Thread: Need help about converter
    • Ratul107's Gadgets
      • gigabyte h61M s2p
      • core i5 2400 3.1 ghz
      • 2x2gb ddr3 1333mhz
      • 1TB + 1TB ext
      • Sapphire R9 280X
      • samsung SA300 20" 1600X900
      • generic
      • generic
      • generic
      • thermaltake smart power 550w
      • 1000va
      • win 7 64 bit ultimate edition
      • Cpu 7.4 gpu 7.8 ram 7.6 hdd 5.9
      • it's a mixed bag ... but gaming performance is satisfactory
      • smilebd
      • ~240kB/s
    Ratul107's Avatar
    Default Need help about converter
    I was using a molex converter that came with my hd5830. I lost that converter. Today i got a new converter but its not working , i dont get the display. Are all converters of same type? The converter seems to lack 2 pins each above and under the larger pin , assuming from the gpu's port . So is there a different converter or the converter is faulty? Plz help guys.
    Try a different molex converter, as the cheap converters found in the shops (not the bundled one that came with the card's packaging) are known to be troublesome, and the connector should have one blank spot where there's an empty space for a pin to fit in, not two., but that's just my opinion.
      • gigabyte h61M s2p
      • 1TB + 1TB ext
      • Sapphire R9 280X
      • generic
      • generic
      • generic
      • 1000va
      • smilebd
      • ~240kB/s
    Ratul107's Avatar
    So from where do i get the converte?
      • ASROCK h81-GL
      • Core i3 4130 @3.40ghz
      • WD 1tb BLUE
      • Radeon r7 260x (2gb) GDDR5
      • Hp 18.5"
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    A place Where U Belong >:/
    try multiplan or idb...
      • gigabyte h61M s2p
      • 1TB + 1TB ext
      • Sapphire R9 280X
      • generic
      • generic
      • generic
      • 1000va
      • smilebd
      • ~240kB/s
    Ratul107's Avatar
    I got it from multiplan . Maybe its faulty
  1. DP to HDMI Converter
    By k1ngdom in forum Help - PC Buying
    Last Post: November 2nd, 2011, 12:33
  2. need swf to pdf converter
    By ronycmc in forum Software
    Last Post: September 22nd, 2010, 21:20
  3. pdf to word converter
    By soul in forum Software
    Last Post: September 9th, 2010, 23:48
  4. Video Converter Needed
    By ScS :: XTR in forum Software
    Last Post: March 24th, 2009, 19:02
  5. game port r usb converter
    By ЯV●@spret in forum Others PC Hardware
    Last Post: May 24th, 2008, 01:27
Page generated in 0.17433 seconds with 14 queries.
