Results 1 to 20 of 26
Thread: gtx 560Ti and gtx560 sli help [urgent]
    • mr_08's Gadgets
      • Asus B75M+ || Gigabyte G41m combo
      • Intel core i5 2500k @3.3ghz cooled by the CM V6GT || Intel dual core e5500 @4ghz with TT V1AX cooler
      • Gskill RIPJAWS X SERIES 4gbx2 @ 1600mhz || adata xpg 2x2gb @1333mhz 7-7-7-20
      • samsung f3 500gb || wd 1tb , samsung 250gb
      • Sapphire 7970 OC 3GB w/ BOOST || Gigabyte 8800gts 512mb
      • Sony Bravia KDL42W700B || Samsung P2350, Samsung T190
      • integrated
      • Genius G500v || cosonic headphone
      • cm devastator mb24 , a4tech x7 g800 , logitech k260|| a4tech x7 g500,a4tech KB 28g
      • cm devastator ms2k , a4tech x7 X710 || a4tech office mouse, logitech m210
      • logitech g13,logitech rp2,xbox 360 wireless controller,generic usb x 3
      • xfx pro series 650w || delux 450w
      • liteon 24x w/ LT || asus dvd rw
      • Transcend 16gb USB 3.0 || Transcend 16gb usb 2.0
      • Apollo 1200va || Powerguard 650va
      • win7 ultimate sp1 || xp sp3
      • alhamdulillah!duitai chole,kharap na :D
      • Itbasebd || qubee
      • 8mb || 4 mb
      • 8mb || 2mb
    Default gtx 560Ti and gtx560 sli help [urgent]
    currently im using a i5 2500k with gigabyte z68 d2h b3.gpu is gigabyte 560ti OC 1gb.
    im thinking of getting a ecs gtx560 and do a sli.so what kind of a performance improvement can i expect in games?i mean frames kirokom barbe?ektu taratari janale bhalo hoi!!
    ami chhoto amake marbenna.-_- shob _ buira_gamer_
    If a higher-end card is SLIed with a lower end card then the higher end card will just simply downgrade to match the other card.
    Quote Originally Posted by EviL AnGeL View Post
    but it will work as a gtx 560 non ti sli wont it?
    Quote Originally Posted by Taher fu®ious™ View Post
    technically yes they should work.
    how about practically? i'm planning to sli also...
    There was a thread where a 570 & 580 were working in SLI but with a 3rd-part patch. Officially NV locks that up, while in AMD cards u can CFX 2 different model of the same series like 6950 & 6970 without any 3rd party tools. I googled up a bit but couldn't find any answers to the specific config.
    http://banglagamer.com/showthread.php?23606-SLI-2-different-Nvidia-cards!!-Guide-inside&highlight=580+sli+570
    ---------- Post added at 14:23 ---------- Previous post was at 14:16 ----------
    But yes, I would strongly suggest not to, for the sole reason that either the user has to wait for a modded driver or mod the driver himself. But I'll tell ya what, if both of u guys want to SLI then why don't u guys each buy a 560 Non-Ti & exchange it with each other leaving 1 person with dual 560s & another dual 560 Ti's. Bcoz, even with this patch if one Ti & another Non-Ti is used then still performance will be same a dual Non-Tis or even a bit worse due to scaling.
    • eXsTatik's Gadgets
      • Msi 990FXA GD80
      • Phenom x6 1090T @ 4ghz 24/7
      • 8gb drr3 1600mhz
      • 500GB x2 raid 0 + 1TB caviar black + 500GB wd passport.
      • GTX 580
      • Syncmaster 2243
      • X-fi titanium
      • 2x microlab solo 7c front and back, 2 x microlab FC subs + pro 1 as center
      • Razer blackwidow
      • Razer imperator/deathadder/a4tech x7/razer boomslang 2007CE/ Razer Abyssus
      • xbox 360
      • 850 Toughpower Thermaltake
      • Glasses.
      • Generator that runs on oil downstairs with 24/7 backup
      • Windows7 64 I still dont really care.
      • Yes if you are wondering I am AMD fanboyish :/. LOL
      • link 3
      • 142
    eXsTatik's Avatar
    Beyond reality
    I would recommend that you get a Ti and sli not with the 560 vanilla as you would need modded drivers, if you are okay with the modded drivers then go for it otherwise its better to get similar cards.
    FTW!!!!!!!!!!
      • ASROCK h81-GL
      • Core i3 4130 @3.40ghz
      • WD 1tb BLUE
      • Radeon r7 260x (2gb) GDDR5
      • Hp 18.5"
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    A place Where U Belong >:/
    Bro, get another gigabyte gtx 560Ti... Duita kay 950mhz a OC koray Sli koro... IMO that will b a gud option
    • shafi's Gadgets
      • Gigabyte Z170 gaming 7, apple macbook pro late 2013 retina/ apple ipad air/iPad pro 9.7 iPhone 7+
      • CORE i7 6700K WITH coolermaster hyper 212 evo/intel haswell i7 2.3 ghz
      • GSkill RipJaws v 3000 32gb ddr4/16 gb ddr3 1600 mhz on mac
      • Samsung 850 evo 250gb+1tb+wd ezex 1tb, trancend 35t3 3 tb, Wd black 5tb, 950 pro, muskin 1tb
      • gigabyte gtx 1080 xtreme sli/ intel iris pro+ nvidia gt 750m 2gb gddr5
      • samsung ku 6290 4k uhd tv, Dell S2716DG
      • Sound blaster zx
      • Akg k7xx,Samson sr 850, audio technica ath m50x, ,dt 990 pro, hd 598
      • corsair vengeance k95 rgb
      • logitech g500s, g700s,g502,g402, deathadder chorma on razer goliathus speed edition
      • ps4, xbox one controller
      • corsair rm i 1000w
      • 32 gb trancend, 64gb sandisk, 16gb kingston
      • Windows 10 education, mac osx maverick 10.9.1
      • wei- cpu and ram-7.6 on stock, gfx-7.9
      • thanks a lot to omnipotent creator(as a muslim allah) for my awesome rig, xbox one and ps4
      • Teksavvy 150mbps unlimited
      • 18.8MB/s
      • Don't upload
    shafi's Avatar
    Vancouver
    well im on sli with asus gtx 560 top, but an atx board is a must, cuz the more distance u can maintain between two cards, the more better
    and also u need a very good psu to support it
    at least 800w recommended
    ---------- Post added at 20:31 ---------- Previous post was at 20:26 ----------
    i have benched assassin creed revelation 2 times on everything maxed out(on 1080p 46inch 3d led tv), i got 145 and 129 fps on avg using fraps
    and also constant 60 on saints row the third with vsync on
    well waiting for bf3 to smoke out
    u can see my rig from my gadget menu
    ---------- Post added at 20:31 ---------- Previous post was at 20:31 ----------
    its always better to get identical cards
    ---------- Post added at 20:32 ---------- Previous post was at 20:31 ----------
    sorry my rig is
    core i7 2600k
    z68extreme 3 gen3
    asus gtx 560 top sli
    with corsair tx 850w v2
    • mr_08's Gadgets
      • integrated
      • Itbasebd || qubee
      • 8mb || 4 mb
      • 8mb || 2mb
    why not!!
    ---------- Post added at 23:13 ---------- Previous post was at 23:11 ----------
    Quote Originally Posted by Z!mM3r View Post
    arey bhai 560ti will cost a lot!its around 22k.and i dont think the gigabyte 560ti is available in market.
    Different cards on SLI is not officially supported. You can use a tweak but thats just a hassle. If needed you can just sell your Ti and get 2 non-tis and not deal with all the hassle 2x560=1x580 more or less.
    • Md. Asif's Gadgets
      • ASRock Z68 extreme3 Gen3
      • Core i5 2500k(4.4 GHz) with coolermaster hyper 412 slim
      • 8 GB Transcend 4*2(1600 MHz)
      • Hitachi 1 TB
      • Gigabyte gtx 670 oc Windforce 3x
      • Samsung syncmaster 943 19"
      • Creative inspires 2.1
      • A4 tech office
      • Logitech F310
      • Thermaltake smart modular 550 W
      • DVD ROM
      • Luminous solo 1200 VA
      • Windows 8 pro X64
      • Banglalion wimax
      • 64
    Md. Asif's Avatar
    mirpur-13,dhaka
    Quote Originally Posted by mr_08 View Post
    sli with other GPU is not officially recommended.here you can see.better you manage a gtx 560ti and do sli. its a way more than gtx 580.link
    That mixed GPU SLI tweak has been around for long, those of you who wished to use SLI on a non SLI board should be more or less familiar with the SLI hack, that mixed GPU SLI acceleration is one of the three configurable settings within the registry that tells how the SLI is supposed to work, hell I wish someone would provide dipanzan another GTX 460 and we might be able to put the SLI hack to a real test (I used the hack to SLI 2 8500GT cards which was an epic fail as even with these cards hooked up in SLI on a P45 didn't provide good enough performance as the card itself is weak)
    On topic: OP buy another 560Ti and SLI it with the one you currently own, it'll be the best thing to do.
    ---------- Post added at 07:24 ---------- Previous post was at 07:21 ----------
    @mr_08 it'll work but all you'll have is two GTX 560s on SLI and that Ti of yours will underperform itself as when bonded, the GPUs operate at the speed of the relatively slower card.
    • mr_08's Gadgets
      • integrated
      • Itbasebd || qubee
      • 8mb || 4 mb
      • 8mb || 2mb
    Quote Originally Posted by K' View Post
    so it seems i should sell my 560Ti and get two 560s.
    ---------- Post added at 14:51 ---------- Previous post was at 14:50 ----------
    i dont know koto pawa jabe 560ti bechle.i bought it around the last of september,should be like 29/30th september.dekhi bhalo dam paile i might sell it.ad maira diboney
    Whatever price you get, it will surely be enough for 1x560 + some more. You should also put up a trade offer, 560ti for 560+cash..
    • mr_08's Gadgets
      • integrated
      • Itbasebd || qubee
      • 8mb || 4 mb
      • 8mb || 2mb
    great idea man!the best idea seems to be the 560+cash.another problem is amar monitor ekta but pc duita.jei pc te 560ti lagano oita use ee korte partasina as i have only one monitor and my old windows is in my old pc.so i need some cash for the monitor as well.
    ecs 560non ti(15k-sup) r msi 560Ti(22k-cs) er price difference only 7k
    so i suggest to manage 7k more and go for Ti without any exchange offer
    btw as far i know there is slight difference between (nonti 560Sli vs 560Ti Sli)
    HE needs a 560 not 460 , as he already owns a 460. Anyway I can lend him or any1 can lend me their card to see if the sli hack really works.
    7k difference is a lot lol.
    You can offer your 560ti for 560+2-3k cash and make it a sweet deal for both of you.
    wow i forgot that i have a 560 :O
    good idea btw. but me and @mr_08 have to think about the money.... and some other things,i will go for sli soon i will face this problem also
  1. Want to Buy GTX 560Ti WANTED
    By furiousTaher in forum Shop - Gadgets
    Last Post: February 11th, 2012, 14:30
  2. gtx 560ti or hd 6950
    By Zimmer™ in forum Help - General Shopping
    Last Post: January 2nd, 2012, 23:30
  3. Kepler or gtx 460 sli
    By shafi in forum Help - PC Buying
    Last Post: November 11th, 2011, 01:58
  4. Replies: 84
    Last Post: September 29th, 2011, 22:54
  5. EVGA design GTX 560ti with custom cooler
    By pcgamer in forum Tech News
    Last Post: April 19th, 2011, 13:49
Page generated in 0.31058 seconds with 14 queries.
