Results 1 to 8 of 8
Thread: Help with nvidia control panel interface.
    • shohag2018's Gadgets
      • Gigabyte H55M-USB3
      • Intel Core i7 860 OC'[email protected] 3.5ghz (TT Frio OCK).
      • a-DATA 8GB 1333MHz
      • Samsung evo 250gb SSD+1 TB 7200rpm
      • Zotac GTX 970 OC
      • Sony Bravia 26inch
      • Creative 5.1 ll Nokia BT stereo 503 ll Nokia BT Stereo 505
      • A4tech bloody b314
      • A4tech bloody v3m
      • Xbox 360 wired original
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Windows 10 pro x64
      • Cinebench r15- 600, Unigine valley- 54fps
      • Going under renovation, Next is CPU-mobo!
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    Default Help with nvidia control panel interface.
    i Just switched from AMD to nvidia... and its been a long time.
    i see there are few options in the nvidia control panel,for example-
    options such as- "ambient occlusion" cant be set to "application controlled". its either on or off. im confused, so if its set to off (which is default), it cant be turned on from in-game settings? TIA.
    set everything to application controlled.... but you can set force anti aliasing and many things to games that dont have those features... tag aayman to know more info... he uses nvidia inspector to force stuff
      • Zotac GTX 970 OC
      • A4tech bloody v3m
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    Quote Originally Posted by furiousTaher View Post
    i every option dont offer the slectable "application controlled" thats my point.
    tagging @aayman for help.
ID:	37116Click image for larger version.
    There you go!
      • Zotac GTX 970 OC
      • A4tech bloody v3m
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    @redwan hasan to be clear, so if ambient occlusion is turned off in global settings,and HBAO+ is selected inside Farcy 4's ingame settings, it ll be actually turned off? because visually it looked to me as if the game overrode the global settings!
    also, on the flip side, as shown in your pics above, the FXAA turned on in global means, fxaa will always be turned on ingame, even if its disabled in the game settings?
    Edit: nevermind i guess, i could keep the global settings, and tweak the game specific profile for each game.. still seems like an extra workload compared to amd cards.. oh well, may be ill get used to it.
    As you can see AA Transparency is off yet I can use MSAA in games and has effect, so I'm sure games can override. I had to use specific game profile only for the one to turn off SLi for specific game.
    'Off' only means that the NVCPL won't override the games settings, so by default it is application controlled (everything is). They really should just change the title.
      • Zotac GTX 970 OC
      • A4tech bloody v3m
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    Makes sense now. Thanks.
  1. PCI-E x1/x2 Network Interface Card
    By CvP in forum Others PC Hardware
    Last Post: July 3rd, 2012, 23:29
  2. LSI Announces SAS 12 Gb/s Interface
    By salmanshah in forum Tech News
    Last Post: November 28th, 2011, 02:13
  3. Replies: 6
    Last Post: December 13th, 2010, 16:45
  4. How to Try the New Google Search Interface
    By coldfire7 in forum Internet
    Last Post: November 27th, 2009, 12:27
  5. Control Panel Missing :S
    By Hamilton in forum Technical Support
    Last Post: July 20th, 2009, 12:00
Page generated in 0.20680 seconds with 15 queries.
