View Poll Results: Some Monitors
Voters
9. You may not vote on this poll
  • Samsung S22A300B
    4 44.44%
  • Benq V2220H
    1 11.11%
  • AOC E2243FW2K
    1 11.11%
  • Dell P2211H
    3 33.33%
Results 1 to 20 of 26
Thread: Help Me Buying LED Monitor 21.5"
    • Abdur Rafi's Gadgets
      • MSI P55A Fuzion Intel Motherboard
      • Intel Core i3 530 @ 2.93 GHz
      • Transcend 4GB KIT aXeRam DDR3 1600+ Mhz (8-8-8-24)
      • 660 GB
      • SAPPHIRE Radeon HD5570 1GB DDR3
      • BENQ B700A 17"
      • Logitech Stereo Headset H150
      • Logitech Media Keyboard MK200
      • Logitech Media Mice MK200
      • Tt Toughpower 600W
      • LITE-ON 24X DVD Writer Black SATA
      • SILICON POWER Touch 810 16GB Pen Drive
      • Windows 7 Ultimate 64Bit
      • City Net
      • 64 KB/s
      • 32 KB/s
    Abdur Rafi's Avatar
    Jun 2010
    Lightbulb Help Me Buying LED Monitor 21.5"
    Dear Friends,
    Please help me on buying LED monitor 21.5".
    Need urgent help.thx
    Budget: 16000
      • ASROCK h81-GL
      • Core i3 4130 @3.40ghz
      • WD 1tb BLUE
      • Radeon r7 260x (2gb) GDDR5
      • Hp 18.5"
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    A place Where U Belong >:/
    i wudn't vote for ne on the poll... I wud suggest u to buy a Philips 224el2sb which bits all these others..
    Here's the specs:
    Picture/Display
    •LCD panel type: TFT-LCD
    •Backlight type: W-LED system
    •Panel Size: 21.5 inch/54.6 cm
    •Aspect ratio: 16:9
    •Optimum resolution: 1920 x 1080 @ 60 Hz
    •Response time (typical): 5 ms
    •Brightness: 250 cd/m²
    •SmartContrast: 20,000,000:1
    •Pixel pitch: 0.248 x 0.248 mm
    •Viewing angle: 176º (H)/170º (V), @ C/R > 5
    •Picture enhancement: SmartImage Lite
    •Display colours: 16.7 M
    •Scanning Frequency: 30–83 kHz (H)/56–75 Hz (V)
    •sRGB
    Connectivity
    •Signal Input: VGA (Analogue), DVI-D (digital, HDCP), HDMI
    •Sync Input: Separate Sync, Sync on Green
    •Audio In/Out: Stereo Audio, PC audio-in, Earphone out (3.5 mm jack) x 1
    Convenience
    •Built-in Audio: 1.5 W x 2
    •User convenience: SmartImage lite, Input, Volume, Menu, Power On/Off
    •OSD Languages: English, French, German, Italian, Russian, Simplified Chinese, Spanish, Portuguese, Turkish
    •Other convenience: VESA mount (100 x 100 mm), Kensington lock
    •Plug and Play Compatibility: DDC/CI, Mac OS X, Windows 7 / Vista, sRGB
    Stand
    •Tilt: -5/+20 degree
    Power
    •On mode: 17 W (EnergyStar 5.0 test method)
    •Standby mode: <0.5 W
    •Off mode: < 0.5 W
    •Power LED indicator: Operation - White, Standby mode - White (flashing)
    •Power supply: Built-in, 100-240 VAC, 50/60 Hz
    Dimensions
    •Product with stand (mm): 505 x 484 x 249 mm
    •Product without stand (mm): 505 x 351 x 59 mm
    •Packaging in mm (W x H x D): 565 x 465 x 155 mm
    Weight
    •Product with stand (kg): 4.15 kg
    •Product without stand (kg): 3.65 kg
    •Product with packaging (kg): 6.00 kg
    Operating conditions
    •Temperature range (operation): 0°C to 40°C °C
    •Temperature range (storage): -20°C to 60°C °C
    •Relative humidity: 20–80% %
    •MTBF: 30,000 hour(s)
    Sustainability
    •Environmental and energy: RoHS, EPEAT Silver, EnergyStar 5.0
    •Recyclable packaging material: 100 %
    Compliance and standards
    •Regulatory Approvals: BSMI, CE Mark, FCC, Class B, GOST, UL/cUL
    Cabinet
    •Colour: Black/Black
    •Finish: Glossy
    ---------- Post added at 09:41 ---------- Previous post was at 09:39 ----------
    im usin it and its evn better than the ms228h... The led backlight is really bright so that the sun doesn't get into ur way
    U can shift from hdmi to dvi-d or vga on the fly (a unique feature)
    Price: 17k @computer source...
    • cyanid3's Gadgets
      • msi 760Gm p33
      • Amd Athlon x4-640
      • 4GB siliconpower DDR3
      • 540GB
      • SAPPHIRE HD 6770 1GB GDDR5
      • Philips 192EL2SB 18.5&quot;
      • Microlab 2.1
      • LOGIC waterproof + dustproof
      • A4tecH 2x
      • VINYSON
      • TT 500W
      • Liteon 24x Label Tag DVDRW
      • WIN 7 x86
      • goriber pc
      • LINK3
    cyanid3's Avatar
    Dec 2009
    West Panthapath.
    philips LED ftw!!!
    best part is , it has a flat back , and wall mount kora jae, epic led monitor imo.
    and its energy efficient than other choises you have,.
    • SadIkMahdI's Gadgets
      • Gigabyte B85M-D3H
      • Intel Core i5 4590 @ 3.30 GHz
      • 4x4GB G.SKILL Ripjaws Series 240-Pin DDR3 SDRAM 1600 Bus Desktop Memory
      • Western Digital WD10EZEX 1 TB | SanDisk 2.5&quot; 128GB SATA III Internal Solid State Drive
      • EVGA GeForce GTX 750 Ti FTW Edition with ACX Cooling
      • Samsung SB19B300B 18.5 LED
      • Built in Realtech HD
      • Altec Lansing VS2621 2:1 Channel Speakers
      • Newmen E370 Illuminated Keyboard
      • Bloody V3
      • Original Microsoft Xbox360 Controller for Windows (Wired Black)
      • Thermaltake Litepower 500W
      • Samsung S-ATA TrueDirect Super WriteMaster
      • SanDisk Ultra USB 3.0 Flash Drive 32 GB
      • Windows 7 Ultimate 64 Bit
      • 5.3 @ Windows 7 Benchmark
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    yeah ATM Phillips ee best IMO...Ami nijei Phillips LED 18.5" ta use kortesi, almost a year hoye gese...and ami totally satisfied amar ek friend k kisu din aage Samsung LED kine disi ( tokhon Phillips market a chilo na ) Samsung o kharap na but Phillips er Display ta amar kahcche onek lively lagse but Samsung LED er Display te ekta Pale vab ase jeta amar valo lage nai..
    • ochin's Gadgets
      • MSI H61
      • intel core i3 2100 3.1ghz
      • 2gb ddr3 1333mhz
      • 500gb
      • sapphire 7850 OC
      • philips 224el2sb 21.5&quot;
      • Thermaltake smart 550w
      • qubee
      • 124kpbs
    Quote Originally Posted by Z!mM3r View Post
    Here's the specs:
    Picture/Display
    •Aspect ratio: 16:9
    •sRGB
    Connectivity
    Convenience
    Stand
    Power
    •Off mode: < 0.5 W
    Dimensions
    Weight
    Sustainability
    Cabinet
    •Finish: Glossy
    mama tumi dekhi advertisement koire fatae diteso .nah asholei my visual experience has enhanced after buying this magnificent monitor
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    Quote Originally Posted by cyanid3 View Post
    philips LED ftw!!!
    tomar r amar Monitor same, tumi ki wall mount use koro? amader ai modeler jonne wall mount ase? thakle price kamon?
    • ochin's Gadgets
      • MSI H61
      • 2gb ddr3 1333mhz
      • 500gb
      • sapphire 7850 OC
      • qubee
      • 124kpbs
    Quote Originally Posted by SadIkMahdI View Post
    1000-1500tk
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    Quote Originally Posted by ochin View Post
    1000-1500tk
    ai gular ki kono specific brand ase? naki generic?
      • Asus vx229h ||Samsung 21.5&quot; S22A300B
    ami last week e samsung led 21.5" kinsi 15200taka...1080p movie dekhte bhaloi lage...chrm xp
    • cyanid3's Gadgets
      • msi 760Gm p33
      • Amd Athlon x4-640
      • 540GB
      • Microlab 2.1
      • A4tecH 2x
      • VINYSON
      • TT 500W
      • WIN 7 x86
      • goriber pc
      • LINK3
    cyanid3's Avatar
    Dec 2009
    West Panthapath.
    last time i checked , idb 2nd or top foolr er ekta vendor er kase dekhsi. 700 chaisilo, ami ekhono mount kori nai, but khub joldi 2 ta minitor laganor chinta ase tokhn korbo inshallah !
    mount er kono brand nai, afaik, ekta steel plate with some holes for you to fit in, jinish ta durable, but no 1st hand experience.
    Is there any led monitor available in bd of 120hz?
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    Quote Originally Posted by Taher fu®ious™ View Post
    boro monitor kinar ekta baje effect hoilo HDD space crisis dekha daye
    ---------- Post added at 14:32 ---------- Previous post was at 14:31 ----------
    thanx for the info amaro akhoni mount korar kono plan nai, but future a korar plan ase
    amar 500gb+dvdwriter o ase
    btw apnara keu wall mount krle pic upload koiren...dekhbo
      • Gigabyte B85M-D3H
      • Bloody V3
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    Movie ki dekhe Del kore dao? taile khub ekta prob hobe na..But Movie jodi rekhe dao taile 500 GB shesh hoiteo beshi time lagbe na, Write kore rakhar Idea ta valo, but DVD valo thake?
    okay korle dibo
    • cyanid3's Gadgets
      • msi 760Gm p33
      • Amd Athlon x4-640
      • 540GB
      • Microlab 2.1
      • A4tecH 2x
      • VINYSON
      • TT 500W
      • WIN 7 x86
      • goriber pc
      • LINK3
    cyanid3's Avatar
    Dec 2009
    West Panthapath.
    bro blank dvd kothae and price kemon pore? i mean the cheapest
    Sola Boot Muri™
    • Deep -xCross-'s Gadgets
      • ECS G41T-R3
      • Intel Pentium D E5400 (@2.7Ghz)
      • Transcend 2GB DDR3 (@1066MHz)
      • Western Digital Caviar BLACK 1TB &amp; Seagate GoFlex Desk External 3TB
      • Sapphire ATi Radeon 5550
      • DELL P2211H 21.5&quot; LED LCD (@1080p)
      • Creative Audigy Value 7.1
      • Creative GIGAWORKS T3 / Bose IE2
      • Razer BlackWidow Ultimate
      • Microsoft Comfort Mouse 6000
      • Thermaltake Lightpower 430W
      • GreenPower 600VA powered by a 85AH IPS Battery which gives me 3.5hours of backup
      • Windows 7 Ultimate 32bit (Pirated)
      • Not so bad for normal usage. I don't have any time to play games right now.
      • Link3 1532kbps Night Doubler
      • 180-360
      • 180*360
    Deep -xCross-'s Avatar
    Gulshan, Dhaka
    DELL P2211H (no HDMI though)
    seeing is believing..
      • ASROCK h81-GL
      • WD 1tb BLUE
      • Hp 18.5&quot;
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    Hehe!! Protidin ghum thaika uitha boli... 'ai monitor ta amr?'Joto dinjai toto amader shomporkay ghonishtota baray
    Write kore rakhar Idea ta valo, but DVD valo thake?o
    15takar dvd o bhalo thake but dekhar shomoy 1080p dvd theke direct dekha bhalo na...tai hdd te abar copy paste kore dekhi
    ---------- Post added at 15:28 ---------- Previous post was at 15:22 ----------
    15taka e pawa jay faltu classic gula...ami ogulai use kori...10ta ~150taka..but ogulae scratch porar chance beshi thake etai prob 20takar ydd/melody gula bhalo..r moser baer o bhalo
      • ASROCK h81-GL
      • WD 1tb BLUE
      • Hp 18.5&quot;
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    ami mitsubishi dvd's use kori...
      • 660 GB
      • BENQ B700A 17&quot;
      • City Net
      • 64 KB/s
      • 32 KB/s
    Abdur Rafi's Avatar
    Jun 2010
    Please stay on topic and suggest me good LED monitor frnds
  1. Monitor: AOC i2353 23" IPS LED
    By Leaving BG in forum Others PC Hardware
    Last Post: December 28th, 2011, 00:53
  2. Samsung SyncMaster BX2250 21.5" LED monitor....is it available in BD ???
    By Codename-Scorpion in forum Help - General Shopping
    Last Post: January 4th, 2011, 22:13
  3. Suggestion for Buying LCD/LED Monitor
    By SadIkMahdI in forum Others PC Hardware
    Last Post: December 9th, 2010, 02:09
  4. 20" LED monitor
    Last Post: November 23rd, 2010, 01:39
  5. Help me buying a good LCD/LED monitor(budget 18k)
    By showdown_king in forum Others PC Hardware
    Last Post: June 12th, 2010, 17:10
Page generated in 0.32458 seconds with 15 queries.
