Results 1 to 13 of 13
Thread: P2P File Sharing Advanced Direct Connect Hub for Smile/BDCOM, ISPROS and others
    • notimeforlove's Gadgets
      • Intel
      • Intel Pentium 4
      • 1.5 GB
      • 80 GB
      • LG CRT
      • Altec Lansing / Sonic
      • A4TECH
      • A4TECH
      • Power Tree
      • Windows XP
      • Banglalink
      • ~30 KB
      • ~20 KB
    notimeforlove's Avatar
    Feb 2012
    Default P2P File Sharing Advanced Direct Connect Hub for Smile/BDCOM, ISPROS and others
    Discontinued!
    Advanced Direct Connect(ADC), is a peer-to-peer file sharing and chat protocol, using the same topology, concepts and terminology as the Direct Connect (DC) protocol.
    Requirements:
    StrongDC++
    View this thread to learn how to connect to a ADC hub: BanglaDC THREAD
    You should connect to BanglaDC's hub. It is always good to stay connected at multiple hubs because a hub might go off (Poof!) anytime due to electrical and or other problems.
    This is where the idea of hosting a hub came up.
    IS PROS users have couple of ADC hubs to stay connected to but I guess Smile/BDCOM has only one (BanglaDC). They have some Http File Servers (HFS) too. But the problem is that those ADC hubs and HFS' can be accessed by IS PROS users only!
    See: [IS PROS THREAD] and [THE LIST OF THEIR HUBS]
    And Finally the address to the hub:
    adc://crazylove.bounceme.net:411
    If your ISP is registered with BDIX you can connect to both BanglaDC and this hub. Here's a list of BDIX members on
    BanglaDC's website: Members BDIX's website: Members
    A user guide for this particular hub might be created in the future.
    But it is not needed for now, as the cool guys behind BanglaDC and IS PROS adc hubs already created two of them.
    crazylover does host a HTTP File Server but that is for his own personal purposes.
    User guide: PDF / Flip Book
    Like and share the hub's page on facebook: CrazyLoveAdcHub,
    If you are aware of accessible (HFS) Servers and or ADC hubs for Smile/BDCOM please share in the comments below.
    Last edited by notimeforlove; November 13th, 2012 at 05:13. Reason: Hub permanently offline.
    no ip r working..............
    is there a problem....????
      • Intel
      • Intel Pentium 4
      • 1.5 GB
      • 80 GB
      • LG CRT
      • A4TECH
      • A4TECH
      • Power Tree
      • Windows XP
      • Banglalink
      • ~30 KB
      • ~20 KB
    Feb 2012
    Default Problem?
    Quote Originally Posted by BugBig View Post
    Yes. There was a problem with the Microtik router or something, so some smile users could not get connected to the net.
    It is up and working now.
    Knowledge is your only defense.
    Keep away from people who try to belittle your ambitions. Small people always do that, but the really great make you feel that you, too, can become great.~ Mark Twain
    Quote Originally Posted by notimeforlove View Post
    kintu bro ami to ispros ar.....amr ta to kag kora na............
      • Intel
      • Intel Pentium 4
      • 1.5 GB
      • 80 GB
      • LG CRT
      • A4TECH
      • A4TECH
      • Power Tree
      • Windows XP
      • Banglalink
      • ~30 KB
      • ~20 KB
    Feb 2012
    Akhono kaj kortesena?
    IS PROS er hub gulo'r ki obostha?
    aktao active nai.............
    vai , ami karo file list dakta partasina...................connect hoi na...........prob ki.........
      • Intel
      • Intel Pentium 4
      • 1.5 GB
      • 80 GB
      • LG CRT
      • A4TECH
      • A4TECH
      • Power Tree
      • Windows XP
      • Banglalink
      • ~30 KB
      • ~20 KB
    Feb 2012
    This hub is mainly for Smile and BDCOM users. I can't do anything for other users.
    ISPROS' users are using the hub without any problem. Try using DC++ and see if that makes any difference.
    Read the pdf if anyone needs detailed step by step information on how to connect and share on ADC.
    http://dl.dropbox.com/u/8433808/Adva...ct_Connect.pdf
      • Intel
      • Intel Pentium 4
      • 1.5 GB
      • 80 GB
      • LG CRT
      • A4TECH
      • A4TECH
      • Power Tree
      • Windows XP
      • Banglalink
      • ~30 KB
      • ~20 KB
    Feb 2012
    Use DC++ or StrongDC++ or ApexDC++ to connect to this ADC hub:
    adc://ashman.serveftp.com:411
    adc://ashmanlive.sytes.net:411
    All links will lead to the same hub.
    The hub stays on as long as the electricity of Bangladesh allows it.
    For detailed step by step information on how to connect on and share using ADC download this pdf from here: http://dl.dropbox.com/u/8433808/Adva...ct_Connect.pdf
    OR view the flipbook or download the pdf from my hfs:
    http://ashmanlive.sytes.net/ADC/
      • Intel Desktop Board
      • Dual core 2.8Ghz
      • 1GB DDR2
      • 250GB
      • Samsung LCD 19''
      • Realtech High Definition Audio
      • Altech Lancing 2:1
      • A4tech
      • A4tech
      • Windows 7 SP1 ORIGINAL
      • SMILE/BDcom
      • 1Mbps
      • 512Kbps
    ••F3AR••'s Avatar
    How you made this? Its superb?
      • Intel
      • Intel Pentium 4
      • 1.5 GB
      • 80 GB
      • LG CRT
      • A4TECH
      • A4TECH
      • Power Tree
      • Windows XP
      • Banglalink
      • ~30 KB
      • ~20 KB
    Feb 2012
    Is it? I think the pdf is much user friendly compared to this.
    I used an open source online pdf-to-flash-page-flip converter.
    I used strongdc++ and it was fine.but now my download speed is only 1-7 kbps.Can someone help me how to fix the problem and increase speed.
    • Frenzy's Gadgets
      • MSI G31M3-F
      • Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz
      • nVDIA GeForce 9400GT
      • Windows 7 Ultimate/ Ubuntu 11.04/ Mac OS X 10.6.8
      • Connect BD Ltd
    Frenzy's Avatar
    nice work bro. the manual is well written. btw im a Connectbd user assigned with a static ip. And i wanna host a private HUB. How do i make it up and running for WAN. I am already running a LAN server and i wanna expand in more directions. Any suggestion?
      • Intel
      • Intel Pentium 4
      • 1.5 GB
      • 80 GB
      • LG CRT
      • A4TECH
      • A4TECH
      • Power Tree
      • Windows XP
      • Banglalink
      • ~30 KB
      • ~20 KB
    Feb 2012
    If your LAN and WAN IP addresses are the same then you are good to go. If it is not then you are out of luck.
    I haven't come across any workaround for that problem yet. Not sure if there is one.
    Even if you manage to make it work outside your LAN somehow(with port forwarding and stuff) chances are that the transfer speed for the WAN people won't be the same. i.e. they will most likely get what their package bandwidth allows them.
    Wish I could help.
    Let me know if you find a fix. I am not using broadband anymore; shifted to wireless long time now and thus I am out of this file sharing gig.
  1. Ispros DC++ File sharing Network
    By minitt in forum ISPros
    Last Post: November 2nd, 2012, 20:48
  2. File Sharing DC HUB for ConnectBD Users
    By Frenzy in forum File Sharing and Torrents
    Last Post: September 16th, 2012, 22:16
  3. Smile/BDCOM, Link 3 | BanglaDC++ File Sharing Network!
    By GiDDY_SOUL in forum File Sharing and Torrents
    Last Post: September 13th, 2012, 23:04
  4. Ispros File sharing Network address With DC Client
    By Shameem Raihan in forum ISPros
    Last Post: March 13th, 2011, 03:25
  5. BDCOM-SMILE Sharing Community
    By abir in forum Smile/BDCom
    Last Post: November 22nd, 2010, 12:57
Page generated in 0.24446 seconds with 14 queries.
