Thread: CPU cleaning with Air Compressor
    • Mahdi's Gadgets
      • Biostar Hi-Fi Z77X in Thermaltake Dokker (with 120mm intake and 140mm exhaust fan)
      • Intel Core i5 2400 3.1 GHz with Cooler Master Hyper 212 Evo
      • 2X8GB Team Dark DDR3 OC 1600 MHz
      • Samsung 850 Evo 250GB SSD + 2TB HDD
      • Asus DCII Top 560 GTX
      • Dell S2240L 1080p 22 inch display
      • Realtek Built-in Hi-Fi chip
      • Microlab 5.1
      • Logitech K270 Wireless
      • A4Tech X7
      • XBox 360 Controller for Windows
      • XFX Pro Edition 650 Watt
      • Samsung 24x DVD-RW
      • ADATA 1TB Portable Drive
      • 1200 VA
      • Windows 10 Professional x64
      • Gets the job done.
    Dec 2011
    Default CPU cleaning with Air Compressor
    As the title suggest, does any of you have any experience with cleaning your CPU using an air compressor? Blowers seem to leave a thin residue of dirt in CPU and components inside it. On the other hand, Portable Compressed Air Canisters are pretty costly for regular use. So, stumbling YouTube, I found out couple of videos showing using an Air Compressor to clean CPUs. Popular YouTube channels like LinusTechTips also has videos showing the use of Air Compressors (link:https://www.youtube.com/watch?v=W9T6WGFmam0). Here is one from another channel: https://www.youtube.com/watch?v=9NnbrfDiL94
    So, any comments or suggestions on that? Plus, any idea from where in Dhaka I can get a good Air Compressor at a reasonable price or do I need to bring one from abroad?
    N.B.: Since, this post isn't entirely technical the forum moderator can move it to appropriate section if he or she wishes.
    You can look for air compressor in AC and fridge repair shops. But personally I feel safer using a 1 inch paint brush with blower than using high pressure jet of compressed air.
    • MusharratC's Gadgets
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
      • Gigabyte Pulse 650W
      • Dead Powertree 1250VA
      • An ALMOST decent rig!
    MusharratC's Avatar
    Feb 2013
    U can also look into auto repair shops. But I guess those compressors will be pretty expensive too. And high power air compressor can easily blow of a cap or two. So u needa be really carefull using that.
    Quote Originally Posted by MusharratC View Post
    You will never be able to blow off a cap with jet air . Try pulling out a CAP from a dead pcb with your hand. But small smd resistors can be blown away easily when jet air is used on a old pcbs or pcbs that usually goes through cycles of hi/low temp. Since many of these SMD components are already in brittle condition.
    So yeah gentle brushing with soft long bristle is safe.
      • MSI 990FXA G65
      • Asus VX229
      • Prachin JVC UX T1
    MusharratC's Avatar
    Feb 2013
    Asholeo? Honestly didn't know. Someone told me long ago that this might happen! Was too young too believe whatever I was told. Thanks for letting me know bhai.
    And sorry OP, for the wrong info.
  1. Where can I get a dust blower for cleaning PC?
    By radeef in forum Help - PC Buying
    Last Post: May 19th, 2014, 21:48
  2. Which shop to go in IDB for cleaning Laptop Fan
    By TheNutKicker in forum Technical Support
    Last Post: March 24th, 2014, 15:37
  3. Gpu cleaning
    By DarkMan in forum GPU
    Last Post: June 29th, 2011, 00:00
Page generated in 0.82710 seconds with 14 queries.
