Core i5 750 @ 3.81GHz | Prolimatech Megahalems Rev.B + Nidec Beta V + Rosewill RFX-120BL
ASUS P7P55D | Gigabyte HD5970 @ 850MHz/1150MHz + XFX 9800GT for PHYSX
2X2GB A-DATA DDR3 XPG @ 1520MHz, 8-8-8-20 | Samsung F3 500GB + Hitachi Deskstar 250GB
Samsung 2233SW | Gigaworks G500 | Creative HS-1000 X-Fi Fatality USB Headset
TT Spedo Advanced Package + 4X12" Logisys Blue CCT + Delta XTREME Airflow | ASUS 750W
yes it's reliable lol! I bought several stuff from it before. My budget was about $350, but now it looks like the PSU issue will get me spending more, can you guys honestly tell me if these PSUs are ok?
http://www.msy.com.au/product.jsp?productId=5106
http://www.msy.com.au/product.jsp?productId=4973
at least below a $100 for a PSU!
---------- Post added at 06:44 ---------- Previous post was at 06:42 ----------
How's this VANTEC, I hear they're a good brand! http://www.msy.com.au/product.jsp?productId=5132
I think its his processor bottleneck that is saving him from frying his PC right now. Too weak to use the full power of the GPU, and full GPU usage = fried circuits.
I sold my pc!!!!!
Yes, I said that before, everything except my GFX Card. I am starting from scratch!
What I currently Have:
2.0TB SATA HD
ATI Radeon HD 6950 1GB (PowerColor)
---------- Post added at 09:10 ---------- Previous post was at 08:10 ----------
How's this one?
http://www.msy.com.au/product.jsp?productId=4978
That wasn't all that necessary to sell off the whole pc, you could've bought a new power supply and a used Quad Core processor to reduce the bottleneck.. anywaysgo for atleast an Amd Phenom ll X4(minimum) or a core i5 2500K if you wish to game comfortably throughout 2012.
And yes, that power supply, the cooler master extreme 700W looks good on paper, just google for reviews with the PSU model name and you'll find out whether the PSU will be a good buy or not.
Do yourself a favor, that is spend an extra $13 & get this:
http://www.msy.com.au/product.jsp?productId=4990
Will easily power anything you plan to buy for the foreseeable future even if you want to upgrade the GPU.![]()
lol, I logged in. It's out of stock except in two branches far from here!
those extreme power series of CM are pretty low end psu's with weak +12v rail. get atleast this(corsair gs600) at $98 one. its within your budget and should be enough for any of the single gpu of today....for more detailed specs about this check this link http://www.corsair.com/gs600w.html
Ok How about this, so it can last longer just in case! http://www.msy.com.au/product.jsp?productId=7602
---------- Post added at 16:46 ---------- Previous post was at 14:32 ----------
http://www.hardwaresecrets.com/artic...Review/1422/11 This is the review for it, it's actually pretty good. I am going to get this one XD
---------- Post added at 16:47 ---------- Previous post was at 16:46 ----------
BTW, this is the last page (Conclusion) go back and check the rest!
That TR2 700W is a good power supply, wish it was available in BD, you can go for it or the one @nonymous suggested, both are good.
Yes I am getting these two first then the rest!
Antec 200V2 Gaming Case http://www.msy.com.au/product.jsp?productId=859
Thermaltake TR-700 http://msy.com.au/product.jsp?productId=7602
I'll get the MotherBoard http://msy.com.au/product.jsp?productId=8299
RAM http://msy.com.au/product.jsp?productId=6866
and Processor http://msy.com.au/product.jsp?productId=7098
When I get more money!
Does anyone disagree with these specs, will there be any bottleneck with anything. Including my Radeon HD 6950?
Ok, I am getting the Case and PSU VERY SOON!
now, I just need to save up more money to get the CPU, RAM and MoBo
I am almost 15, so it takes time to make such money quickly :'(
Going to try to get some money from fixing some Computers and laptops!
