Results 1 to 20 of 20
Thread: high CPU temperature due to "system" running in task manager....plz helpppp
    • aallvveeee's Gadgets
      • AMD Phenom !! X4 Processor Black Edition 3.2GHz True Quad -Core Design 8.0 MB Total Cache
      • Silicon Power 4GB DDR3-1333
      • Hitachi 1TB SATA 7200 RMP
      • Sapphire HD5770
      • Samsung SyncMaster 2033sw
      • A4 TECH MOP-70D
      • PC DUAL SHOCK JOYPADAS U-900
      • Thermaltake 430W
      • LG Portable Super Multi Drive GP08NU20
      • Smart Centra
      • Windows 7 64-bit
      • Bangla Lion
      • ~18 kBps
      • ~6 kBps
    Dhaka, Bangladesh, Bangladesh
    Default high CPU temperature due to "system" running in task manager....plz helpppp
    the system run by NT Kernel & System ............consumes avrg 25% of my CPU causing my PC core temperature around 60........Click image for larger version.
ID:	15509Click image for larger version.
    Default Re: high CPU temperature due to "system" running in task manager....plz helpppp
    Quote Originally Posted by aallvveeee View Post
    i think its virus, try to clean it through scanning the HDD in another computer with updated anti-virus or reinstall the windows..
      • Sapphire HD5770
      • A4 TECH MOP-70D
      • Thermaltake 430W
      • Smart Centra
      • Windows 7 64-bit
      • Bangla Lion
      • ~18 kBps
      • ~6 kBps
    Quote Originally Posted by musvi View Post
    ami AMD Catalyst Software Suite 11-11 install korar por thekei arokom hocche......
    akhon ki kora jay???
    first uninstall Catalyst and see if the condition is restored or not.if everything is normal then probably its because of a bug in the software.
      • Sapphire HD5770
      • A4 TECH MOP-70D
      • Thermaltake 430W
      • Smart Centra
      • Windows 7 64-bit
      • Bangla Lion
      • ~18 kBps
      • ~6 kBps
    Quote Originally Posted by offcutter View Post
    uninstall korar por temp thik koyeche......system o 0% or 1-2% hoy....
    but abar install korar por abaro temp + system % 25% hoye giyeche....
    ami previous version of Catalyst Manager use korte chacchi na....
    • abir's Gadgets
      • Realtek Builtin Audio
      • Creative Inspire 2.1
      • A4tech 7K Office (USB)| HP
      • Deluxe DLP 388A 450W
      • 4GB Apacer Pendrive
      • OVO 650VA
      • Smile Internet (Bronze)
    abir's Avatar
    Azimpur
    From where did u download it?
    ATI site?
    You can try downloading from alternate link :S
    I bleed red, Man Utd 4ever..
    Download one from AMD site if not fixed then use an older version nothing to do.
    Poor Driver coding by AMD.
      • Sapphire HD5770
      • A4 TECH MOP-70D
      • Thermaltake 430W
      • Smart Centra
      • Windows 7 64-bit
      • Bangla Lion
      • ~18 kBps
      • ~6 kBps
    AMD site theke abaro download kore install korlam.....eki problem.....
    amar banglalion connection manager problem kore.......manager diye connect kore rakhle temp bere jay....connect kore task manager diye off korle abar thik hoy.......(auto connect hole temp bare na,auto connect hole task manager eo wcm.exe thake na)
    ...........ahon ki kkora jay???
    keu help korben???
ID:	15581   Click image for larger version.
    • TheNutKicker's Gadgets
      • Intergated
      • Intel Core 2 Duo T6500
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • Genuine Vista 64 Bit
      • 10
      • 138
    TheNutKicker's Avatar
    yes i also use banglalion and cm.exe PRODUCES ALOT OF HEAT AND CPU Usage so after u log on kill the cm.exe and dont worry it wont log you out but if you lose connection youll have to log in again,enjoy.
      • Sapphire HD5770
      • A4 TECH MOP-70D
      • Thermaltake 430W
      • Smart Centra
      • Windows 7 64-bit
      • Bangla Lion
      • ~18 kBps
      • ~6 kBps
    but abarer somossa hocche task manager e "Process>System" e "System" 25% CPU use kkorche..........ajonno temp beshi......ami ageo task manager theke wcm.exe kill kortam but tokhon "System" 0/1% thakto............
    kindly ektu last 2ta picture dekhen.....abar ajonno temp beshi hocche............CPU & GPU mone hoy co-relate korte parche na.......
    *new symptom dekha dilo.....windows update hocche na....
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Do a malware bytes scan,and delete any kind of virus and if theres 2 virus called online gameware/spyware leave it as it is and dont delete it its needed for banglalion to run.
      • Sapphire HD5770
      • A4 TECH MOP-70D
      • Thermaltake 430W
      • Smart Centra
      • Windows 7 64-bit
      • Bangla Lion
      • ~18 kBps
      • ~6 kBps
    Quote Originally Posted by TheNutKicker View Post
    http://www.tomshardware.co.uk/forum/...power-question or http://linkhide.in/proxy/browse.php?...c3Rpb24%3D&b=5
    ami control panel theke power management Balanced change kore Power saving korlm..//////......
    but tobuo idle obosthay/simple kaj korte thakle temp 60up thake.....
    *power DVD diye kono video chalale GPU load 0% thake.......vlc diye chalale up down hoy....(2,5,7,20.....etc etc thake........mostly 2/3 thake)
    new amd catalyst manager e GPU'r load ta CPU'r processor carry kkore.........GPU kono load e nicche na....!!!!!
    • shohag2018's Gadgets
      • Gigabyte H55M-USB3
      • Intel Core i7 860 OC'[email protected] 3.5ghz (TT Frio OCK).
      • a-DATA 8GB 1333MHz
      • Samsung evo 250gb SSD+1 TB 7200rpm
      • Zotac GTX 970 OC
      • Sony Bravia 26inch
      • Creative 5.1 ll Nokia BT stereo 503 ll Nokia BT Stereo 505
      • A4tech bloody b314
      • A4tech bloody v3m
      • Xbox 360 wired original
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Windows 10 pro x64
      • Cinebench r15- 600, Unigine valley- 54fps
      • Going under renovation, Next is CPU-mobo!
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    @aallvveeee dosto apatoto 11.10 install diye dakho system usage kome kina, jodi kome then wait for 11.12. it ll be out soon. jodi tao nai hoy tahole mone hoy amd cpu gpu er oi jinis bondho korar way ber korte hobe.
    ---------- Post added at 23:49 ---------- Previous post was at 23:38 ----------
    ar jodi tao downgrade korte na chao, taile aita dekhte paro- 11.12 beta-
    http://www.mediafire.com/?x1odw5itznt76oh
    tateo kaj na hoile go back to 11.9, the most stable driver in recent history.
      • Sapphire HD5770
      • A4 TECH MOP-70D
      • Thermaltake 430W
      • Smart Centra
      • Windows 7 64-bit
      • Bangla Lion
      • ~18 kBps
      • ~6 kBps
    problem solved......
    matro solve kkorlam.........
    just BIOS e giye amd cool&quiet auto ta change kore enable kore dilam....(jodio ager catalyst manager e khub somvoboto auto kora chilo but temp barto na)
    akhon system1%
    but onek gula svchost.exe (atake ignore korlam.... )
    ati avivo enable korar ki kono dorkar ache???Click image for larger version.
Name:	ati avivo.png
    http://forums.amd.com/game/messagevi...hreadid=116888
    Quote Originally Posted by Max Handler View Post
    http://game.doomforge.com/?raf=ZC42ODYyNjc= looking for cool gaming.
    ? Play this one now!! And reach to lvl 10 to gain rewards. Have fun!! TIP: When creating ur Char. Choose the Seal for Faster exp.
    Who is this guy burging in every thread trying to hijack the thread?
      • Zotac GTX 970 OC
      • A4tech bloody v3m
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    akhon system1%
Name:	ati avivo.png
    good problem solved ! windows install kora onek pera..
      • Sapphire HD5770
      • A4 TECH MOP-70D
      • Thermaltake 430W
      • Smart Centra
      • Windows 7 64-bit
      • Bangla Lion
      • ~18 kBps
      • ~6 kBps
    Quote Originally Posted by shohag2018 View Post
    hmmm.........koto software install dite hoy.....diye abar update.......amnei net speed er jei obostha!!!
    kichu kichu software ache , install korci .....but naam e vule geci....(jemon:windows on howar somoy login screen change hoy, but naam ta vule geci......use korchi )
    ---------- Post added November 26th, 2011 at 12:15 ---------- Previous post was November 25th, 2011 at 18:12 ----------
    _ akhno prob solved hoy nai........
    ajke sokale pc on kore dekhi abaro aki problem........
    cool and quiet enable/disable/auto kore dekhlam..........temp kome na!!!
    kono software probably ata kortece.......malware+avg scan dicchi......dekha jak ki hoy>> > > > > > > > > > _
    scan kore dekhlam......kono kaj hoy nai......
    software e prob thakle bios e geleto ttemp kom thakar kkotha......but windows e thaka kale temp joto thake BIOS e geleo eki thake......>> > > > > > > > >
    HASAN er HD ta amar kache ache......last vorosha = oor HD tate new windows install kore dekhi ki hoy..> > > > > >
    ---------- Post added at 16:18 ---------- Previous post was at 12:15 ----------
    ami abar pagol hoye jabo.....................
    avg diye scan kore (normal scan) jokhon anti-rootkit ta scan dilam, tokhon dekhi temp kome gece.......restart diye dekhi temp kome gece..> > > > >
    CSE te jara pore , tara kivabe sustho thake ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ?
      • Zotac GTX 970 OC
      • A4tech bloody v3m
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    khek khek...last condition ki? thik ase akhon?
    tomar nia akta Thermaltake frio kena dorkar.
      • Sapphire HD5770
      • A4 TECH MOP-70D
      • Thermaltake 430W
      • Smart Centra
      • Windows 7 64-bit
      • Bangla Lion
      • ~18 kBps
      • ~6 kBps
    akhon prob thiik hoice.........virus prib chilo most probably........
    kichu kichu virus mone hoy kichu software chalaye system25% kore rakhe......
    frio kenar taka nali.....
      • Zotac GTX 970 OC
      • A4tech bloody v3m
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    jomaite thako. frio market e asteo deri ase.
  1. Replies: 5
    Last Post: October 28th, 2011, 14:08
  2. Replies: 0
    Last Post: October 28th, 2009, 04:21
  3. Replies: 0
    Last Post: October 27th, 2009, 21:00
  4. [DailyTech] AMD 6-core "Thuban" CPU Confirmed
    By RSS Bot in forum Tech News
    Last Post: September 22nd, 2009, 21:31
  5. Replies: 2
    Last Post: May 4th, 2009, 23:18
Page generated in 0.32814 seconds with 15 queries.
