Thread: Need Help with OpenVPN
    Default Need Help with OpenVPN
    Ok, I've got the VPN server running but on the client end when i try to connect I keep getting this error
    Code:
    Tue Jan 24 04:04:53 2012 OpenVPN 2.2.0 Win32-MSVC++ [SSL] [LZO2] built on Apr 26 2011
    Tue Jan 24 04:04:53 2012 IMPORTANT: OpenVPN's default port number is now 1194, based on an official port number assignment by IANA.  OpenVPN 2.0-beta16 and earlier used 5000 as the default port.
    Tue Jan 24 04:04:53 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
    Tue Jan 24 04:04:53 2012 ******* WARNING *******: null cipher specified, no encryption will be used
    Tue Jan 24 04:04:53 2012 LZO compression initialized
    Tue Jan 24 04:04:53 2012 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
    Tue Jan 24 04:04:53 2012 Socket Buffers: R=[8192->8192] S=[8192->8192]
    Tue Jan 24 04:04:53 2012 Data Channel MTU parms [ L:1558 D:1450 EF:26 EB:135 ET:32 EL:0 AF:14/26 ]
    Tue Jan 24 04:04:53 2012 Local Options hash (VER=V4): '5dc1b6ca'
    Tue Jan 24 04:04:53 2012 Expected Remote Options hash (VER=V4): '38390689'
    Tue Jan 24 04:04:53 2012 UDPv4 link local (bound): [undef]:1194
    Tue Jan 24 04:04:53 2012 UDPv4 link remote: 192.168.1.150:1194
    Tue Jan 24 04:04:53 2012 TLS Error: Unroutable control packet received from 192.168.1.150:1194 (si=3 op=P_CONTROL_V1)
    Tue Jan 24 04:04:55 2012 TLS Error: Unroutable control packet received from 192.168.1.150:1194 (si=3 op=P_CONTROL_V1)
    Tue Jan 24 04:04:58 2012 TLS Error: Unroutable control packet received from 192.168.1.150:1194 (si=3 op=P_CONTROL_V1)
    Tue Jan 24 04:04:59 2012 TLS Error: Unroutable control packet received from 192.168.1.150:1194 (si=3 op=P_ACK_V1)
    Tue Jan 24 04:05:00 2012 TLS Error: Unroutable control packet received from 192.168.1.150:1194 (si=3 op=P_CONTROL_V1)
    Tue Jan 24 04:05:02 2012 TLS Error: Unroutable control packet received from 192.168.1.150:1194 (si=3 op=P_CONTROL_V1)
    Tue Jan 24 04:05:04 2012 TLS Error: Unroutable control packet received from 192.168.1.150:1194 (si=3 op=P_CONTROL_V1)
    Tue Jan 24 04:05:05 2012 TLS Error: Unroutable control packet received from 192.168.1.150:1194 (si=3 op=P_CONTROL_V1)
    Tue Jan 24 04:05:07 2012 TLS Error: Unroutable control packet received from 192.168.1.150:1194 (si=3 op=P_CONTROL_V1)
    I googled it up alot & results turn up that its a time sync issue. But both of the PCs time is updated by internet time servers. What possibly could be the problem & the fix?
    Add a route or two manually, your vpn server does not know how to route a packet to 192.168.1.0/24
    Quote Originally Posted by Wintereise View Post
    U mean in the router right? I'm a bit confused there See : >
    What should i input where?
    Here : 192.168.1.150 is the IP of the pc which its hosted in.
    My Main PC ip is 192.168.1.100
    VPN ip line is 10.10.0.x
    I have no idea how routing works in Windows. Join #OpenVPN (Or ##Openvpn) on Freenode and ask there @ http://webchat.freenode.net/
Page generated in 0.16139 seconds with 14 queries.
