Thread: need HELP about overclocking e7200
    • banglabro's Gadgets
      • Gigabyte G41MT
      • Intel Core 2 Duo e7200 2.53ghz OCd @3ghz
      • 4gb ddr3
      • 160GB SATA
      • Sapphire ATI Radeon HD 5670 1GB DDR5
      • Sony Bravia KLV32..
      • On board Realtek
      • Xbox 360 Wireless controller
      • 430W
      • DVD+RW Benq
      • Windows 7
      • Aging pc..need to upgrade soon...
      • 64
    banglabro's Avatar
    May 2011
    Sylhet
    Default need HELP about overclocking e7200
    ok..here it is..i have DG31 mobo..which has no bios support for overclocking..i am using setFSB to overclock..can some one tell me how to use it? ami 5(top bar) increase korar ektu por amar computer hang hoy jae..NOT full hang..coz i can move the mouse..but nothing else..
    Default Re: need HELP about overclocking e7200
    it is not recommended to overclock cpu from other then Bios....and if ur motherboard is Intel made then i its impossiable and another thing G31 chipset is not built for overclock.
      • Gigabyte G41MT
      • 4gb ddr3
      • 160GB SATA
      • On board Realtek
      • 430W
      • DVD+RW Benq
      • Windows 7
      • 64
    banglabro's Avatar
    May 2011
    Sylhet
    is it totally impossible? software overclock ki useless? ami mobo kinte parbo bole mone hoe na..nevertheless overclock friendly LGA 775 socket MOBO er price koto hobe?
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    Quote Originally Posted by banglabro View Post
    yah.... it's hardly possible & don't try it again.it may cause serious damage...you will get g41 mobo's starting from 3k...all of them will allow you to OC except the intel boards.......
    if u want to overclock a little get G31/41, if u want to oc moderately get P/G33/43(up to fsb 415 and in some case 420mhz) and if u want to oc insanely get G/P 35/45 or X48(fsb 420mhz+)
    now all these Intel chip-sets i mentioned must have to be in non intel Motherboard, i hope u get it..
  1. Replies: 5
    Last Post: January 16th, 2011, 03:07
  2. Sale (Used) Core 2 Duo E7200
    By EBL.Mantis in forum Shop - Gadgets
    Last Post: December 9th, 2010, 21:52
  3. Closed E7200+G31+4GB RAM+HDDs-HD 4850
    By Uchiha Obito in forum Shop - Gadgets
    Last Post: May 8th, 2010, 22:01
  4. factory overclocking vs. own overclocking ?
    By Leaving BG in forum GPU
    Last Post: April 20th, 2009, 01:45
Page generated in 0.17589 seconds with 14 queries.
