Thread: Problem with Remote Desktop Connection
    Default Problem with Remote Desktop Connection
    Ami laptop er shathe pc crossover cable die connect korsi. Both are using win7 ultimate. File sharing hocche kintu Remote Desktop Connection setup korte parsi na. Ei bishoye amar jana shona ektu kom, tai google e search dilam. Kichu tutorial pelam jegulo follow korechi kintu 'Connect' e click korle username r password chay. Eikhane ami kon username/pass dibo?
    Abaro bolsi ei bishoy tate ami noob. Tai ektu help dorkar.
    Thanks in advance...
    • sadi_warhead's Gadgets
      • MSI G41
      • Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz (4 CPUs)
      • ADATA 4096MB RAM DDR3
      • 1 TB Samsung H3
      • Gigabyte GTX 560OC-1GI 1 GB
      • 22" samsung 2233sw
      • Realtek HD Audio output input
      • Creative 2.1/A4tech headphones
      • BenQ mulitmedia
      • A4 teCH
      • Sony controller
      • Fortex 600w
      • Windows 7 Ultimate 64-bit (6.1, Build 7600)
      • Motamuti-:| :)
      • Ispros
    sadi_warhead's Avatar
    MIRPUR
    Default Re: Problem with Remote Desktop Connection
    remote desktop korte chaile .. password set up kortei hobe .. desktop e password den .. then oi password and user name diye try koren.. tahole work korbe ...
    Fly High, Do or Die, Dare to Dream, Cheer Extreme!
    Quote Originally Posted by sadi_warhead View Post
    thanks it works.
      • MSI G41
      • 1 TB Samsung H3
      • BenQ mulitmedia
      • A4 teCH
      • Sony controller
      • Fortex 600w
      • Motamuti-:| :)
      • Ispros
    MIRPUR
    thanks it works.
    welcome bro
    welcome bro
    remote desktop korle remote pc er windows session lock hoye jacche. Eita lock na kore open rakhar ki kono upay ache? Mane remotely kaj korleu ekhane shob dekha jabe emon r ki?
      • MSI G41
      • 1 TB Samsung H3
      • BenQ mulitmedia
      • A4 teCH
      • Sony controller
      • Fortex 600w
      • Motamuti-:| :)
      • Ispros
    MIRPUR
    umm :S oita lock hobei .. ami jani na tasara .. but teamviewer use koren tahole
    • SadmanBD's Gadgets
      • Asus VX229H 21.5" LED IPS
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • XFX 850W Core Edition
      • Luminous Solo 1000VA
      • Windows 8.1 Pro WMC
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    Lock hobei kisu korar nai. But password na diye connect korar system ase
    Teamviewer er kotha to vulei gesilam. try kore dekhboni.
    Quote Originally Posted by SadmanBD View Post
    kivabe?
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    kivabe?
    You can disable blank password restrictions by using a policy. To locate and change this policy:
    1. Click Start, point to Run, type gpedit.msc, and then click OK to start the Group Policy Editor.
    2. Open Computer Configuration\Windows Settings\Security Settings\Local Policies\Security Options\Accounts: Limit local account use of blank passwords to console logon only.
    3. Double-click Limit local account use of blank passwords to consol logon only.
    4. Click Disabled, and then click OK.
    5. Quit Group Policy Editor.
    NOTE: By default, this policy is on (enabled).After you have enabled this, you will be allowed to log on using a blank password.
    এই কাজ গুলা যে পিসি তে কানেক্ট করবেন ঐ পিসি তে করবেন। আর খেয়াল করবেন যাতে ইউসার অ্যাকাউন্টে কোন পাসওয়ার্ড দিয়া না থাকে।
    আর এত ঝামেলা না করে সহজ বুদ্ধি হল Tight VNC অথবা Ultra VNC ইউস করেন। টিমভিউআরে ঝামেলা হবে।
  1. BTCL ADSL Connection Problem
    By austin in forum BTCL
    Last Post: March 23rd, 2012, 13:08
  2. btcl connection problem
    By S_F.darkzone in forum BTCL
    Last Post: October 10th, 2011, 09:37
  3. Replies: 2
    Last Post: July 11th, 2011, 03:41
  4. Connection problem
    By Ahad Uddin in forum BTCL
    Last Post: May 31st, 2011, 21:28
  5. Tracker connection problem
    By avas911 in forum File Sharing and Torrents
    Last Post: February 26th, 2011, 00:50
Page generated in 0.22371 seconds with 14 queries.
