Thread: CPU Cooler Noise
    • wayne's Gadgets
      • MSI 880GMS-E35 Themaltake Commander ms-i
      • AMD Phenom II X4 965 Black Edition 3.40GHz cooled by Cooler Master Hyper 212+
      • Transcend 8GB 1333MHz
      • Samsung HDD 1TB 7200RPM
      • Saphire Radeon HD7850 OC 2GB Dual-X Edition
      • Dell 21.5 inch S2240L
      • Realtek HD
      • Sony Ericsson HPM-85
      • A4 Tech KR 85
      • A4-tech Bloody GUN3 V3
      • X-box 360 controller for windows
      • Corsire VS450W
      • HP DVD-RW
      • Trancend 32GB USB 3.0
      • X
      • Windows 10 TP
      • happy enough :)
      • New Lava Communications
      • 107~114 kbps
      • 100~200 kbps
    wayne's Avatar
    Dec 2011
    Unhappy CPU Cooler Noise
    I have AMD Phenom II X4 965 Black Edition processor and it's stock cooling fan is making huge noise only when I play games. In bios the rpm is approximately 4117 (variable) in the boot time. In addition, there's a smart fan option indicates (40"C ,55"C..........)at bios in my motherboard (MSI 880GMS E35) and 40"C is enabled. Now what should I do to reduce noise or fan's rpm? I have not faced this problem was not from the beginning. I need a solution except buying a new cpu cooler because if I do not play games it does not create any sound.
    • Rorschach's Gadgets
      • MSI B85 GAming
      • Core i3 4130 3.2Ghz
      • Corsair vengeance 2*4gb = 8gb Ddr3 1600Mhz
      • 128Gb Crucial M4 SSD + 2TB Hitachi HDD + 2* 2TB Seagate HDD+2TB Seagate HDD+(4TB+3TB) Seagate HDD
      • EVGA GTX 980 SC ACX cooler
      • Sony Bravia W670A 32inch
      • Sound Blaster X fi Titanium
      • Panasonic HTF600 + Creative 4:1 Speaker
      • Ducky
      • V3
      • Xbox 360 Controller In PC via Receiver
      • TT Toughpower XT 675W 80+Bronze
      • Asus Dvd-RW ; NZXT Sentry 2
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • BUCT 2Mbps real ip
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    Quote Originally Posted by Mukit View Post
    The stock 955/965BE coolers are like whining dogs, they go up to 7K RPM at 100%. Set your smart fan profile to 55C so that the the fan spins up after you reach 55C or more. There's nothing you can do to stop the cooler from making that awful noise, I used to have it too with my 955BE. I had mine set at 55C, I recon you can also put a lower value for the fan to spin down. If you do have one, set it to 40C or say 35C.
    The noise you are getting is because you've set it at 40C which easily crosses that threshold during intense 3D or stressing the CPU.
    • wayne's Gadgets
      • Realtek HD
      • A4 Tech KR 85
      • Corsire VS450W
      • HP DVD-RW
      • X
      • Windows 10 TP
      • happy enough :)
      • 107~114 kbps
      • 100~200 kbps
    wayne's Avatar
    Dec 2011
    I will do that but what to do with AMD calm and quite option? it is enabled.
    Yes you can enable it. It'll lower clock speeds & voltages when the CPU is idling (desktop, browsing, etc), which would reduce temps even further so the cooler won't have to ramp up frequently. But can be a bit sluggish, since CnQ takes it sweet time to increase processor speeds corresponding to loads. If you had it enabled all this time, then just leave it like that. But if the option is disabled, enable it!
    Btw, it's CnQ ~ CoolNQuiet, not CalmNQuiet.
    • wayne's Gadgets
      • Realtek HD
      • A4 Tech KR 85
      • Corsire VS450W
      • HP DVD-RW
      • X
      • Windows 10 TP
      • happy enough :)
      • 107~114 kbps
      • 100~200 kbps
    wayne's Avatar
    Dec 2011
    I set it to 55"C but it did not show much effective. (Noise reduced a little)
    • wayne's Gadgets
      • Realtek HD
      • A4 Tech KR 85
      • Corsire VS450W
      • HP DVD-RW
      • X
      • Windows 10 TP
      • happy enough :)
      • 107~114 kbps
      • 100~200 kbps
    wayne's Avatar
    Dec 2011
    Bios e Cpu fan minimum speed- 62.5 Can I reduce it? (Disable,0,12, 40, 50,62.5.............)
    Yes you can, for minimum try 40C. I'm afraid you can't do much above 50C, since Phenoms are highest rated at 62.5C after that, thermal throttling takes place. But your chip should be a C3, which can supposedly go up as high as 70C, but for maximum you should ideally set it to atleast 55C.
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    leave it at 62.5% since lower may increase your idle cpu temperature. at 62.5% your stock fan speed may be around ~3200-3500rpm which is quiet enough for those tiny stock fans....
  1. Want to Buy CPU cooler
    By neo.sy1ar in forum Shop - Gadgets
    Last Post: November 16th, 2011, 14:51
  2. Sale (New) Cooler Master Hyper 212 Plus Cpu Cooler
    By EBL.Mantis in forum Shop - Gadgets
    Last Post: November 10th, 2011, 20:44
  3. Weird Noise Emanating from CPU
    By flyboy670 in forum Others PC Hardware
    Last Post: November 1st, 2011, 20:14
  4. Replies: 9
    Last Post: June 10th, 2011, 22:16
  5. Replies: 42
    Last Post: February 21st, 2010, 15:51
Page generated in 0.20358 seconds with 14 queries.
