Results 1 to 20 of 26
Thread: Replacement fan for Radeon 5770
    • faisal.amir.bd's Gadgets
      • ABIT IP35 Dark Raider
      • Intel Core 2 Duo [email protected]
      • 2GB Transcend AxeRam DDR-2 800+ @816MHz
      • 820GB (320GB Hitachi, 500GB Samsung)
      • Gigabyte Radeon HD5770 1GB DDR5 (Batmobile Cooler)
      • ASUS MS228H 1080p LED backlit
      • Creative Sound Blaster Live! 5.1
      • Creative Inspire 5200 (5.1)
      • XBOX 360 wired gamepad
      • Thermaltake TR2 600W
      • Rahim Afrooz 1000VA
      • Windows 7x86
      • 180kBps [1.5Mbps]
      • 180kBps [1.5Mbps]
    faisal.amir.bd's Avatar
    Atlanta
    Default Replacement fan for Radeon 5770
    Lately I've noticed the fan on my Radeon 5770 (Batmobile cooler) is not as loud as it used to be. I decided to open up the case today and I noticed it spinning significantly slower than usual. Changing the fan speed from CCC has no effect either. In addition, the fan speed seems to be variable, i.e. I can sometimes see it slowing down, and then revving up again. My idle temp right now is 43 C, despite the weather, God knows what it would be like in summer. I opened it from the case and gave it a brief cleaning with the dust blower. I also took the fan shroud off and cleaned the fan. It's an Everflow T128015SH with a 2-pin fan header. Pics given below
ID:	17082 Click image for larger version.
    Also, when powered on, the fan used to spin at 100% duty cycle for a few seconds and then slowed down to the value CCC set it at. But now, it does not spin initially at all. During my last restart I had to spin it by hand to get it started
    I believe my fan is dying, does anyone have any ideas where I can find a replacement? Or if I can't find the actual thing, any way I can jury rig a high performance 80mm fan on my card?
    P.S. I still have six months of warranty left, but I have to leave the card at the shop and go PC-less for a few days which I can't really afford right now. The less painful alternative would be to hunt around and buy a replacement fan myself.
    Tagging some users who have experience in these areas, @error , @Hemlock , @Infracted , @romulus_ut3 . I hope you won't mind.
    • error's Gadgets
      • None ; 18x DL SuperDrive
      • Mac Pro love.
      • 1 mbps
      • 1 mbps
    error's Avatar
    Boo.
    I don't think you'll find a replacement fan, you won't even be able to put a high performance 80mm fan as it won't fit in properly. You might be able to get if off from a dead card if anyone wants to give it away or something. Otherwise, RMA'ing it would be your best bet. This fan is not even available on amazon. :/
    • Franklin's Gadgets
      • Gigabyte z97P D3
      • NIA Wireless Headset
      • A4 tech
      • DS4 Wireless Controller
      • Cooler Master v750W
      • Asus DVD RW 24x
      • Transcend Jetflash v70 8 GB
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    Just like error said, you will not find a replacement unless, of course, you find a seller who's willing to sell their video card fan separately. You better call up the shop you bought your card from. They will give you the correct answer.
    • Hemlock's Gadgets
      • ASUS P7P55D
      • Core i5 750 @ 3.81 GHz + Prolimatech Megahalems (Nidec Beta V Intake + Rosewill RFX120BL Exhaust)
      • 2X2 GB A-DATA XPG DDR3 @ 1520 MHz, 8-8-8-20 @ 1.55V
      • 500GB Samsung F3 + 250GB Hitachi Deskstar
      • Gigabyte HD5970 @ 850/1150 + XFX 9800GT for PHYSX
      • Samsung 22" 2233SW
      • VIA VT1828S
      • Gigaworks G500, HS-1000 X-fi Fatality USB Headset
      • A4Tech Generic
      • A4Tech XL747-H
      • ASUS 750W U-75HA || TT Spedo Advance Package || 4 X 12" Logisys Blue CCT
      • ASUS 22X DVD-RW
      • A4Tech XL-747H
      • Micro 2000VA - Failed
      • Windows 7 Ultimate 32bit Build 7600, 4GB Unlocked
      • 28363 3d Mark Vantage Score with cat 10.5, 31K possible with cat 10.6
      • ANUBIS 970 - "The Beast Unleashed"
    Hemlock's Avatar
    Jun 2010
    Muhammadpur,Dhaka
    This is bad, because this fan is going to be a lot harder to find than the stock radeon fans, actually impossible to get a 70mm replacement that features three screw mounts. You sure can find ways to mount an 80mm over the cooler with zip ties or strong rubber bands. It 's going to be a little tricky because i've disassembled this exact 5770 (it 's in my secondary PC) and as far as i can recall form the pattern, if you zip tie it, the ties on left hand side will have to go under the pciex slot pins(which will render the card useless). Insted you can run rubber bands/ strong threads/ties beneath the cooler and take support of it.
    I definitely think you should hand it over under warranty, that might be the only sensible solution. It 's better to abandon the PC for a while in order to get a fully functional card than to live with a card that has an 80mm case fan zip-tied on it, you can 't even sell it later. But if you are looking for a temporary solution and will ultimately avail warranty when you can give your PC a break, then using the cooler as a support to fix an aftermarket fan over it will do the job for now.
    Core i5 750 @ 3.81GHz | Prolimatech Megahalems Rev.B + Nidec Beta V + Rosewill RFX-120BL
    ASUS P7P55D |
    Gigabyte HD5970 @ 850MHz/1150MHz + XFX 9800GT for PHYSX
    2X2GB A-DATA DDR3 XPG @ 1520MHz, 8-8-8-20 | Samsung F3 500GB + Hitachi Deskstar 250GB
    Samsung 2233SW | Gigaworks G500 | Creative HS-1000 X-Fi Fatality USB Headset
    TT Spedo Advanced Package + 4X12" Logisys Blue CCT + Delta XTREME Airflow
    | ASUS 750W
      • |Gigabyte| G41M-Combo
      • |Intel| Core 2 Quad Q-8400 @ 3.46 Ghz with Thermaltake Frio Ock
      • |Twinmos Ocean Blue| 8 Gb(4x2) DDR3 1333MHz @ 7-7-7-20
      • |Samsung| 850 EVO 120 Gb, |Samsung| Spinpoint F4 2TB, |Hitachi| HGST 2TB(64MB Cash)
      • |NVIDIA| Gigabyte G1 1050Ti 4GB GDDR5
      • |LG| 22MP68 22 inch LED Monitor ♥
      • |Realtek| ALC883 7.1 HD
      • |Microlab| 2.0 Solo 7c Speakers / |A4Tech| Headphone / |Logitech| Webcam
      • |Cooler Master| Masterkeys Lite
      • |Genious| Gamepad
      • |Cooler Master| G550M
      • |Asus| CD Rom, |HP| DVD/CD RW
      • |Transcend| JF V30 / 2 GB
      • |Apollo| 650VA
      • |Windows 10| PRO 64-bit
      • Processor 7.4 | Ram 7.4 | Graphics 7.4 | Gaming Graphics 7.4| Primary HDD 5.9
      • Love my PC! muahhhh!! ♥
      • X-press Technologies Limited
      • 20 Mbps
      • 20 Mbps
    Vиms Vm's Avatar
    tag avas(salman) vaiya. he might help.
      • Windows 7x86
      • 180kBps [1.5Mbps]
      • 180kBps [1.5Mbps]
    Atlanta
    Quote Originally Posted by Vиms Vm View Post
    Right! Forgot about him! Tagging @avas911
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Quote Originally Posted by faisal.amir.bd View Post
    first try to spin the fan with your finger. Does it spin smooth? If it slows down too fast or there is some resistance, it might be dying. but some fans have multiple poles like stepper motors. they tend to move like bicycle sprockets. they normally show resistance. Like the fan of 4890, 5850 stock. But normal 2 pole fans, like yours usually do not show any resistance.
    If it is dying, best solution RMA. but if you have to run it for now, you dont have to do anything. as in this temp it will be OK for couple of weeks. make sure the fan doesnt completely stop.
    and in another thought, @Hemlock said it all.
    Once more into the fray
    Into the last good fight Ill ever know
    Live and die on this day
    Live and Die on this day
    • Rajmi's Gadgets
      • MSI H61M-E33 [B3]
      • Corei5 2500k
      • GSkill Ripjaws 2x2 => 4gb
      • intel 3000
      • 19" LCD LG Flatron
      • Creative 2.1
      • A4tech slim
      • Delux T6 :: Dragon
      • Delta 550W
      • BTCL - ADSL
      • 64KBps
      • 15KBps
    Rajmi's Avatar
    faisal.amir.bd ,i'm saying this from my 5770 RAM experience....IF you send it for RAM, you WON'T get the card back! ...they'll ask you to either upgrade to 6770 with 2k or they'll give you a 6670 as replacement .
    i was so frustated with my RMA procedure, that i went to UCC's head office to complain...the only thing a managed to change was a reduction in the "upgrade" cost. i had to pay 1.5k instead to 2k.
    they don't import 5770s anymore so if you send for RMA, then there's high chances that you wont see you card ever again.
    • avas911's Gadgets
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Quote Originally Posted by Rajmi View Post
    the Batmobile on is Gigabyte not Sapphire
    • Rajmi's Gadgets
      • MSI H61M-E33 [B3]
      • Corei5 2500k
      • intel 3000
      • Creative 2.1
      • A4tech slim
      • Delta 550W
      • BTCL - ADSL
      • 64KBps
      • 15KBps
    Rajmi's Avatar
    doesn't matter...if they dont import it anymore, then they wont give him warranty.
    Bhai, akta short and simple kotha boli. Stay away from SMART, though i worked with them long days, and still somehow connected. Follow it and you will thank me later on.
    • avas911's Gadgets
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    you dont know that. and thats no ground to deny warranty.
    mentioning @dipanzan . he had some insane stories of RMAing.
    Follow your cards and cool right. you will get that eventually. once i had to try for 3 months. but i got a brand new better mobo for only 300 more. And i am telling you. they threw everything at me at get me take the same mobo which died 3 times before.
    • Hemlock's Gadgets
      • ASUS P7P55D
      • VIA VT1828S
      • A4Tech Generic
      • A4Tech XL747-H
      • ASUS 22X DVD-RW
      • A4Tech XL-747H
    Hemlock's Avatar
    Jun 2010
    Muhammadpur,Dhaka
    Not that they won 't give him warranty, they will have to satisfy the RMA with another equivalent product if the same product is not available anymore. And it 's RMA Rajmi, not RAM.
    ASUS P7P55D |
    | ASUS 750W
    • Rajmi's Gadgets
      • MSI H61M-E33 [B3]
      • Corei5 2500k
      • intel 3000
      • Creative 2.1
      • A4tech slim
      • Delta 550W
      • BTCL - ADSL
      • 64KBps
      • 15KBps
    Rajmi's Avatar
    Quote Originally Posted by Hemlock View Post
    that was typo ...and as for the not giving warranty...i was in a hurry so i could make the post properly. what i ment was...they wont be giving exact replacement if they dont have the card....and the possibility of getting a new card might come with some extra cost.
    Lately I've noticed the fan on my Radeon 5770 (Batmobile cooler) is not as loud as it used to be. I decided to open up the case today and I noticed it spinning significantly slower than usual. Changing the fan speed from CCC has no effect either. In addition, the fan speed seems to be variable, i.e. I can sometimes see it slowing down, and then revving up again. My idle temp right now is 43 C, despite the weather, God knows what it would be like in summer. I opened it from the case and gave it a brief cleaning with the dust blower. I also took the fan shroud off and cleaned the fan. It's an Everflow T128015SH with a 2-pin fan header. Pics given belowClick image for larger version.
ID:	17083Also, when powered on, the fan used to spin at 100% duty cycle for a few seconds and then slowed down to the value CCC set it at. But now, it does not spin initially at all. During my last restart I had to spin it by hand to get it started I believe my fan is dying, does anyone have any ideas where I can find a replacement? Or if I can't find the actual thing, any way I can jury rig a high performance 80mm fan on my card?P.S. I still have six months of warranty left, but I have to leave the card at the shop and go PC-less for a few days which I can't really afford right now. The less painful alternative would be to hunt around and buy a replacement fan myself.Tagging some users who have experience in these areas, @error , @Hemlock , @Infracted , @romulus_ut3 . I hope you won't mind.
    Try to spin the fan with ur finger; if u feel resistance, Buy a WD40 Spray (available in stadium) and then pull out the sticker off the fan which will reveal a small hole. Now shake ur WD40 attach the supplied red pipe and spray on that hole. I'm sure you will be surprised with the result.btw WD40 is 1 hell of a useful staff for which U'll find plenty of useful use in future.
      • Windows 7x86
      • 180kBps [1.5Mbps]
      • 180kBps [1.5Mbps]
    Atlanta
    There is significant resistance to motion. The fan is dying. Just now I had to spin it manually to get it started.
    ---------- Post added at 22:20 ---------- Previous post was at 22:18 ----------
    Quote Originally Posted by Infracted View Post
    Upay nai, Golam Hossain!
    ---------- Post added at 22:22 ---------- Previous post was at 22:20 ----------
    What I am hoping for is that since it's only the fan that needs replacing they might have some dead cards lying around they can just substitute the cooler from. But maybe I'm being too optimistic.
    ---------- Post added at 22:24 ---------- Previous post was at 22:22 ----------
    Ki bolen! First e etai try korbo! Pray to God it works! BTW, WD40 is a lubricant, right? Any idea about the price range?
    Yes it is. should be within 200-250.
    • Camouflage's Gadgets
      • Gigabyte Sniper B5 B85
      • Core i5-4460 3.2Ghz with Deepcool Mini Cooler in Thermaltake 'Versa-2'' Case
      • Corsair Vengeance DDR3 1600Mhz 2*4gb
      • WD Blue 1TB 7200rpm
      • MSI Gtx770
      • Samsung 22'' Wide Screen LED-1920*1080
      • Creative Sound blaster Audigy 2ZS
      • Microlab 5:1
      • HP keyboard
      • A4Tech X7 XL-747H Spider
      • Corsair-HX650W-52A in single 12V Rail with 4 (6+2) pin connectors
      • HP DVD writer
      • Transcend Jetflash-16gb & Sandisk Cruzer 4gb
      • Apollo 1200VA
      • Windows-7-64 bit Ultimate Edition
      • Pro-7.6,GPU-7.9-Windows7 benchmark
      • Satisfied what i have
      • Dhakanet,1mbps
      • 128 kbps
    Camouflage's Avatar
    Wow.idea to joss.Gpu e prblm hle most of the case e fan nosto hoi prai i.Idea ta kaje lagbe.
    Yes, lol. I've had some actually "insane" warranty stories. But nonetheless, it won't be any help to the OP here, so no point in writing. What I would suggest is that, you get the RMA done. Manage a cheap GPU, so that you can work while the RMA is being done. That way it would be a lot easier & worthwhile than replacing & tinkering with the fan.
    @Rajmi , please don't scare people like that saying you won't get warranty & stuff like that. If you know how to "claim" warranty, you'll surely get it. Then there's no point in buying a brand new product, the point is he has warranty left & that should be his 1st priority.
    Oh, btw @faisal.amir.bd , I don't know how you can control the fan RPM, since it's only a 2pin fan, you need atleast a 4pin fan to actually see fan RPM speed/control. I guess, your card manages it by controlling it with a PWM voltage control, rather than actual RPM throttling. I best I would advice is to go for RMA bhaiya, even if you find a 2pin replacement fan, chances are that it won't match exactly with the one that came with your batmobile cooler & might not work properly if it requires a higher power.
      • Windows 7x86
      • 180kBps [1.5Mbps]
      • 180kBps [1.5Mbps]
    Atlanta
    That's the biggest problem, no one I know has a spare PCI-E GPU lying around
  1. Want to Buy ati radeon 5770
    By neorage in forum Shop - Gadgets
    Last Post: June 29th, 2011, 04:14
  2. 8800GT RIP, should I go for the Radeon 5770?
    By faisal.amir.bd in forum GPU
    Last Post: November 27th, 2010, 15:34
  3. Radeon HD 5770 review (Crossfire)
    By dipanzan in forum GPU
    Last Post: October 13th, 2009, 20:53
  4. ASUS Radeon HD 5770 Benchmarked
    By shaikh_imtiaj in forum GPU
    Last Post: October 9th, 2009, 14:23
  5. Gigabyte Radeon HD 5770 Pictured
    Last Post: October 9th, 2009, 00:18
Page generated in 0.33072 seconds with 15 queries.
