Results 1 to 20 of 26
Thread: ATi Radeon 5830 temperature issue ! I'm Using Thermaltake V6 Chassis
    • Ahsan Abdullah's Gadgets
      • Gigabyte
      • Intel
      • A-Data
      • Samsung 1-TB
      • Ati Radeon 5830
      • Creative-4.1
      • Raidmaxx 730s
      • Apolo 1200 VA
      • Windows 7 Ultimate
      • OLLo Wimax
      • 80-150 KB
    Sep 2011
    Dhaka+Chittagong
    Angry ATi Radeon 5830 temperature issue ! I'm Using Thermaltake V6 Chassis
    Feeling extreme hot....in front of my PC. I don't know why my card is going so crazy{45-50 in idle mood}
    ( mind it, bought it just 5 months ago Brand new). Currently I'm using Thermaltake V6 Chassis....with good air flow. But card is getting hott 45 to 50 at idle & 65 while playing NFs Run/Crysis 2 etc. Just few days ago temperature was 33 to 38 at idle & 55 in full throttle. Frndz frm BG pls help me out. Is that attitude natural or any trouble ...?
    • Mohaan's Gadgets
      • Gigabyte H61M-S2PV
      • Intel Core i3 3220 @ 3.3 Ghz
      • Transcend 4 GB DDR3
      • Samsung 250 GB
      • Nvidia Geforce 210
      • LG 22MP65HQ-P 22" IPS LED
      • Sound Blaster Audigy.
      • Microlab 4:1
      • Chudirbhai keyboard
      • Chudirbhai mouse
      • Logitech F310
      • Maxim 500 watt
      • Asus DVD-R
      • Windows 8.1 Professional 64 bit
      • Economical beast
      • Link3 Technologies
      • 192~195
    Mohaan's Avatar
    Shantinogor,Chamelibag
    I don't know about your card, but mine ( HD 4770) stays at 45-47 at idle and 60-65 at load. I don't feel anything weird or whatsoever. However if you think you do have a problem with your card then open the cpu and brush it with a vacuum cleaner or ki jani ekta ase ( ) and then setup it again. I had this sort of problem but I cleaned it and it is fine now. Mind you , my card is more than 1.5 years old. I hope other members can help you further in time of your crysis .
    visit san&design and get your design done
    I am 80% addicted to Counterstrike. What about you?
    are you using 12.1 driver???? Then it happens. Mine was 36 before, now in 12.1 38 degree celcius.
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Intel Core i5 2500K @4.2GHz
      • Sapphire Vapor-X HD 7970
      • Asus MS228H 21.5''
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • TT Toughpower 750watt
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    dude, my hd 5770 used to stay 55 on idle and 75 on load. so, don't u worry. Use GpuZ, for thermal monitoring and don't worry until it reaches 70 or higher.
    Quote Originally Posted by Ahsan Abdullah View Post
    Same thing happened when I bought my GTX460 a few months back along with my PC. I couldn't sit in front of it, the heat waves coming out of my 460 were literally burning my feet when playing games. The V6 has a side fan mount, and a front intake if I'm correct ?
    What I did was, installed 2x fans at the side, and an intake at the front which solved my problem. The heat is stacking up inside your case, at least that is what happened in my case. The fans helped push hot air out, while maintaining a good airflow.
    and.......Click image for larger version.
    @Ahsan Abdullah this raise in temp means winter season is almost over and in a few weeks we'll be fully embraced by summer and your idle/load temp will further increase.
    put some fan on you side panel so that air can blow directly over your GPU.
    ^This, but what Dipanzan said could also be true.
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    2x side fan in dokker :/
    you r right. But minar bhai, ami nije chokkhe dekhsi 12.1 dewar por temp barse.
    2x side fan dokker e kemne?
    Quote Originally Posted by @bhi View Post
    Quote Originally Posted by EviL AnGeL View Post
    Ahh, I meant 2x fans (at the side, and an intake at the front). Sorry guys *facepalm*
    proof that u are a noob
    Just kidding.
    • Rajmi's Gadgets
      • MSI H61M-E33 [B3]
      • Corei5 2500k
      • GSkill Ripjaws 2x2 => 4gb
      • intel 3000
      • 19" LCD LG Flatron
      • Creative 2.1
      • A4tech slim
      • Delux T6 :: Dragon
      • Delta 550W
      • BTCL - ADSL
      • 64KBps
      • 15KBps
    Rajmi's Avatar
    Dee might be selling a fan...u can contact him if u'r interested in buying one soon.
    • eXsTatik's Gadgets
      • Msi 990FXA GD80
      • Phenom x6 1090T @ 4ghz 24/7
      • 8gb drr3 1600mhz
      • 500GB x2 raid 0 + 1TB caviar black + 500GB wd passport.
      • GTX 580
      • Syncmaster 2243
      • X-fi titanium
      • 2x microlab solo 7c front and back, 2 x microlab FC subs + pro 1 as center
      • Razer blackwidow
      • Razer imperator/deathadder/a4tech x7/razer boomslang 2007CE/ Razer Abyssus
      • xbox 360
      • 850 Toughpower Thermaltake
      • Glasses.
      • Generator that runs on oil downstairs with 24/7 backup
      • Windows7 64 I still dont really care.
      • Yes if you are wondering I am AMD fanboyish :/. LOL
      • link 3
      • 142
    eXsTatik's Avatar
    Beyond reality
    Your gpu lost its thermal virginity lol.
    ---------- Post added at 04:27 ---------- Previous post was at 04:27 ----------
    Casing herpes
    FTW!!!!!!!!!!
    • Robin Rayhan's Gadgets
      • Gigabyte B85-D3H
      • Intel Core i5 4570
      • Avexir 8GB DDR3 1600MHz
      • 120 + 240 GB ADATA SSD
      • (N/A)
      • AOC 20 INCH LED 1600x900
      • WinnerIT 3.5Mbps
      • 200-500 KB/s International | 12Mbps Local
    Robin Rayhan's Avatar
    Dec 2011
    U shudnt really worry until u hit 78-80 in load. @Ahsan Abdullah
      • Msi 990FXA GD80
      • 8gb drr3 1600mhz
      • GTX 580
      • Syncmaster 2243
      • X-fi titanium
      • Razer blackwidow
      • xbox 360
      • Glasses.
      • link 3
      • 142
    eXsTatik's Avatar
    Beyond reality
    anything below 90 is fine lol. All you people worry too much.
    FTW!!!!!!!!!!
    • Gladiator''s Gadgets
      • Asrock z68 extreme4 gen3
      • intel corei5 [email protected] 3.1Ghz with SC
      • PQ 4gb ddr3 with1333Mhz including hs
      • Western digital 500gb blue cavier
      • sapphire hd 7770 1Gb ddr5
      • SAMSUNG
      • onboard Realtek
      • MICROLAB
      • Lexma am 546
      • a4 tech kbs 720
      • xfx 650w
      • Lite on
      • Power tree
      • WINDOWS 7 Ultimate 64bit
      • wired"Techzone" and wireless GP isp
    Gladiator''s Avatar
    Dec 2011
    @Ahsan Abdullah Your's one is really cool man.If u worry to much then just open the case, blow those naughty dust from ur gpu fan with a blower.This will improve the thermal condition of ur card.Oh and keep in mind that summer is knocking at the door
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    temps are absolutely OK.... don't see any reason to be worried about. just the winter has gone and atmospheric temperature is rising everyday....
    though the psu is a bad one(probably a low end 450w unit)...
      • Gigabyte B85-D3H
      • (N/A)
      • WinnerIT 3.5Mbps
    Dec 2011
    PSU can be the issue here too. I had 400watt PSU minimum requirement of gtx550ti. a gts450 wants 450watt. got 80-75 load temp on gts450. Asus smart doctor used to minimize my games wen temp. hit 80. However 65-70 load temp. on same 400watt PSU with gtx550ti. When upgraded to 650watt maximum load temp was 55. (installed 4 fans)
  1. Replies: 9
    Last Post: January 15th, 2012, 22:02
  2. Sale (Used) Gigabyte Ati Radeon HD 5830
    By Dhumketu in forum Shop - Gadgets
    Last Post: July 28th, 2011, 05:09
  3. Want to Buy Thermaltake Chassis
    By Aziz37 in forum Shop - Gadgets
    Last Post: July 7th, 2011, 13:45
  4. Thermaltake Debuts New Chaser MK-1 XB ATX Chassis
    By Frank3nst3in in forum Tech News
    Last Post: June 18th, 2011, 07:10
  5. ATI 5830 vs. 5770
    By sakinsarwar in forum GPU
    Last Post: November 15th, 2010, 22:00
Page generated in 0.31834 seconds with 15 queries.
