Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 52
Thread: Suggest me power supply for these configs>>
    Post Suggest me power supply for these configs>>
    Guys,i have a plan to buy hd5850 or such card next month but i need a good psu.Currently i have athlon II x2 but later i might upgrade it.My mobo is 740gmP25. So pliz suggest me power supply for these configs,i prefer thermaltake but you can also suggest other brand such delta/corsair etc.And don't forget to post psu price along with the name!!
    1)Athlon II x2 + hd 5850
    2)Athlon II x2 + hd 5830
    3)Athlon II x2 + GTX 460 1gb
    4)Athlon II x2 + hd 6850
    ______________________________
    5)Phenom II x4 + hd 5850
    6)Phenom II x4 + hd 5830
    7)Phenom II x4 + GTX 460 1gb
    8)Phenom II x4 + hd 6850
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Intel Core i5 2500K @4.2GHz
      • Sapphire Vapor-X HD 7970
      • Asus MS228H 21.5''
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • TT Toughpower 750watt
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    IMO, if you are not overclocking for every config delta 550w is sufficient. Price 6.5k.
    • Rajmi's Gadgets
      • MSI H61M-E33 [B3]
      • Corei5 2500k
      • GSkill Ripjaws 2x2 => 4gb
      • intel 3000
      • 19" LCD LG Flatron
      • Creative 2.1
      • A4tech slim
      • Delux T6 :: Dragon
      • Delta 550W
      • BTCL - ADSL
      • 64KBps
      • 15KBps
    Rajmi's Avatar
    hmm...go for delta..its a bit pricey but reliable.
    • Camouflage's Gadgets
      • Gigabyte Sniper B5 B85
      • Core i5-4460 3.2Ghz with Deepcool Mini Cooler in Thermaltake 'Versa-2'' Case
      • Corsair Vengeance DDR3 1600Mhz 2*4gb
      • WD Blue 1TB 7200rpm
      • MSI Gtx770
      • Samsung 22'' Wide Screen LED-1920*1080
      • Creative Sound blaster Audigy 2ZS
      • Microlab 5:1
      • HP keyboard
      • A4Tech X7 XL-747H Spider
      • Corsair-HX650W-52A in single 12V Rail with 4 (6+2) pin connectors
      • HP DVD writer
      • Transcend Jetflash-16gb & Sandisk Cruzer 4gb
      • Apollo 1200VA
      • Windows-7-64 bit Ultimate Edition
      • Pro-7.6,GPU-7.9-Windows7 benchmark
      • Satisfied what i have
      • Dhakanet,1mbps
      • 128 kbps
    Camouflage's Avatar
    I will say to u to buy Xfx 650W for being futureproof if itz available to market.Itz also better than Delta.Price will be like 8.5k-9k.If u cant afford this Delta is the only option left.
    • RonzDrive's Gadgets
      • ECS H61H2-M2 B3 Stepping
      • Intel Core i3 2100 SB
      • Transcend 2x2 GB DDR3
      • Hitachi 500 GB SATA 2
      • ECS GTX 550 Ti 1 GB DDR5
      • Acer 18.5'' LED
      • Creative Inspire 2500 2.1
      • PS2
      • PS2
      • Tt TR2 RX 450W (Modular)
      • External
      • Windows 7 Ultimate (64-bit)
      • 3DMark 11 Score P2740
      • Happy with it
    RonzDrive's Avatar
    Xfx psu unit (450W/550W/650W)will be good buy as those has single 12v rail, i would say go for 650W for better system futureproof
      • ASROCK h81-GL
      • Core i3 4130 @3.40ghz
      • WD 1tb BLUE
      • Radeon r7 260x (2gb) GDDR5
      • Hp 18.5"
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    A place Where U Belong >:/
    future cards such as radeon 7xxx series and keeplar r energy efficient cards... I don't c a reason to go for a 650w psu at the moment... 550w is enough..
    Option 8 definitely
      • MSI Gtx770
      • Microlab 5:1
      • HP keyboard
      • HP DVD writer
      • Apollo 1200VA
      • Dhakanet,1mbps
      • 128 kbps
    Camouflage's Avatar
    Quote Originally Posted by Z!mM3r View Post
    future cards such as radeon 7xxx series and keeplar r energy efficient cards... I don't c a reason to go for a 650w psu at the moment... 550w is enough..Option 8 definitely
    TDP of 7970 is abt 210w.So itz nt safe running it with psu lyk delta 550w.Bt yeah if itz in between his options it will be ok.Most important part is that he didnt mentiond his budget.Thn all questns will be cleard.
    thnx a lot guys but i am in a tight budget here.... psu calculator of coolermaster or thermaltake website showed me i need max 400-430watt with (phenom II x4 + gtx 460 ) and max 360-390watt with (athlon II x2 + gtx 460 ).
    Are their calculations have some error?Do they show lesser wattage than actual? Can i go for any psu that gives 430-450watt or i cant?
    If i can... then pliz answer following query
    1)Is TT TR2 bronze 500watt available in BD market?Price?
    2)Is TT Smart 530watt available in BD market?Price?
    3)Price of Delta 500watt?
    ---------- Post added at 15:01 ---------- Previous post was at 14:53 ----------
    My initial budget is 5k but perhaps i can expand it upto 6k
    And i am not going to upgrade beyond (phenom II x4 + hd 5850) so no need to be future proof.Actually i am going to have (athlon II x2 +5850) or (athlon II x2+ gtx 460).
      • MSI Gtx770
      • Microlab 5:1
      • HP keyboard
      • HP DVD writer
      • Apollo 1200VA
      • Dhakanet,1mbps
      • 128 kbps
    Camouflage's Avatar
    If ur budget is arnd 6k-6.2k go for Delta 550w from binary logic.
      • ASROCK h81-GL
      • WD 1tb BLUE
      • Hp 18.5"
      • basic
      • basic
      • TT Amaru
      • Newman Gaming
      • Corsair CX430w
      • General
      • Alhamdulillah :)
      • 6
    Zimmer™'s Avatar
    go for delta 550w... Its prefered by 95% BG members
    • Robin Rayhan's Gadgets
      • Gigabyte B85-D3H
      • Intel Core i5 4570
      • Avexir 8GB DDR3 1600MHz
      • 120 + 240 GB ADATA SSD
      • (N/A)
      • AOC 20 INCH LED 1600x900
      • WinnerIT 3.5Mbps
      • 200-500 KB/s International | 12Mbps Local
    Robin Rayhan's Avatar
    Dec 2011
    Recently PSU'r onek shortage BD market eh.
    I dont know what is a good PSU for you guys, but for me over 18A @ 12v means a good PSU since ami SLI, XFIRE, DUAL-GPU prefer kori na. For me Thermaltake TR2 is really bogus. (Dont knw about TR2 RX) It gives 15A @ 12V, same as Chinese stock casing ones. Delta 550watt gives 16A @ 12v.
    Elephant road erh ekta shop eh ekta PSU dekhsilam Compro. Gives 20A @ 12V. But since its a chinese brand, trust kora jae na.
    Jodi market eh Thermaltake XT 575watt ta thakto tahole nitam. But chilo na. Ekhon ashche kina jani na.
    Another thing I look for in a PSU is whether its 80PLUS, means whether its 80% efficient. 80PLUS PSU's last longer than regular PSUs.
    XFX PSU's are good. But rare nowadays. Delta PSU 750watt 13k chaisilo. Binary Logic maybe BG member der interest notice kore PSU's dam barae dise. 750watt PSU which is only 80PLUS certified, no bronze capacitors, 18A @ 12v, 13k is unfair.
    Budget e main problem.
    1)Delta
    500watt er price koto?
    2)Thermaltake 550watt TR2 RX er price koto?
    3)Thermaltake 500watt bole kisu ki ase ekhono?na thakle tt 450watt TR2 er price koto?
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    Quote Originally Posted by Taher fu®ious™ View Post
    their calculations don't have any error but the process of recommending psu by combined wattage is far ideal. what those calculators do is pretty simple, just adding the TDP's of the entire components + extra 60/70W...these calculators won't give you any clear idea for making a decision. Tr2 bronze/smart probably not available. get delta 500/550w...another thing is that 5850/gtx460 will be bottlenecked much on a athlon iiX2......
    Quote Originally Posted by XLR8 View Post
    seems like you don't have any idea about multiple +12v rail.its why you are saying that tr2 RX/delta 550w have 15/16A on +12v rail!!!
    Quote Originally Posted by @nonymous View Post
    seems like you don't have any idea about multiple +12v rail.its why you are saying that tr2 RX/delta 550w has 15/16A on +12v rail!!!
    ROFL ami or post dekhe takay chilam eita ki? Pore chinta korlam ekta rail r Amp post korse.
      • Gigabyte B85-D3H
      • (N/A)
      • WinnerIT 3.5Mbps
    Dec 2011
    Actually I dont. :S I dont get the rail thing. It means extra cables right? Each 12V rail provides 18A for the Delta 750watt?
    ---------- Post added at 20:00 ---------- Previous post was at 19:56 ----------
    Quote Originally Posted by EviL AnGeL View Post
    Yes, I dont get the rail thing, thats why I dont look for rail when buying a PSU. Thats why I said I dont knw what you guys think about when buying PSU.
    http://lmgtfy.com/?q=Power+Supply+Rails
      • Gigabyte B85-D3H
      • (N/A)
      • WinnerIT 3.5Mbps
    Dec 2011
    LOL! I still dont get it. I am special type of noob! onek agei google korsilam. I just dont get the concept and how it helps in gaming. 12V1, 12V2, thats multiple rail ryt? And how does that help me when I have a cheap GPU with 6 pin connector?
    hmm....if adding wattage for every components cant give dependable infomation then i should buy 550watt
    bumping previous query>
    1)Delta 500watt er price koto?
    • Arif69's Gadgets
      • Gigabyte H61 S2P B3
      • Dell E1910H 18.5 Wide Lcd
      • VIA HD Audio Codec
      • Lexma LK7550P Slim
      • Logitech B100
      • Generic Usb Joystick
      • ITS 500 Watt
      • Samsung SH-224BB 24X
      • Transcend Jetflash350 16 GB
      • KS
    Delta 500 watt - 5.5k
    Delta 550 watt - 6k
    Can't say about the TT one.
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    dön't take tt. Even delta 550 can cover ur need. Sli is not ur plan, future is power effitient. So, why spend on higher psu?
  1. Sale (Used) Tansnet Casing with 430watt Thermaltek Lite power Power Supply
  2. Power Supply
    By Rajmi in forum Help - General Shopping
    Last Post: October 6th, 2011, 04:49
  3. Replies: 21
  4. Best Power Supply
    By EBL.Mantis in forum Others PC Hardware
    Last Post: January 9th, 2011, 01:14
Page generated in 0.31586 seconds with 14 queries.
