Thread: How to Auto disable Lan connection when IP conflict error occurs..
    Default How to Auto disable Lan connection when IP conflict error occurs..
    Basically I want my lan connection to disable itself when "IP conflicts" occurs.
    I'm on windows 7 64bit.
    All kinds of suggestions are welcome.
    Can be done, but not unless you have some nice knowledge of the windows tcp/ip stack and shell scripting.
    Anyway, the solution is simple. Rather than you doing something about it, tell your ISP to stop being retarded and configure dhcp (or whatever they use to assign IPs) correctly.
    • Flame's Gadgets
      • MSI 880GMA-E35
      • AMD Phenom II X6 1090T @ 3.2Ghz
      • 2x4GB Transcend DDR3 1333MHz
      • 2TB Hitachi 7200RPM
      • XFX AMD HD6850 1GB
      • LG Flatron W1953T 18.5"
      • Realtek HD Audio
      • Creative | A4Tech
      • Genius KB 101
      • Genius X Scroll
      • Genius Maxfire
      • Tt TR2 500W
      • ASUS DVD-RW
      • ADATA 320GB External HDD
      • Prolink somethingsomething
      • Windows 7 Ultimate (64-bit)
      • 5.9 | 7.7 (without HDD)
      • BEST! :D
      • Spark
      • 45
      • 35
    Flame's Avatar
    Aug 2008
    Quote Originally Posted by Wintereise View Post
    Anyway, the solution is simple. Rather than you doing something about it, tell your ISP to stop being retared and configure dhcp (or whatever they use to assign IPs) correctly.
    Like talking with ISPs ever solve anything.
    or u can buy a router & set a dhcp urself, then when the ip conflicts it will get a new ip. BTW, normally IP conflict hoy na unless ur hacking/know other persons IP/PPOE.
  1. Replies: 19
    Last Post: April 24th, 2012, 16:38
  2. How to disable Networ Card from cmd ?
    By Gaara™ in forum Technical Support
    Last Post: April 28th, 2011, 18:39
  3. Help on Redialing a PPPoe Connection Auto
    By ABDmaster in forum Technical Support
    Last Post: January 29th, 2010, 22:30
  4. How to Disable Dial-up Modem's Dialing Sounds ...
    By soul in forum Technical Support
    Last Post: November 25th, 2009, 21:01
  5. Win 7 - Turn Off and Disable Hibernation - Save 2 GB Space
    By rafaat in forum Technical Support
    Last Post: May 29th, 2009, 18:14
Page generated in 0.16714 seconds with 14 queries.
