Thermaltake Thunderblade Blue LED Fan
http://www.thermaltake.com/products-...?id=C_00001472
P/N
AF0032 Fan Dimension 120 x 120 x 25 mm Started Voltage ≦9V Rated Voltage 12V Power Input 3.6W(Max) Rated Current 0.30A Fan Speed 1800±10%R.P.M. Max. Air Flow 70.2CFM Max. Air Pressure 2.41MM-H2O Noise 31.7 dBA Bearing Type Sleeve Life Expectation 30000hrs,25°C Connector 4 Pin Weight 112.5g
Box, accessories, manual, screws, all available.
Price: 500/= only
Contact: 01833331668
