Thread: graphics card fan speed curve not working MSI afterburner
      • Asus z170p || MSI B450M Mortar Max mATX
      • i7 6700k || Ryzen 7 3700X cooler wraith prism
      • 2 x 8gb Ripjaws 3200C16D 16GVKB || 2x 16gb TridentZ Neo 3200 cl16
      • Toshiba 2tb + WD 500gb blue || Samsung Evo 850 250gb + Toshiba 4TB black 7200rpm
      • Zotac 1060 6gb Amp Sapphire r7 260x 1gb || EVGA 2060 6gb SC Gaming
      • Asus vx229h Samsung 21.5" S22A300B || BenQ PD2700Q 27" 1440p
      • Xonar dgx ||
      • Microlab 223 AltecLansing VS2621 || Audio Technica m40
      • ROYAL KLUDGE Sink87G RGB Wireless mechanical brown switches
      • logitech g602 wireless || logitech g703 wireless
      • Adata HM 850w || Gigabyte Aorus p850w
      • CASING Phantom 240 red/black || Inter Tech x608 mATX mirror
      • Power guard 1200va ||
    Default graphics card fan speed curve not working MSI afterburner
    recently bought sapphire 260x 1gb. win10 x64
    graphics card fan speed not increasing at all. stuck at like 50% or less. using msi afterburner custom fan curve. even when using default curve its not increasing.
    this problem showed up for last 2 days apparently.. before that i didnt see this problem.
    afterburner latest version. driver version 16.4.1... i tried 16.3.2 also...
    while using sapphire trixx the fan curve working properly it seems... but i havent use for much so i cant confirm whether it will work forver properly.
    • kaziishan's Gadgets
      • Asus Sabertooth Z97 Mark S
      • Intel Core i7-4790K (Thermaltake Frio OCK CPU Cooler)
      • 2x8GB Kingston HyperX Fury White DDR3-1866
      • 240GB Zotac ZTSSD-A5P Premium, 1TB Toshiba (x2 RAID 1), 2TB Toshiba (x2)
      • Sapphire Nitro+ RX 480 4GB OC (Core:1390MHz, Memory:2000MHz)
      • LG 22MP68VQ-P 21.5" FHD IPS FreeSync 75Hz, ViewSonic VX2263S 21.5" FHD IPS 60Hz
      • Creative SBS A35
      • FL-ESports Mechanical Armor
      • Mad Catz R.A.T.3 Titanfall Edition
      • Corsair RM1000 80+ Gold
      • PNY Turbo 3.0 64GB USB Flash Drive (R:105MBps, W: 58MBps)
      • Prolink 1200VA
      • Windows 10 Pro
      • Thermaltake Suppressor F51 Case
      • Link3 Technologies
      • 8mbps
      • 8mbps
    kaziishan's Avatar
    Oct 2015
    Quote Originally Posted by furiousTaher View Post
    I have faced almost similar issue with afterburner. Custom Fan Profile did not work after starting the PC, though afterburner kept showing that it is selected. I had to manually re-select the profile to make it work. However, after a clean installation of afterburner, the problem seems to be solved.
    • Sybaris Caesar's Gadgets
      • MSI Arsenal Gaming B450 Tomahawk
      • AMD Ryzen 5 3600
      • Team T-Force Delta RGB 2x8GB 3200CL16
      • WD Black WD1003FZEX 1TB + Crucial MX500 500GB
      • Colorful GeForce RTX 2060 6G V2
      • LG 22MP68VQ-P 22" 75hz IPS
      • Onboard Realtek ALC892
      • HyperX Cloud X | iVOOMi iVO-169SUFBT 2.1
      • Fantech MK871 RGB TKL Outemu Blue mechanical keyboard
      • Logitech G402 | Logitech G102
      • Xbox 360 Wireless
      • Cooler Master G550M
      • Windows 10 Enterprise x64 1903
    Sybaris Caesar's Avatar
    Nowy Warsaw
    amar gtx 560 ti e 75% e stuck chhilo. pore dekha gesilo je stock bios e 75% e lock kora. so nibitor ar nvflash dia bios edit kore flash kora lagsilo. but not in this case I think. who on their right mind would lock at 50%?
      • Xonar dgx ||
    seems like the main problem with msi afburner for my card is the fan speed at 0C. if i set 0C 75% fan speed then fan will get stuck at 75% all the time.
    i had to ditch aftter burner completely and it seems working now.... with trixxx
      • Xonar dgx ||
    damn... even my 280x showing problem in another pc with msi afterburner fan curve.... whats wrong with windows 10? -_- anybody else having problem with windows 10 fan curve (msi afterburner)?
    Because Windows 10 is Windows XP v2 with degraded UI graphics. Lots of problems, incompabilities and so on. You have to wait for updates and maybe then might solve the issue.
    By the by, may I ask why you bought R9 260x when you got 280x ?
      • Xonar dgx ||
    i have 2 pcs
    actually its my brothers pc
      • AMD Ryzen 5 3600
      • Xbox 360 Wireless
    Nowy Warsaw
    i have 2 pcs
    so 3 pcs?
      • Xonar dgx ||
Page generated in 0.20846 seconds with 13 queries.
