Results 1 to 20 of 30
Thread: Strange problem
    • Cpt.Mactavish's Gadgets
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Cpu:5.4,Gpu:7.1,HDD:5.9
      • Happy with it!
    Cpt.Mactavish's Avatar
    Default Strange problem
    Ekta strange problem.jokhon pc start kori tokhon thikmoto chole.then kono karon,jamon driver installation r jonno restart nilo,tarpor shobkisui thikmoto choltese rear fan,cpu fan,gpu fan etc.but monitor e kono data ashtese na!tapor power off kore 2-5 minute por on korle abar shob kisu thikmotoi chole.
    Ek vaiya suggestion onujai mobo bios update korsilam.tarpor shobkisui normally choltesilo.aj hothath abar shei prblm dekha dise.akhon majhe majhe shob thik moto choltese or not!
    My spec:
    1.dg31pr
    2.c2d
    3.2gb ram(in 2 slot)
    4.hd 6670
    any help?it's urgent.i'm really scared.
    ---------- Post added January 18th, 2012 at 07:59 ---------- Previous post was January 17th, 2012 at 22:23 ----------
    Heellpp!it won't even run.cpu choltese but monitor e kisu ashtese na!
    • codename5302's Gadgets
      • Gigabyte X99-UD5 Wifi
      • Zotac 980Ti Amp Extreme
      • Fiio Andes E07K
      • Corsair RM850
      • 2 * Prollink 1200VA
      • Windows 7 64Bit
      • It works!!
      • 154
    codename5302's Avatar
    check your grafix card on different pc.
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    grafix card onno pc te try korsi.working flawlessly.tasara geforce 6200 ar intel igd diyo try korsilam.but the problem xists
    @Cpt.Mactavish the problem u r facing is called cold boot issue(may be), this was a common problem in legacy Asus and AsRock Boards, coldboot happens mainly when ur mobo detects any change in u BIOS tries to reconfigure/reset to defaults but unfortunately hangs and thus the screen remains blank, so whenever this happens-
    1. go to BIOS load optimized defaults, F10/save reboot,
    2. Mobo'r battery change kore dekhte paren,
    3. cold boot hole simply reboot the pc(by pressing reboot button)
    Let me if this helps..
    I bet it's the PSU, can't rule out the cold boot either but if that was the case then you would've faced it at start up too, not only while restarting, frankly speaking, I tried using dedicated PhysX (A 9500GT) with a HD 4850 and faced the same issue, upon restart the motherboard would get into a boot loop, then I reassembled the whole pc from scratch (tried re-installing the gpu and it didn't help) and the issue was gone. So you've a lot of testing to do.
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    Quote Originally Posted by musvi View Post
    @Cpt.Mactavish the problem u r facing is called cold boot issue(may be), this was a common problem in legacy Asus and AsRock Boards, coldboot happens mainly when ur mobo detects any change in u BIOS tries to reconfigure/reset to defaults but unfortunately hangs and thus the screen remains blank, so whenever this happens-1. go to BIOS load optimized defaults, F10/save reboot,2. Mobo'r battery change kore dekhte paren,3. cold boot hole simply reboot the pc(by pressing reboot button)Let me if this helps..
    1&3 works!but,shompurno na.bios downgrade kore previous version install kora ki uchit?
    • Reznov's Gadgets
      • Gigabyte G31M-ES2C
      • Intel Core 2 Duo E8400
      • 3GB DDR2 800mhz (2GB+1GB)
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Adata UV150 (16 GB USB3)
      • windows 7 Ultimate 64bit
      • Mobile ISP
      • Vashae Prokasher Ojoggo
    Reznov's Avatar
    Dinajpur
    Ekta strange problem.jokhon pc start kori tokhon thikmoto chole.then kono karon,jamon driver installation r jonno restart nilo,tarpor shobkisui thikmoto choltese rear fan,cpu fan,gpu fan etc.but monitor e kono data ashtese na!tapor power off kore 2-5 minute por on korle abar shob kisu thikmotoi chole.Ek vaiya suggestion onujai mobo bios update korsilam.tarpor shobkisui normally choltesilo.aj hothath abar shei prblm dekha dise.akhon majhe majhe shob thik moto choltese or not!My spec:1.dg31pr2.c2d3.2gb ram(in 2 slot)4.hd 6670any help?it's urgent.i'm really scared.---------- Post added January 18th, 2012 at 07:59 ---------- Previous post was January 17th, 2012 at 22:23 ----------Heellpp!it won't even run.cpu choltese but monitor e kisu ashtese na!
    try with a different monitor and a different cable. Changing the cable helped me once. This might be helpful
    Bhai different 1ta Power supply try kore dekhen.
    if 1 and 3 works for u, then we can assume its coldboot issue, and if its really so, its not a major problem, thing u have to do is to restart the system whenever it occurs,
    u might install the older bios to check weather the problem persists or not
    but what @K' said also very important, if ur psu can't cope up with ur system, this might also happen, and in that case ur system is in fatal risk,
    so now u have to troubleshoot this matter and determine weather its psu or just coldboot or something else,
    Hint- to check weather its psu related or not u can check ur PSU with OCCT PSU test, but beware this is a very risky stress test as some weak components might fail during this test and u need adequate cooling system to complete this test..
    Boss Pc er full configuration ta den, tahole problem analyse korte shubidha hobe, jodi apner mobo P67/Z68 hoy tahole cold boot issue er chance higher, specially Z68.
    Quote Originally Posted by K' View Post
    Strange problem
    My spec:
    1.dg31pr
    2.c2d
    4.hd 6670
    this..
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    Quote Originally Posted by Dark_wave View Post
    korsilam vaiya.but no change
    surely its not monitor cable related, r jodi hoto then blank screen every now and then hoto not specifically when i restarting pc..
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    if 1 and 3 works for u, then we can assume its coldboot issue, and if its really so, its not a major problem, thing u have to do is to restart the system whenever it occurs,u might install the older bios to check weather the problem persists or notbut what @K' said also very important, if ur psu can't cope up with ur system, this might also happen, and in that case ur system is in fatal risk,so now u have to troubleshoot this matter and determine weather its psu or just coldboot or something else,Hint- to check weather its psu related or not u can check ur PSU with OCCT PSU test, but beware this is a very risky stress test as some weak components might fail during this test and u need adequate cooling system to complete this test..
    installing older bios.0052.mine is now 0071.amar ek vai o same problm face korsilo onar mobo g41.uni ram r slot change kore diten.tate thik hoito.amar khetreo eta kisudin kaj korsilo.now it won't work anymore!slot change korte korte slot loose hoye jaoar pothe!
    • Banglavai's Gadgets
      • Asus Maximus VI Hero
      • Core i5 4670k
      • G-Skill Ripjaws X 2X 8GB 1600
      • 2X Samsung EVO 840 240GB
      • Gigabyte GTX 770 Windforce OC
      • Asus MX279H 27 inch
      • ROG SupremeFX 8-Channel High Definition Audio
      • Bose 301 Direct / Sennheiser Momentum 2.0
      • Logitech G105
      • Logitech G5
      • Xbox 360(usb wired)
      • Fractral Design 650 watt 80 plus gold
      • No need at all
      • Windows 8.1 64bit Professional
      • 100 Mbps
      • 30 Mbps
      • 146
    Banglavai's Avatar
    Oct 2009
    Helsinki, Finland
    According to Romulus vai I am 95% sure It's PSU problem.I had experienced the same problem when i switched to a better PSU(though it was faulty one). Change the PSU first and I think everything will go fine.
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    the prblm seems to be solved!thanx.aro kisukkhon test kore dekhi.but why it occured?
    DG31PR? Bios prob hobar chance ache, Stock bios a windows 7 theke restart dile amar intel screen a eshe boshe thakto, latest bios install dewar por problem solve hoye chilo, ar vaiya apner specs kintu full na, PSU er model ki ta kintu mention koren nai, apni jodi again problem face koren then ar1ta different PSU use kore dekhben, cold boot issue apner khetre projojjo na.
    how?
    The message you have entered is too short. Please lengthen your message to at least 5 characters.
    @musvi vai, OCCT diye stress test kore apni PSU er load capability and stability test parben, kintu onek PSU ache jeta rail a problem thakar karone PC restart/startup ei problem kore, kintu 1bar chalu hoye gele ar problem korena until pc restart/shut down dewa hoy, j generic PSU ta amar mobo kheye dise oitar ei habit chilo, XFX er 6 pin less 9800GT lagano thakle PSU ta windows e boot korar age/startup er shurute restart/display chere dito, kintu 1bar windows e dhuke jabar por fully stable thakto, restart dawa matroi same bepar.. so OCCT diye PSU diagnose kora jayna at all times.. Ami amar generic PSU tay X diye rakchilam but amar Branded PSU ta sell kore debar por tarahuray ar kheyal korini, folafol within two nights mobo assassinated!
    On topic: vai apner bios prob hobar chance 70% DG31PR er ei problem common, PSU problem hobar chance 15%, Ram 2ta ki same brand er? Jodi problem persist kore ar ram 2ta jodi different vendor er hoy, 1ta Ram khule pc chaliye dekhen, intel board ram er bepare khub choosey, jara intel er purano mobo gula use korsen tara janen j intel er mobo gula ki rokom pain j dei memory different vendor/fully support na korle.
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    bro psu to generic!ar ram r moddhe ekta dynet and another one is of trancend.both are at 667mhz.cpu c2d e8400.250gb hdd,free 1.2gb(total hdd).sapphire hd 6670.that's all
    ---------- Post added at 14:32 ---------- Previous post was at 14:32 ----------
    how?The message you have entered is too short. Please lengthen your message to at least 5 characters.
    bios downgrade!
    ---------- Post added at 14:35 ---------- Previous post was at 14:32 ----------
    @musvi vai, OCCT diye stress test kore apni PSU er load capability and stability test parben, kintu onek PSU ache jeta rail a problem thakar karone PC restart/startup ei problem kore, kintu 1bar chalu hoye gele ar problem korena until pc restart/shut down dewa hoy, j generic PSU ta amar mobo kheye dise oitar ei habit chilo, XFX er 6 pin less 9800GT lagano thakle PSU ta windows e boot korar age/startup er shurute restart/display chere dito, kintu 1bar windows e dhuke jabar por fully stable thakto, restart dawa matroi same bepar.. so OCCT diye PSU diagnose kora jayna at all times.. Ami amar generic PSU tay X diye rakchilam but amar Branded PSU ta sell kore debar por tarahuray ar kheyal korini, folafol within two nights mobo assassinated!On topic: vai apner bios prob hobar chance 70% DG31PR er ei problem common, PSU problem hobar chance 15%, Ram 2ta ki same brand er? Jodi problem persist kore ar ram 2ta jodi different vendor er hoy, 1ta Ram khule pc chaliye dekhen, intel board ram er bepare khub choosey, jara intel er purano mobo gula use korsen tara janen j intel er mobo gula ki rokom pain j dei memory different vendor/fully support na korle.
    yap bro different brand!
  1. Strange problem in win 7
    By Speed in forum Technical Support
    Last Post: December 8th, 2014, 01:39
  2. FIFA 11 fifa 11 strange problem
    By @nonymous™ in forum FIFA 11
    Last Post: December 12th, 2010, 17:03
  3. Strange problem!!!!!
    By shaikh_imtiaj in forum Technical Support
    Last Post: December 10th, 2010, 02:51
  4. Strange Pc Problem
    By D3FC0N in forum Technical Support
    Last Post: October 11th, 2010, 18:12
  5. strange problem....any solution?
    By saadbillah in forum Older NFS Games
    Last Post: November 16th, 2008, 22:38
Page generated in 0.30902 seconds with 14 queries.
