Hello BG members.My r7 360 nitro is reaching 90s+ while hardcore gaming for a long period.On furmark it corsses 95.Is it possible to claim warranty for overheating issue?It was bought from Bismillah computer,Multiplan.What should i do?![]()
If the temp shoots up really fast then u have dry heat paste or loose heatsink. Whats the brand name and model of ur card?
Group for new/old cyclist !
Oiginal games/software/app available at reasonable price
Selling iTune gift card,Google Play, Steam Wallet Card, Facebook Credits
Facebook Page - Join>Like>Share=discounts!
Steam ID: minitt
It doesn't shoot right away it does take some time 20-30mins in games nd 15+mins in furmark.Its from sapphire nitro edition...
On custom fan curve in games temp is around 80-82...on furmark 88(case opened and the gpu's fan in running at 100%).Isn't it a bit high?
Exactly what happened to my 6850 before dying. ^Apply thermal paste, wipe it fully clean and check for loose connections. If that does not fix it, I think you will have to RMA it.
Won't it break warranty?nd will any thermal paste do?should i contact the vendor/shop about it?will they do anything if i tell them or am i better off re -applying thermal paste?currently the thermal paste i have is the one tht comes free with coolermaster cpu coolers.....
if i know what i am talking about detaching cooler and applying thermal paste on chip dont void warranty but.... this is bangladesh so you better go to shopkeeper first... i think
Talked with the shop-keeper....Told me to take the gpu to the shop.....Let's see..Thanks all...
The gpu is replaced....Thanks everyone......
Steam ID: minitt
