Results 1 to 2 of 2
Thread: Broadcam's first Gigabit-Speed 802.11 ac Chips
    • Trave160's Gadgets
      • MSI B350M Mortar AM4
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • 3TB Western Digital red
      • ASUS Strix GTX 960 4G
      • Dell S2216H 22 Inch monitor
      • Logitech Speaker
      • TtEsports Knucker
      • PS4 Dualshock 4 controller
      • Pendrive 4GB
      • NunuCom Ltd, Penus group
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    Default Broadcam's first Gigabit-Speed 802.11 ac Chips
    Broadcom introduces first gigabit-speed 802.11ac chips
    Broadcom is ushering in a new generation of Wi-Fi technology with the release of its first gigabit-speed 802.11ac chips. The company says the new chips are aimed at enabling higher-bandwidth services like HD movie streaming over wireless connections. They are up to three times faster, deliver 40 to 60 percent better range, and are up to six times more power efficient than similar 802.11n solutions.
    Broadcom is marketing the technology as "5G Wi-Fi," though it's unclear if the networking industry will adopt the same terminology to promote 802.11ac.
    Broadcom's family of 802.11ac chips cover everything from high-end routers and PCs to small USB dongles. The lineup is comprised by the BCM4360, BCM4352, BCM43526, and BCM43516. All of these chips share a number of common features, as detailed in the press release:
    • 80 MHz channel bandwidth that is 2 times wider than current 802.11n solutions
    • 256-QAM, a higher modulation scheme that increases data transfer efficiency
    • Transmit and receive beamforming (helps increase wireless range, penetration, and data rates)
    • Low Density Parity Check (LDPC) Codes
    • Space-Time Block Codes (STBC)
    The top tier BCM4360 supports the PCIe interface and uses a three-stream implementation, reaching as high as 1.3 Gbps of throughput. The BCM4352 and BCM43526 support PCIe and USB interfaces, respectively, and use a two-stream 802.11ac implementation that can reach up to 867Mbps. Lastly, the BCM43516 chip also supports USB interfaces, but uses a single-stream radio that can reach speeds of up to 433Mbps. By comparison, even multiple-stream 802.11n devices don't typically surpass 300Mbps.
    The Wi-Fi Alliance is not expected to formally ratify the 802.11ac specification until sometime around Q4 2012. However, much like it happened with the transition from 802.11g to 802.11n, users will be able to buy "pre-standard" hardware early in 2012 without worrying about compatibility issues when the standard is approved.
    According to Michael Hurlston, senior vice president and general manager of Broadcom's wireless LAN division, early products should be upgradable in the field to the final standard. "I'm confident that any changes to the spec beyond this point and before final ratification will be be window dressing, and relatively small [...] History is a very good guide, and we feel that history will repeat itself," he said.
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    minimum 3 years before we see this properly marketed and utilized
    Once more into the fray
    Into the last good fight I’ll ever know
    Live and die on this day
    Live and Die on this day
  1. Intel Ivy Bridge to release 25 Chips on April 8
    By Trave160 in forum Tech News
    Last Post: December 30th, 2011, 05:11
  2. Intel Releases 16 New Chips Over The Weekend
    By Arif69 in forum Tech News
    Last Post: September 11th, 2011, 23:27
  3. Replies: 7
    Last Post: September 3rd, 2011, 19:01
  4. Intel to retire old 45nm chips
    By Dee in forum Tech News
    Last Post: February 10th, 2011, 08:20
  5. Nvidia chips show underfill problems.
    By GiDDY_SOUL in forum GPU
    Last Post: December 27th, 2008, 14:31
Page generated in 0.15507 seconds with 14 queries.
