Results 1 to 16 of 16
Thread: Is there any way of running a 16bit application in 64bit OS?
    • s.s.shuvo's Gadgets
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • G.SKILL FORTIS 16GB (2 x 8GB) DDR4 2400
      • Samsung 850 EVO 2.5" 250GB Sata III SSD
      • MSI GeForce GTX 1060 Aero ITX 6GB
      • Dual ASUS VN248H-P IPS 23.8" 5ms (GTG) with Mounted on VESA stand
      • Topping D30 DAC > Schiit Magni 3 headphone amp, xDuoo TA-01 DAC/Amp combo (Tube)
      • Polk Audio T15 through Nobsound TPA 3116 amp, Philips SHP9500, Monolith M1060 Planar
      • Generic Backlit
      • Rapoo Vpro
      • SeaSonic M12II 620 EVO Bronze 620W (Full Modular)
      • Sokol game motamuti chole r ki
      • Spectrum Time Warners Cable
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    Default Is there any way of running a 16bit application in 64bit OS?
    Hey everyone.
    I am stuck in a problem. I am using windows 7 sp1 32bit in my laptop. A particular 16bit software ( windows 98 আমলের জিনিস) runs fine in 32 bit OS. But I can't run it in 64bit version of windows. Is there any way of running it in 64 bit? Any kind of emulator or something similar? I really need to run this soft. So, any help is appreciated.
    Thanks.
    Past : Full time gamer - Part time others
    Present : Full time others - Part time gamer
    Quote Originally Posted by s.s.shuvo View Post
    Hey everyone.
    Thanks.
    easy and simple, just go to the property of that program, in compatibility tab select Windows 98, and u r done.....
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • Generic Backlit
      • Rapoo Vpro
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    Quote Originally Posted by musvi View Post
    Oops sorry I forgot to mention. I've tried that method. It doesn't work at all. Here is the screenshot of the error message:
    • Frank3nst3in's Gadgets
      • MSI 760GM-P33
      • AMD Athlon II X4 640
      • Samsung 500GB F3, WD Blue 1TB, Seagate Barracuda 1TB, Hitachi 160GB
      • ECS EliteGroup GTX 550Ti
      • ASUS VX229H 21.5
      • Creative SB X-Fi Titanium
      • Panasonic HTF600, SoundMagic E10
      • CM Storm Devastator MS2K
      • CM Storm Devastator MB24
      • Windows 8.1
      • 64 KBps
    Frank3nst3in's Avatar
    I faced the same problem with runnign Turbo C++ on 32bit.
    @Badhon_raj bhaia, turbo c++ er method ki ekhane kaj korbe??
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • Generic Backlit
      • Rapoo Vpro
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    Quote Originally Posted by Frank3nst3in View Post
    you just mention the method. I will give it a try.
      • MSI 760GM-P33
      • ASUS VX229H 21.5
      • Windows 8.1
      • 64 KBps
    Code:
    http://blog.bestsoftware4download.com/2010/02/how-to-install-turbo-c-on-windows-7-64bit/
    Code:
     1. Download and dosbox.
    2. Download and extract turbo c++
    3. Configure dosbox according to turbo c++ folder location.
    Turbo C++ installation :S
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • Generic Backlit
      • Rapoo Vpro
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    doesn't work. Thats sad.
    • Mahfuz's Gadgets
      • Asus 9600GT 512MB
      • Asus ML239H 23'' IPS Panel
      • Never Interested :-/
      • Asus 18X DVD RW
      • RahimAfrooz 1000VA
      • Not half-bad.
      • 30KBps
      • 7KBps
    Mahfuz's Avatar
    May 2010
    মনে নাই
    Use VMWare. Its basically a virtual machine that let you run numerous types of host OS within your primary OS by using processor's Virtualization technology. In your case, since this ancient soft is from win98 era, to make the soft runnable with VMWare you'll need to install the host OS as either 98/Millennium (As much as I'm concerned, these two OS have very few minor modification in both Kernel and User level thereby, hopefully there won't be any compatibility issue if you install Millenium instead of 98).
    At first VMWare might seems to be a bit of complicated but it's not that hard once you get used to it. The amazing part is, it's perfectly safe in spite of having many tremendous options. I usually recommend this when I find someone want to try linux distros without manipulating HDD partition or something like this.
    By the way, if you happen to find Virtual Box instead of VMWare that will do too.
    Last edited by Mahfuz; January 30th, 2012 at 22:44. Reason: Adding some info that might be helpful ...
    can you send the application to me?(or any download link?) I would like to personaly give a try..
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • Generic Backlit
      • Rapoo Vpro
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    Thanks bro, but it just won't work. Here is the screenshot of DOSbox 0.74. It says " This program requires microsoft windows" .
    virtualbox. Ok I am giving it a try in my desktop. If it works, then bye bye 32bit.
    Yes VMware would be the best solution
    I have 3 virtual OSes running off VMware.
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • Generic Backlit
      • Rapoo Vpro
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    Quote Originally Posted by EviL AnGeL View Post
    Alright, downloading virtualbox now. I'll install windows xp sp2. Question is, is there any chance of GPU driver related difficulties? If I can see everything on the screen , it'll be just fine. So, do you have any experience with XP as a guest OS? share plz.
    Try VMware, Virtualbox is foul.
    hmmm. Then try vmware workstation. It is better than virtual box.
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • Generic Backlit
      • Rapoo Vpro
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    Alright guys my problem solved. Virtualbox diyei amar kaj 100% successful. & I am happy now. Thanks everyone.
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • Generic Backlit
      • Rapoo Vpro
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    Hey bro, is it possible to play games like fifa 98, nfs 2-3-4 if i use vmware instead of virtualbox?
  1. Replies: 0
    Last Post: June 16th, 2011, 18:56
  2. Replies: 25
    Last Post: June 14th, 2011, 12:49
  3. 64bit Operating System
    By abir in forum Software
    Last Post: June 24th, 2010, 14:17
  4. X-fi Titanium vista 64bit driver issue
    By Extreme Noob in forum Technical Support
    Last Post: May 23rd, 2010, 18:10
  5. Does anyone has Windows 7 64bit Beta?
    By arch.racd in forum Software
    Last Post: March 18th, 2009, 03:32
Page generated in 0.26397 seconds with 15 queries.
