Results 1 to 20 of 28
Thread: Cooler Master Hyper N520 CPU Cooler
    • VIPERS's Gadgets
      • ASRock B75M
      • Intel Ivy Bridge G2010 2.8ghz
      • 4GB Corsair Vengeance 1600
      • WD Caviar Blue 1TB
      • Asus MS228 22''
      • Creative sound blaster Audigy Value
      • Microlab TMN 4
      • A4 tech
      • A4 Tech X7
      • Thermaltake LP Black 500w
      • liteon 24x dvd rw
      • A Data16gb pen drive
      • Mercury 800VA
      • Windows 7 64bit
      • Wondows Rating 6.9
      • Delta Info Com 2mbps
      • 210- 250kbps
      • 45-50kbps
    VIPERS's Avatar
    Underground.......
    Default Cooler Master Hyper N520 CPU Cooler
    Cooler Master Hyper N520 CPU Cooler with all accessories and thermal paste. Came from Malaysia so no box.
    Asking Price is 2800tk Fixed.
    Interested BG member PM me or Call 01195428754.
    Check for details : http://www.coolermaster-usa.com/prod...roduct_id=2879
ID:	19875   Click image for larger version.
ID:	19876   Click image for larger version.
    Attached Images Attached Images
       0
    @optimus prime get this.
       0 Mobile
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    @CRY_ENGINE3 no box ok, but used or new??
       0
    • VIPERS's Gadgets
      • ASRock B75M
      • Asus MS228 22''
      • Microlab TMN 4
      • A4 tech
      • A4 Tech X7
      • liteon 24x dvd rw
      • Mercury 800VA
      • Windows 7 64bit
      • 210- 250kbps
      • 45-50kbps
    VIPERS's Avatar
    Underground.......
    Its 4 months used @@bhi Vy.
       0
    • samiulislam16's Gadgets
      • Core i7 860 2.93ghz
      • Sapphire HD7870 ghz dualX
      • Asus 22 inch LED MS228H
      • Realtech Hd 8 channel Audio
      • Creative 2.1
      • Newmen M560
      • Dilong usb controller
      • Samsung DVD writer
      • Sigma 640va
      • Good enough
      • Smile/BDcom
      • 150
      • 200
    samiulislam16's Avatar
    used or new? , why r u selling it?, whats its height, cause i've small case?, can i use it with my i7 860 (lga 1156)?
    Guess what??? scan it??:
    Good enough GAMING RIG
    HApPy GAMing
       0
    • VIPERS's Gadgets
      • ASRock B75M
      • Asus MS228 22''
      • Microlab TMN 4
      • A4 tech
      • A4 Tech X7
      • liteon 24x dvd rw
      • Mercury 800VA
      • Windows 7 64bit
      • 210- 250kbps
      • 45-50kbps
    VIPERS's Avatar
    Underground.......
    Quote Originally Posted by samiulislam16 View Post
    Yes u can used it. For more details u can check this link http://www.coolermaster-usa.com/prod...roduct_id=2879 .
       0
      • Creative 2.1
      • Newmen M560
      • Sigma 640va
      • Good enough
      • Smile/BDcom
      • 150
      • 200
    why seeling?
    well the site does not mention core i7 support??????
    HApPy GAMing
       0
    why seeling?
    Model RR-920-N520-GP
    CPU Socket Supports Intel Sandy Bridge 1155
    Supports Core i7 with socket LGA 1366
    Intel Socket (LGA1366 /LGA1156 / LGA775) *
    AMD Socket (AM3 / AM2+ / AM2)
    CPU Support Intel
    Corei7 / Core 2 Extreme / Core 2 Quad / Core 2 Duo / Pentium 4 / Pentium D / Celeron / Celeron D
    AMD
    Phenom X4 Quad Core / Phenom X3 Triple Core / Athlon 64 x2 Dual Core / Athlon 64 FX / Athlon 64 / Sempron
    Dimension 122.35 x 102.5 x 141 mm
    Weight 1.52 lbs
    Heat Sink Dimensions 115 x 62.3 x 141 mm
    Heat Sink Material Cu base, Al fin, 5 heatpipes
    Heat Pipes Dimensions 6 mm
    Fan Dimension 92 x 92 x 25 mm
    Fan Speed 1800 R.P.M.
    Fan Airflow 43.8 CFM (Total)
    Fan Air Pressure 3.24 mmH2O (Total)
    Bearing Type Sleeve
    Fan Life Expectancy 70,000 hours
    Fan Noise Level (dB-A) 19 dBA
    Connector 3-pin
    UPC Code 884102002885
    Notice * Supplied accessories may differ by country or area. Please check with your local distributor for further details.
    Company Info
       1
      • Creative 2.1
      • Newmen M560
      • Sigma 640va
      • Good enough
      • Smile/BDcom
      • 150
      • 200
    ooops ,my temps are getting higher currently 50* in idle ( both cpu and my brain)
    akhon maipa dekhi case e dhukbe naki as its 141mm, correct me if i m wrong
    HApPy GAMing
       0
    • MaDDy's Gadgets
      • AsRock Z77 Pro3
      • Intel i5 2500k
      • Team Elite DDR3 1333Mhz 8GB
      • Crucial M4 128gb SSD + Hitachi 500Gb Sata2
      • Evga GTX580
      • Asus MS228H 21.5" L.E.D
      • Microlab TMN-3 (2:1)
      • Mercury Multimedia Keyboard
      • Microsoft Intellimouse 3.0
      • N/A
      • Gigabyte SuperB 720w
      • Asus 24x DvD RW
      • Silicon Power 8GB + Corsair Voyager Slider 32GB USB3
      • Windows 8 Pro (x64)
      • Qubee 512 sky**
      • 64 Kbps
      • 15 Kbps
    MaDDy's Avatar
    Dec 2009
    Fixed price na hole nitam, as its used.
       0
    • VIPERS's Gadgets
      • ASRock B75M
      • Asus MS228 22''
      • Microlab TMN 4
      • A4 tech
      • A4 Tech X7
      • liteon 24x dvd rw
      • Mercury 800VA
      • Windows 7 64bit
      • 210- 250kbps
      • 45-50kbps
    VIPERS's Avatar
    Underground.......
    AMD Phenom X4 955 3.5ghz a idle Temp 26-27 and load a 40-45.
    ---------- Post added at 21:46 ---------- Previous post was at 21:43 ----------
    Quote Originally Posted by MaDDy View Post
    Market a ekon sob kichu price beshi. So 2800tk kom hole kemne hoi. As 2800tk is fair price i think.
    ---------- Post added at 22:56 ---------- Previous post was at 21:46 ----------
    Book for @optimus prime Till 24th February.
       0
    • optimus prime's Gadgets
      • MSI K9A2C-ff v1
      • AMD 64X2 5200+
      • Transend 4GB DDR2 800MHz
      • 1T Hitachi+750GB Samsung+500GB Hitachi
      • Sapphire ATI 4850 512MB DDR3 & 4830 512MB DDR3 in Xfire
      • ASUS MS228
      • Built-in Realtek
      • F&D F6000(5:1)
      • A4TECH
      • A4TECH 747H
      • Chinese
      • Valuetop 500W
      • ASUS
      • MICRO 1000VA(Customized)
      • 256
    yaa.....booked my me
       0
    • VIPERS's Gadgets
      • ASRock B75M
      • Asus MS228 22''
      • Microlab TMN 4
      • A4 tech
      • A4 Tech X7
      • liteon 24x dvd rw
      • Mercury 800VA
      • Windows 7 64bit
      • 210- 250kbps
      • 45-50kbps
    VIPERS's Avatar
    Underground.......
    Quote Originally Posted by optimus prime View Post
    @optimus prime Bro if u don't take u will must confirm at least before 2 days. 2nd Book for @Salmaan. If @optimus prime bro don't take within 24th February 2PM then @Salmaan Bro can take my Cooler.
       0
      • MSI K9A2C-ff v1
      • AMD 64X2 5200+
      • ASUS MS228
      • Built-in Realtek
      • F&D F6000(5:1)
      • A4TECH
      • A4TECH 747H
      • Chinese
      • Valuetop 500W
      • ASUS
      • 256
    Quote Originally Posted by CRY_ENGINE3 View Post
    yeahhh sure ....but I am afraid that i won't be cancelling the deal....
    ---------- Post added at 15:05 ---------- Previous post was at 00:09 ----------
    @CRY_ENGINE3 ...bro I suppose u r giving the thermal paste that came with it...at-least some of it????
       0
    He wrote that he'll provide thermal paste, check the first post, IMO a good deal, considering the fact used aftermarket coolers can hardly be found, and in most cases you'll have to buy a new one, which would cost you atleast 1200/= more.
       0 Mobile
    • VIPERS's Gadgets
      • ASRock B75M
      • Asus MS228 22''
      • Microlab TMN 4
      • A4 tech
      • A4 Tech X7
      • liteon 24x dvd rw
      • Mercury 800VA
      • Windows 7 64bit
      • 210- 250kbps
      • 45-50kbps
    VIPERS's Avatar
    Underground.......
    Quote Originally Posted by K' View Post
    Don't worry bro i will give this one which i upload image.
       0
      • MSI K9A2C-ff v1
      • AMD 64X2 5200+
      • ASUS MS228
      • Built-in Realtek
      • F&D F6000(5:1)
      • A4TECH
      • A4TECH 747H
      • Chinese
      • Valuetop 500W
      • ASUS
      • 256
    thanks for the conformation.....
       0
    Please read it....
    http://www.clickbd.com/bangladesh/47...cessories.html
    " Used Only 3 months. Came from UK. "
       0
    Quote Originally Posted by Raj_11 View Post
    Please read it....
    What's your point? A lot of people advertise their products on ClickBD, and he didn't bother giving them a story.
       0 Mobile
    • Rorschach's Gadgets
      • MSI B85 GAming
      • Core i3 4130 3.2Ghz
      • Corsair vengeance 2*4gb = 8gb Ddr3 1600Mhz
      • 128Gb Crucial M4 SSD + 2TB Hitachi HDD + 2* 2TB Seagate HDD+2TB Seagate HDD+(4TB+3TB) Seagate HDD
      • EVGA GTX 980 SC ACX cooler
      • Sony Bravia W670A 32inch
      • Sound Blaster X fi Titanium
      • Panasonic HTF600 + Creative 4:1 Speaker
      • Ducky
      • V3
      • Xbox 360 Controller In PC via Receiver
      • TT Toughpower XT 675W 80+Bronze
      • Asus Dvd-RW ; NZXT Sentry 2
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • BUCT 2Mbps real ip
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    Please read it....
    So what ? Ad to ditei pare uni Clickbd te , But Je age Book korse Unar kase sell Korlei hoi ...
    ---------- Post added at 16:53 ---------- Previous post was at 16:53 ----------
    I really Respect Cry_Engine3 bro ... Bcz amar Ak friend unake maybe 3000 taka offer disilo and O instant Product ta nite chaise .. But Cry_Engine3 bro Product ta sell korte raji hoi nai cz Already Akjon Booked kore falsilo .. Hats Off bro
    বাট রিমেমবার, জলিল নেভার ডাই, আর মরলেও ডাই এনাদার ডে।
       0
  1. Sale (New) COOLER MASTER HYPER 212+ [brand new]
    Last Post: February 18th, 2012, 00:25
  2. Sale (Used) Cooler Master Hyper N520 Box
    By Xtreme_3 in forum Shop - Gadgets
    Last Post: November 29th, 2011, 20:04
  3. Sale (New) Cooler Master Hyper 212 Plus Cpu Cooler
    By EBL.Mantis in forum Shop - Gadgets
    Last Post: November 10th, 2011, 20:44
  4. Sale (New) Tuniq TX-4 and Cooler Master Hyper 212 plus
    By MAXPAYNE in forum Shop - Gadgets
    Last Post: June 20th, 2011, 01:14
  5. Cooler Master Hyper N520 in BD
    By pcgamer in forum Tech News
    Last Post: May 9th, 2011, 21:54
Page generated in 0.33062 seconds with 15 queries.
