Results 1 to 8 of 8
Thread: Need help in Scanner
    Default Need help in Scanner
    I am interested in purchasing good scanner my budget is 5k may increase it if needed. So I need some suggestion and help from you guys which brand and model to purchase.
    Quote Originally Posted by Set View Post
    Canon Lide series should be fine.
    Milwaukee
    Get a Cannon LiDE series, and if you are going to scan documents/text/books choose the one with fastest scan speed in your budget and you would be happy with it for a long time.
    Sure I have used the 110 model and it was awesome for the price.
    Any shop you guys would recommend
    Don't like ryans that's all I can say.
    Milwaukee
    Does J.A.N Associates (http://www.jan-bd.com/) still sell retail? If yes buy directly from them. They are the importers of Cannon in Bangladesh.
Page generated in 0.18584 seconds with 13 queries.
