Thread: Laptop System Fan not running
    • Iskander's Gadgets
      • MSI 760GM-P23 (FX)
      • AMD FX-6300 3.5GHz
      • 8(2x4GB) Corsair Value DDR3 1600MHz
      • WD Blue 1TB
      • Zotac GTX 1050 Mini
      • ViewSonic VX2270Smh-LED
      • Cooler Master G550M 80PLUS Bronze
      • 500GB Samisung External HDD
      • Prolink 650VA
      • Windows 10 Pro, Linux Mint (Dual Boot)
      • Asianet BD
      • 6Mbps
      • 6Mbps
    Iskander's Avatar
    Aug 2015
    Default Laptop System Fan not running
    Yesterday my laptop screen goes black in the middle of my work, I thought maybe the battery is drained,so after recharged for a while when I turn on my laptop, the screen shows "System Fan (90B) error". After googling the problem I found out that my system fan(CPU) not running.
    SpeedFan 4.52 shows my CPU fan 0 rpm
    At first, I thought maybe the fan is stuck, so I update the BIOS (as followed by youtube solution). But nothing changed.
    Model: HP 430
      • MSI MORTAR MAX B450
      • RYZEN R7 2700
      • 8X2 CORSAIR VENGEANCE 3200
      • 1 TB WDD BLUE , 128 GB RIPJAWS M.2 SSD
      • GALAX GTX 1660TI EX WHITE
      • SAMSUNG 943SWX
      • KZ ZSN PRO
      • GENERIC DELL
      • A4TECH GENERIC
      • COOLER MASTER B500
      • SPEED TECH ONLINE
      • 10mbps
      • 5mbps
    may be your laptop fan is cram on the ocean of dust which means you need to clean inside as fast as possible , google some laptop blowers or something or take to any nearby laptop repair shop to clean it up
      • WD Blue 1TB
      • Prolink 650VA
      • Asianet BD
      • 6Mbps
      • 6Mbps
    Iskander's Avatar
    Aug 2015
    Sorry, I didn't mention that. Already cleaned the fan with a blower. Saw some dust blown out from ventilation. Even opened my keyboard to confirm that fan is properly cleaned.
    Now my question is "My fan Died???"
    Is there any way to replace it.
    Milwaukee
    Quote Originally Posted by Iskander View Post
    Watch this video first.
    So, unless your fan comically starts spinning like it did at 3:45, you would need to replace it. Take it to a repair shop. It would be cheap repair, don't worry.
      • WD Blue 1TB
      • Prolink 650VA
      • Asianet BD
      • 6Mbps
      • 6Mbps
    Iskander's Avatar
    Aug 2015
    Well the same miracle{¤¤¤¤} happens when I disassembly the whole parts like this YouTuber (Mehdi). Though my laptop runs fine (even more cooled), but confused. Why the fan was so arrogant even after cleaned up -____-
    Thanks for the video @Swapnil
Page generated in 0.12005 seconds with 13 queries.
