kaziishan : So
i5 it is then. I need to think about overclocking more, but I am planning to get suitable motherboard for Overclocking. And, about the bang for bucks; that much is certain; what I wanted to know is, if it's worth the cost. Meaning, is 6600k much better than 6500 to justify 4k price increase? Also, as you mentioned, if I need a dedicated cooler for 6600k, then it would cost a bit more. Is it worth it?
I am currently using Asus VX229H monitor and I plan to use that with the new setup as well. I am planning to get the new PC by the 2nd half of January.
