Thread: problem with router
    • terrygr8_007's Gadgets
      • ASrock z77 extreme4
      • Transcend 2x4GB 1600BUS
      • Seagate Barracuda st 2TB
      • Sapphire HD7850 OC edition
      • built-in
      • CM GX650
      • Windows 7 Ultimate 64bit
    Default problem with router
    i bought the modem just 2 days back from UCC, Multiplan. model D-link DIR 842. it was worked perfectly for approximately 6 hours. then suddenly it stopped working. the ethernet cable is working just fine when i connect it to my desktop directly but whenever i connect my ethernet cable to the router it wont work.the light which blinks when the ethernet cable is connected to the WLAN port isnt blinking. i have reset the router, changed the ports, but nothing works. any help would be appreciated. do i need to change the router??
      • MSI MORTAR MAX B450
      • RYZEN R7 2700
      • 8X2 CORSAIR VENGEANCE 3200
      • 1 TB WDD BLUE , 128 GB RIPJAWS M.2 SSD
      • GALAX GTX 1660TI EX WHITE
      • SAMSUNG 943SWX
      • KZ ZSN PRO
      • GENERIC DELL
      • A4TECH GENERIC
      • COOLER MASTER B500
      • SPEED TECH ONLINE
      • 10mbps
      • 5mbps
    something like this happened with me 3 years ago with tplink router , i stopped it using like 6-7 hours then again tried with different channel and after that so far it never occurred anymore . I don't have any explanation how and why this happened but you can try that too and if this process doesn't work then claim your warranty
    • kaziishan's Gadgets
      • Asus Sabertooth Z97 Mark S
      • Intel Core i7-4790K (Thermaltake Frio OCK CPU Cooler)
      • 2x8GB Kingston HyperX Fury White DDR3-1866
      • 240GB Zotac ZTSSD-A5P Premium, 1TB Toshiba (x2 RAID 1), 2TB Toshiba (x2)
      • Sapphire Nitro+ RX 480 4GB OC (Core:1390MHz, Memory:2000MHz)
      • LG 22MP68VQ-P 21.5" FHD IPS FreeSync 75Hz, ViewSonic VX2263S 21.5" FHD IPS 60Hz
      • Creative SBS A35
      • FL-ESports Mechanical Armor
      • Mad Catz R.A.T.3 Titanfall Edition
      • Corsair RM1000 80+ Gold
      • PNY Turbo 3.0 64GB USB Flash Drive (R:105MBps, W: 58MBps)
      • Prolink 1200VA
      • Windows 10 Pro
      • Thermaltake Suppressor F51 Case
      • Link3 Technologies
      • 8mbps
      • 8mbps
    kaziishan's Avatar
    Oct 2015
    Same thing happened when I first attached a specific broadband connection to my TP-Link router. It was working well with Banglalion USB modem, working well with Qubee USB modem, working well with Link3 broadband connection but whenever I attached my area's super local broadband, no connection. It wasn't even detecting the connection let alone any internet.
    However, when I connected the broadband connection to my PC directly, it was working fine. After 2 days of tinkering and complaining, I thought my router was done for (though it was working fine with other internet connection). Then, I turned it off for couple of days, attached it again, voila! It was working. And, I have not had a problem since. How, Why and What happened is beyond me though.
    Any of the meme/quote I post here on this forum is a "দেশ ও দশের সম্পত্তি"... Download it, Edit it, Share it, Put Your Name on it...I will not mind as long as it is Legal and does not convey any Illegal Message...
      • built-in
      • CM GX650
    Quote Originally Posted by Asif_Z View Post
    Have no experience with D-Link router, But I would recommend you to find and change the mtu value to 1400
    whats mtu value?
    Quote Originally Posted by kaziishan View Post
    okay...i'll turn it on tomorrow and see what happens -_-
      • Creative SBS A35
      • Prolink 1200VA
      • Windows 10 Pro
      • 8mbps
      • 8mbps
    kaziishan's Avatar
    Oct 2015
    Quote Originally Posted by terrygr8_007 View Post
    whats mtu value?
    • NahyaN's Gadgets
      • MSI Z490 TOMAHAWK/ LIAN LI LANCOOL II MESH
      • INTEL CORE-i7 10700/ EK-240 D-RGB AIO
      • CORSAIR VENGEANCE LPX (16GB X 2) 3200MHZ CL-16
      • SAMSUNG 970 EVO PLUS 250 GB/ SAMSUNG 860 EVO 1TB
      • MSI VENTUS 3X RTX 3070 OC
      • ASUS VG259Q 144HZ/ BENQ GW2480
      • AudioTechnica ATH-M40X
      • COOLERMASTER MASTERKEYS S CHERRY MX BLUE PBT
      • RAZER DEATHADDER V2
      • XBox 360 Controller
      • ANTEC HCG 650W
      • TecnoWare 2KVA/1800W Online UPS
      • ReLive
      • RACE ONLINE
      • ~40 Mbps
      • ~40 Mbps
    NahyaN's Avatar
    Feb 2009
    OK, I can share some experience regarding a similar issue.
    I too did not see the WAN port blinking when I connected the ISP's ethernet cable into the wan port of my router. But again, the ethernet cable would sometimes work on my pc and sometimes it would not.
    I contacted my ISP about this, they came with their own netbooks and cable testers and verified that the cable was at fault. The power that passes through the ethernet cable was not consistent (or something, they explained it to me that way). In an hour, they changed my ethernet cable and everything was working as before both on pc and router.
    TL;DR: Ask your ISP to check your Ethernet cable and replace it if necessary.
    Edit: OP are you having issues with your WIFI or the fact that your router doesn't pick up the WAN connection in the first place?
      • built-in
      • CM GX650
    so i went to UCC and they replaced the router. and here's the new problem...i cant enter setup. i have tried to do wireless setup, but my cell phone cant find the wi-fi signal. and when i connect it via the ethernet cable my desktop connects to internet directly and wont go into setup page.
    Quote Originally Posted by NahyaN View Post
    the first router didnt pick up the WAN connection and the new replacement is having issues with wifi
    also i cant reset my router. :'(
      • Creative SBS A35
      • Prolink 1200VA
      • Windows 10 Pro
      • 8mbps
      • 8mbps
    kaziishan's Avatar
    Oct 2015
    Why? No reset button?
      • built-in
      • CM GX650
    there is a reset button. i have pressed it for more than 10 seconds. but still it has the same problem.i cant enter router setup. i cant even use the mobile app to setup because my mobile cant identify the wi-fi signal
Page generated in 0.22270 seconds with 14 queries.
