writer
      • Luminous 1000VA
      • Windows 8 Enterprise, x64
      • My baby!
      • DotinternetBD
      • 60-80 kbps
      • 70-80 kbps
    Ork7O's Avatar
    Did ya check the temps (cpu,gpu,hdd ....)??? Which gpu r u using? If nvidia than I recommend you upgrade to the latest driver.
      • Hitachi 1 TB
      • A4 tech office
      • Logitech F310
      • DVD ROM
      • Windows 8 pro X64
      • Banglalion wimax
      • 64
    Md. Asif's Avatar
    mirpur-13,dhaka
    i sold my gpu..so there is no gpu at that time, and yes i monitored the temp everytime..and starts my pc by shorting..but the problem remains ....i think its the problem with the mobo...may be HDD or RAM.
    • Robin Rayhan's Gadgets
      • Gigabyte B85-D3H
      • Intel Core i5 4570
      • Avexir 8GB DDR3 1600MHz
      • 120 + 240 GB ADATA SSD
      • (N/A)
      • AOC 20 INCH LED 1600x900
      • WinnerIT 3.5Mbps
      • 200-500 KB/s International | 12Mbps Local
    Robin Rayhan's Avatar
    Dec 2011
    Check front panel again. See if + and - are correctly put in.
    Disconnect the USB connectors from the casing, and then try running your pc by shorting the power switch with a screw driver, if that doesn't help, bench test your rig, take out the motherboard from your casing, put it on top of the box it came with, and see if that helps, then connect all the accessories and give it a shot, I've seen plenty of cases where a mobo won't work the moment it's installed inside a specific casing, and as you've mentioned you've been facing this problem since you switched to A60, there might as well be a connection.
    ---------- Post added at 04:50 ---------- Previous post was at 04:46 ----------
    Quote Originally Posted by XLR8 View Post
    in case of the Power button and reset button that + and - don't really matter, but it is a must for the LED and PC Speaker that you connect them to the correct orientation.
    • Gladiator''s Gadgets
      • Asrock z68 extreme4 gen3
      • intel corei5 [email protected] 3.1Ghz with SC
      • PQ 4gb ddr3 with1333Mhz including hs
      • Western digital 500gb blue cavier
      • sapphire hd 7770 1Gb ddr5
      • SAMSUNG
      • onboard Realtek
      • MICROLAB
      • Lexma am 546
      • a4 tech kbs 720
      • xfx 650w
      • Lite on
      • Power tree
      • WINDOWS 7 Ultimate 64bit
      • wired"Techzone" and wireless GP isp
    Gladiator''s Avatar
    Dec 2011
    Thats a weird problem.First make sure that ur monitor,hdd,and system is not going into standby mode.So first try soft kinda things.Go to power options in controll panel and set those m,hd turn off time into none.If those changes does't solve the problem then reassemble the whole system.
    Quote Originally Posted by Sunshine View Post
    How can the pc go into standby when the problem takes place even before it boots into windows?
      • MSI K9A2C-ff v1
      • AMD 64X2 5200+
      • ASUS MS228
      • Built-in Realtek
      • F&D F6000(5:1)
      • A4TECH
      • A4TECH 747H
      • Chinese
      • Valuetop 500W
      • ASUS
      • 256
    take off ur psu from ur casing and then start ur pc make sure that psu's body is not touching the casing and see if the problem still exists.....I once faced a problem like this and the culprit was short-circuit between casing and psu.....this may be the case as the problem started after u changed the casing ..right??
      • SAMSUNG
      • onboard Realtek
      • MICROLAB
      • Lexma am 546
      • a4 tech kbs 720
      • xfx 650w
      • Lite on
      • Power tree
    Gladiator''s Avatar
    Dec 2011
    Quote Originally Posted by K' View Post
    Its Not happening every time.I suppose most of the time his windows is booting properly.He said his pc turned off or seemed to be turned off after 1sec/minute(not every time) or sometimes after several hours ok.Low hdd/monitor turn off times sometimes cause such issue.And thats a possibility not a permenent/garantied cure.
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    keep the side panel open, turn on pc and disconnect powerSW & resetSW instantly. then see if the problem still occurs or not...
      • Hitachi 1 TB
      • A4 tech office
      • Logitech F310
      • DVD ROM
      • Windows 8 pro X64
      • Banglalion wimax
      • 64
    Md. Asif's Avatar
    mirpur-13,dhaka
    i plugged out all the front panel connection, strats with a short but same things happens,so i think my casing is ok.i will try try everything that all of u suggest,but it will take time as my exam is going on and i didnt have so much time u know that its so time killing.but thanks to all of u for helping and for your support and if you have any more then please suggest
      • Hitachi 1 TB
      • A4 tech office
      • Logitech F310
      • DVD ROM
      • Windows 8 pro X64
      • Banglalion wimax
      • 64
    Md. Asif's Avatar
    mirpur-13,dhaka
    when i set the psu inside the casing the problems occurs, but when i put the psu on the casing (outside) my pc runs ok.....what is the problem?
      • Asus DVD-RW 24X
    Temperature problem? Maybe? :S
      • Hitachi 1 TB
      • A4 tech office
      • Logitech F310
      • DVD ROM
      • Windows 8 pro X64
      • Banglalion wimax
      • 64
    Md. Asif's Avatar
    mirpur-13,dhaka
    Temperature of what?are you saying that PSU is getting hot thats why its happening. please make it clear
  1. Sale (Used) Tansnet Casing with 430watt Thermaltek Lite power Power Supply
  2. Replies: 2
    Last Post: December 1st, 2010, 01:32
  3. Any good power power supply available???
  4. HDD LED/Power LED on casing always on.is it bad?
    By knroeoueqisk in forum Others PC Hardware
    Last Post: March 19th, 2010, 08:53
  5. Power Led stays ON after shutdown!!!
    By VANGUARD in forum Technical Support
    Last Post: September 28th, 2009, 13:15
Page generated in 0.30000 seconds with 14 queries.
