Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 51
Thread: Urgent help !! Gpu temp go to max auto :( :(
    Default Urgent help !! Gpu temp go to max auto :( :(
    hi bros, bishal ekta bipode pore post korlam, urgent help needed
    nfs the run kheltesilam, 3 no. stage load howar tym hotat game ta hang krlo. game close korlam. then agn game start korlam , hotat suni sho sho awaj cpu theke, thn game start howar por dekhlam gpu temp 100 te uthe jacce
    thn vablam driver prob, driver re-install krlam, no solve. thn vablam nfs a prob, thn jekono game chalaya dekhi same obsta , gpu temp and usage 100% hcce , bt 100% usage howar kno karon e nai ,ageo chalaisi tkhn fifa 12 max temp 78, r nw 100teo chle jay. i mean jkno game chalailei eta hcce. matha pura nsto. gpu ta valo mto clean krlam, no solve. edike jkhn pc start kori , starting obstay emn sho sho awaj kore, mne hcce je full usage hoy, abr jkhn windows load cmplt hoy thn awaj bndho, temp o nrml . sob milaya ja ta obsta, ki krmu kisu bujhtesina. xp/ win7 sob khanei erkm hcce,i tested.hd movie thik mtoi chole.
    so bros, plz ki krmu kow , amr hd 5770 , eita gele gaming lifer ekhanei end
    heeeeeeeeeeelllllllllllllllllpppppppppppppppppp !!!!!
    ---------- Post added at 23:55 ---------- Previous post was at 23:22 ----------
    @abir @@nonymous @sadi_warhead @dipanzan @kung fu panda_4444
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    Default Re: Urgent help !! Gpu temp go to max auto :( :(
    kon model?gpu fan ghure?casing e air flow normal?warranty ase?na thakle heatsink khule thermal paste check & change koro...
    Ati hd 5770, fan speed o 100 te uthe, warnty nai
    ---------- Post added November 19th, 2011 at 00:02 ---------- Previous post was November 18th, 2011 at 23:58 ----------
    game open korle 100% usage howar karon ki? tachara pc start up a gpu full speed a run korar rohossoi ba ki? hotat korei ei prb !
    Shob game ei 100% usage? Tahole GPU ta khule arekta PC te test kore dekhar uchit age before you do anything else.
    idle :
    while gaming : (full speed fan sound also )
    Idle e keno 850MHz? :S Amar mone hoi na card er shomossha. Check in another PC if you can.
    ---------- Post added at 00:14 ---------- Previous post was at 00:13 ----------
    Oh and did you check for dust?
    idle er oi pic ta wrong chilo, 850mhz core clock, dust pura saf korsi, game open holei usage 100% , and fan speed er sho sho awaj start
    Try re installing the drivers. Your card is not clocking down (p-states) in 2D(idle). While, a game can stress a GPU to 100%, though what resolution & settings are we talking here ?
    You can try it with a GPU stress test, download MSI Kombuster. Stress your GPU for 20-30mins, & then let it idle by closing the program. Check using GPU-Z, if the card is clocking down or not. To me, it seems more of dust clogging airflow inside your card.
    EDIT: Yes, the fan speed will ramp up when the GPU is stressed 100%, you can create an additional fan profile under CCC, or using an after market utility: MSI AfterBurner. These programs will allow you to custom set a fan profile, so that it initiates at specific temperatures. Like having a fan speed of 75% at 70C ?
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    Quote Originally Posted by saif View Post
    *gpu ta ki 2nd hand ??? recently apni ki clean korar jonno gpu open korsilen(problem suru hoar age)?
    seems like damaged/faulty resistor/capacitor/VRM/heatsink/fan etc....once i had same type of problem with a gigabyte 5670 in case of dropping down it from my hand when cleaning...
    1.5 YR use krsi new, ajkeo to khelsi onekkhn sob thik thak, bt sndhay ei prblm hotat kore hlo , nw am tensed, is it repairable if any fault
    prb howar por gpu ta hate niye dust gula clear korsi, plastic cap ta uthai nai, upor diye valo mtoi clean krsi heatsink, nw ki kri, keykbr driver install dilam no change. jehetu start up er time eo fan full speed a sound kortese (jeta age hoy nai) so gpu'r external prb?
    • Hemlock's Gadgets
      • ASUS P7P55D
      • Core i5 750 @ 3.81 GHz + Prolimatech Megahalems (Nidec Beta V Intake + Rosewill RFX120BL Exhaust)
      • 2X2 GB A-DATA XPG DDR3 @ 1520 MHz, 8-8-8-20 @ 1.55V
      • 500GB Samsung F3 + 250GB Hitachi Deskstar
      • Gigabyte HD5970 @ 850/1150 + XFX 9800GT for PHYSX
      • Samsung 22" 2233SW
      • VIA VT1828S
      • Gigaworks G500, HS-1000 X-fi Fatality USB Headset
      • A4Tech Generic
      • A4Tech XL747-H
      • ASUS 750W U-75HA || TT Spedo Advance Package || 4 X 12" Logisys Blue CCT
      • ASUS 22X DVD-RW
      • A4Tech XL-747H
      • Micro 2000VA - Failed
      • Windows 7 Ultimate 32bit Build 7600, 4GB Unlocked
      • 28363 3d Mark Vantage Score with cat 10.5, 31K possible with cat 10.6
      • ANUBIS 970 - "The Beast Unleashed"
    Hemlock's Avatar
    Jun 2010
    Muhammadpur,Dhaka
    First thing first, put a check mark on "continue refreshing........" in GPUZ to monitor realtime clocks and temps. Apni to realtime temps dekhtei pacchen na when gpuz is a background app.Ths is prolly a driver issue, apps lik furmark/kombuster and games lik crysis/bfbc2 will stress yr gpu 100%, most others like dirt/nfs will not. What's happening here seems more like a bug/driver flaw that's stressing yr gpu unnecessarily. Turn on vsync in the games that run with more than 60fps and report back.
    Core i5 750 @ 3.81GHz | Prolimatech Megahalems Rev.B + Nidec Beta V + Rosewill RFX-120BL
    ASUS P7P55D |
    Gigabyte HD5970 @ 850MHz/1150MHz + XFX 9800GT for PHYSX
    2X2GB A-DATA DDR3 XPG @ 1520MHz, 8-8-8-20 | Samsung F3 500GB + Hitachi Deskstar 250GB
    Samsung 2233SW | Gigaworks G500 | Creative HS-1000 X-Fi Fatality USB Headset
    TT Spedo Advanced Package + 4X12" Logisys Blue CCT + Delta XTREME Airflow
    | ASUS 750W
    @Hemlock @@nonymous @dipanzan @Mazhar @error @aayman_farzand @Mohiuddin
    ki je hoitese bujtesina, gpu driver onkber install korlam, bt game start korlei stress 100% a chole jaitese,pc startup a gpu fan full speed a choltese ...
    Please stop randomly tagging. This is not Facebook.
    • TheNutKicker's Gadgets
      • Intergated
      • Intel Core 2 Duo T6500
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • Genuine Vista 64 Bit
      • 10
      • 138
    TheNutKicker's Avatar
    This. I Laughed My ****** ¤¤¤ of at this.
    oops, asole tnsn a aci,so.....
    • error's Gadgets
      • None ; 18x DL SuperDrive
      • Mac Pro love.
      • 1 mbps
      • 1 mbps
    error's Avatar
    Boo.
    Did you try any other game than this?
      • A4Tech KRS-86
      • Antec VP450P
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    itz repairable. perhaps PCB change kora lagte pare(if its not something driver related)....anyway whats your PSU?
    • Hemlock's Gadgets
      • ASUS P7P55D
      • VIA VT1828S
      • A4Tech Generic
      • A4Tech XL747-H
      • ASUS 22X DVD-RW
      • A4Tech XL-747H
    Hemlock's Avatar
    Jun 2010
    Muhammadpur,Dhaka
    Quote Originally Posted by @nonymous View Post
    PCB keno change kora lagbe? For no good reason 100% usage hole software related error hobe, hardware hobar kotha na.
    ASUS P7P55D |
    | ASUS 750W
    prob ta kothay kew bujhte parla?
    ekhane koyekta point dei :
    1.prob ta hlo any game start korlei gpu usage 100% or kachakachi chole jacche,fan sppeed o 100% max uthe, temp o 95c uthe jay. but idle temp 52c.
    2.pc start er time a fan besh jore ghure jeta age hoy nai. bt windows load hole fan speed kme awaj o kme jay.
    so what s the prb?
    1. thermal paste issue? thn why fan speed up at start up? and idle temp even down to 48c.
    2. fan is moving,so fan is ok.
    3.game in running well,no stuck,lag,freez issue. bt the prob is gpu goes 100% usage (any game) temp ~100c.
    4.i clear the dust from gpu,bt dnt open the plastic cover.
    5.psu issue?
    6.hd movies runs well without temp prob.
    7.install fresh windows, dirver today, no change of prob.
    8.is it bios prob :o i dnt knw .
    so what is the exact prob going on? reply asap before any bad happen
    @@nonymous @error @Hemlock
  1. URGENT GPU Buying Help!!
    By Frank3nst3in in forum Help - General Shopping
    Last Post: June 2nd, 2011, 23:33
  2. Replies: 14
    Last Post: April 4th, 2011, 16:44
  3. Replies: 9
    Last Post: April 15th, 2010, 19:57
  4. GPU temp increased
    Last Post: April 9th, 2010, 12:40
  5. Need help abt GPU(urgent)
    By Red Devil in forum GPU
    Last Post: April 24th, 2009, 12:06
Page generated in 0.32107 seconds with 15 queries.
