Thread: Hdds keeps on dying one after another. Mobo problem?or PSU?
    • shohag2018's Gadgets
      • Gigabyte H55M-USB3
      • Intel Core i7 860 OC'[email protected] 3.5ghz (TT Frio OCK).
      • a-DATA 8GB 1333MHz
      • Samsung evo 250gb SSD+1 TB 7200rpm
      • Zotac GTX 970 OC
      • Sony Bravia 26inch
      • Creative 5.1 ll Nokia BT stereo 503 ll Nokia BT Stereo 505
      • A4tech bloody b314
      • A4tech bloody v3m
      • Xbox 360 wired original
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Windows 10 pro x64
      • Cinebench r15- 600, Unigine valley- 54fps
      • Going under renovation, Next is CPU-mobo!
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    Default Hdds keeps on dying one after another. Mobo problem?or PSU?
    my lil brothers very upset about his PC. bechara got an old PC off abbu's office, and upgraded almost everything, except for a gigabyte 954 mobo, and a chinese PSU.
    but now this is the third HDD in a row that died in it. all have the same issue, gets detected in the bios but wont boot up. clicking sound from the HDD can be heard from outside.
    all the HDDs died in the same manner. at first they'd work fine. then, occasionally they wont boot, but upon changing the SATA port they would boot up just fine. but after a couple of days..nothing, just a black screen where its supposed to show the windows logo..(but the HDDs do not get burnt, still detected in bios).
    now i figured since only these two things (psu and mobo) remained from the old PC, one should be the culprit. anyone ve had similar experience could help perhaps?
    ---------- Post added at 01:45 ---------- Previous post was at 01:23 ----------
    dont get a lot of response here around in the tech forums, mentioning @aayman_farzand @pollob.codename13 @anik_lc if u dont mind.
    Default Re: Hdds keeps on dying one after another. Mobo problem?or PSU?
    Most probably due to the PSU. If the PSU gives too little or too much volts to the hdd it could die.
    • knroeoueqisk's Gadgets
      • Intel Core i5 750
      • Cosonic head phone
      • Perfect keyboard
      • Delux optical mouse
      • Normal Non brand gamepad
      • Thermalake TR2 500 watt
      • Samsung 22X Dvd Writer
      • i am happy with it.
      • 15 Kilobytes - 64 Kilobytes
      • 5-15 kilobytes
    Dec 2009
    Psu er dam to kom compared to motherboard age psu tai change kore deka jaite pare.
      • Zotac GTX 970 OC
      • A4tech bloody v3m
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    hmm..but SATA port change kore dile abar chole (b4 its totally damaged).. ait keno hoy bujhlam na..
      • Intel Core i5 750
      • Perfect keyboard
      • 5-15 kilobytes
    Dec 2009
    tomar PC er psu ta tomar choto vaier pc te lagaia chalai dekte paro problem solve hoye gele bujba je tomar vaier pc er psu faulty.
    or
    tomar pc te tomar choto vai er HDD ar PSU lagaia chalai dekte paro koekdin.
    obboso tomar powerful graphics card 5850 kule niba age nai le burn korte pare oita weak+faulty psu er karone.
    ar ete jodi problem na hoi tai buja jabe je motherboard er problem ar jodi problem hoy taile buja jabe je psu ta nosto or problem ase.
    The sound may not indicate it's dead, it typically happens when the hdd first spins up. Judging from the symptoms, I'd say it's the PSU. It's not being able to maintain a constant flow of current and is forcing the HDD to spin up, again and again.
      • Zotac GTX 970 OC
      • A4tech bloody v3m
      • Corsair VS 650W
      • Samsung dvd-rw
      • Transcend 8GB.
      • Apollo 1200VA
      • Aftab IT
      • 4 mbps
      • 4 mbps
    shohag2018's Avatar
    Jan 2010
    Quote Originally Posted by Wintereise View Post
    makes sense what u said, but i actually tried that last HDD in my Computer as well, as a secondary drive, windows wudnt boot up. the moment i disconnected the faulty disk, it booted fine.
    i also tried the first of the Hdds, connecting to the computer with an R-cable, as in external USB drive. the drive is detected in windows, but any attempt to copy or paste any files wud show long Estimated time, and then ultimately stops with an error message.
    one thing though, none of these harddrives were brand new.. but each one was in functional state when they were first installed into the system.
    ---------- Post added at 19:08 ---------- Previous post was at 18:54 ----------
    i ve browsed a bit, and it seems that clicking noise is a classical sign of dying HDDs --
  1. Sale (Used) Complete CPU for 6K
    Last Post: November 6th, 2011, 12:57
  2. Replies: 49
    Last Post: September 22nd, 2011, 18:06
  3. Sale (Used) C2D PRO, Gigabyte Mobo and Feel 4 700w psu
    By Ic3_STrik3R in forum Shop - Gadgets
    Last Post: December 25th, 2009, 23:23
  4. Closed Graphics CARD+PSU+MOBO
    By Speed in forum Shop - Gadgets
    Last Post: November 13th, 2009, 17:21
  5. Replies: 28
    Last Post: November 8th, 2008, 16:24
Page generated in 0.19595 seconds with 14 queries.
