Results 1 to 8 of 8
Thread: Getting around the infamous "Connection reset by peer problem"
    Default Getting around the infamous "Connection reset by peer problem"
    Hello there,
    Someone requested me to make a thread pointing out possible ways of getting around this problem. I'm going to do just that.
    The first way is buying/finding a socks v5. However, there's a common problem with this if used with private trackers. Whether you'll get banned or not depends on if someone else is already using that proxy (Provided you just decided to find one in the inet) in that tracker already. You'd do well to buy a private proxy to eliminate those risks. You use the proxies like this,
    (You should be able to do that without needing any help whatsoever, this is basic)
    Single proxy services usually are cheap, 400~500 BDT/mo is more than enough to get one. If you need help buying one, pm me, I can probably get you one.
    Second way is buying complete vpns, these are the things to get if you have other stuff than just this torrent crap to get around. Examples include getting around BTCL's famous SRCDS/UDP packet drop issues or routing via a specific gateway. You don't need these to just get around this torrenting problem, but they're handy to have. Typical price for one is in the 1k/mo or so range, comes with 25 servers in 25 countries enabled. Typical example of this is Overplay, which me and CvP both utilize. I can help you to buy one of these as well.
    There are free vpns around that let you do this as well. But they're often bandwidth capped and include time constraints. Still, if you're just a casual user, you may choose opting for them. The IP thing probably applies here too, since free stuff attracts the wrong type of customers.
       6
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Default Re: Getting around the infamous "Connection reset by peer problem"
    what option would u suggest for private tracker leeching/seeding just enough to deal with the current torrenting situation ?
       0
    What I screenshotted should work just fine.
       0
    • S_F.darkzone's Gadgets
      • Gigabyte EG43m-S2H
      • Intel Core 2 Duo 2.66ghz
      • 4 gb twinmos 800 bus
      • 1 tera western digital x2,250gb samsung x1
      • 9600 GT Alpha Dog Edition
      • Dell 23'' full hd
      • Hyundai CjC-960
      • xbox-360 wired controller
      • Thermaltek 420w
      • I don't freaking own a optical drive
      • Windows 7 ultimate pirated edition,yes pirated
      • BCube
      • 120
      • 64
    S_F.darkzone's Avatar
    Nikunjo 2,Dhaka
    firstly thanks,
    secondly I gotta read the post first
    Live with life in your blood,Die with honor in your name.
       0
    • faisal.amir.bd's Gadgets
      • ABIT IP35 Dark Raider
      • Intel Core 2 Duo [email protected]
      • 2GB Transcend AxeRam DDR-2 800+ @816MHz
      • 820GB (320GB Hitachi, 500GB Samsung)
      • Gigabyte Radeon HD5770 1GB DDR5 (Batmobile Cooler)
      • ASUS MS228H 1080p LED backlit
      • Creative Sound Blaster Live! 5.1
      • Creative Inspire 5200 (5.1)
      • XBOX 360 wired gamepad
      • Thermaltake TR2 600W
      • Rahim Afrooz 1000VA
      • Windows 7x86
      • 180kBps [1.5Mbps]
      • 180kBps [1.5Mbps]
    faisal.amir.bd's Avatar
    Atlanta
    Torrents seem to be working fine on my BDCOM connection at work. Hopefully I'll be able to breathe a sigh of relief when I get home tonight. In the mean time, thanks for your offer to help @Wintereise . It's good to know you have an option when things turn to $hit.
       0
    Appears to be fixed, actually. But yeah, this should serve as a reference should this happen again.
       0
    • emucop's Gadgets
      • Abit IP43
      • Intel Core 2 Quad Q6600 2.4GH
      • 4 GB Transcend
      • 1TB WD+320GB samsung
      • ATI 4850
      • Samsung 20 lcd
      • 7.1 bilting
      • 2.1 creative
      • A4tech
      • A4tech glasser
      • Tharmaltack 600w
      • 1 gb kingston
      • Win 7 64bit , Win xp
    emucop's Avatar
    Chittagong road , narayangonj
    12 .30 pm sunday. Ok bro problem solved. all tracker r online. I think btcl sloved there problem. I m downloding right now.
       0
    This has now been fixed, locking threads as they no longer serve any purpose
       0
  1. Replies: 30
    Last Post: October 22nd, 2011, 10:44
  2. Replies: 2
    Last Post: April 22nd, 2010, 18:47
  3. the new blockbuster from sony "infamous"
    By CHR.Overload in forum PlayStation
    Last Post: May 31st, 2009, 18:39
  4. Replies: 2
    Last Post: May 4th, 2009, 23:18
  5. x-box360 "screen freez" problem......
    By GT3600 in forum XBOX
    Last Post: April 26th, 2009, 19:37
Page generated in 0.19896 seconds with 14 queries.
