asus z170p. updated to latest bios...
cm 212 hyperx
Whenever I try to boot my new asus pc it shows 'cpu fan error, connect the cpu fan properly or set the cpu fan speed low limit. press f1 to enter bios'.
In addition to that when I enter bios it shows my cpu fan is not running at all, but when in reality my cpu fan is spinning properly.
I made sure my cpu fan connector is placed properly with motherboard cpu 4 pins...
I already set fan speed low limit to ignore. it still shows the problem.
finally I had to set cpu fan speed monitoring to disabled otherwise I could not boot.
after searching the internet seems like this a common problem with asus mobo? But the thing is even if i use speed fan or open hardware monitor those software does not show my cpu fan. which is astonishing.
also I noticed these problem started after i updated uefibios last week. though i dont want to revert back to pre historic uefibios.
help please. thnx in advance
