Results 1 to 16 of 16
Thread: Need Help... how to copy games inside Ipod?
    • Rumen's Gadgets
      • Gigabyte GA-EP45-UD3RL
      • Intel Core 2 Quad Q9400 2.93 ghz(OC)
      • 3 GB 1333 mhz DDR3
      • Samsung 320 gb HDD
      • Xfx 5850 1 gb DDR5 BLACK edition
      • Samsung 2243 1920x1080 HD LCD monitor
      • built in Realtek
      • Cosonic CD-721MV
      • xbox 360 controller
      • Coolermaster 600 watt ati xfire certified(italy)
      • ASUS 16x DVD Rom
      • 2 and 16 GB Pendrive
      • Name onek boro, lekhte parbona
      • Windows 7 nd xp
      • 7.1 in Windows 7 index(sometimes 7.2)
      • 2009-2013 porjonto valo vabe game khelte parlei hoy.
      • SMILE
      • 30-35 kBps normal and 200kBps-7MBps from local torrents.
      • 30-40 kBps normal and 150-500 kBps from local torrents
      • 9
    Rumen's Avatar
    Azimpur
    Default Need Help... how to copy games inside Ipod?
    I Have Opened This Thread On Behalf Of @FǀL$ . He Is Facing Some Problem With His Ipod.
    He have a set-up a wifi connection in his home...with that he connected his ipod wid it...everything worked perfect...then he went to download "ibooks" then he clicked on install...then it told "to login or create a apple id" he had his apple id but when he gave his pass n id n logged it...it said "that u have to review ur id again" there only two options "ok" or "cancel" i clicked ok...then it took him to a page..where he had to give his billing details..n select my country...oikhane Bangladesh nai....tai Canada diye try korse (as it was bought frm there) oikhane upore e lekha je credit card no.,gift card or certificate dile cholbe...but He couldnt find any options for gift card or cerficate...shudu credit no. dawa chilo (which he dnt have Bcoz he is underaged..) ar oita na fill up korle he cant install any apps. ki korte hobe, he need help.......
    So Experienced Vaiera Amar, Chele take keo ektu Help Koro.
    Anywhere Anytime Anytask
    Nothing but Excellence
      • MSI GS60
      • Intel(R) Core(TM) i7-5700HQ CPU @ 2.70GHz
      • 16 GB
      • 128 GB SSD / 2 TB HDD
      • Nvdia GT240 1 GB / Amd Radeon HD 7250 (Laptop)
      • 15.6" Full HD eDP Wide View Angle
      • SteelSeries
      • Thermaltake Ventus R
      • Windows 8 64 Bit
      • Verizon
      • 100 mb/s
      • 100 mb/s
    FǀL$'s Avatar
    Sep 2009
    NYC
    Default Re: Need Help... how to copy games inside Ipod?
    need help every1...
    will i have to jailbreak it ??
    Oct 2011
    Dhanmondi
    okay apnake first apple id khulte hobe...etar jonno apni itunes e jeye j kono ekta free app e click koren....erpor oi free app download forte hole apnake login forte bolbe n tokhn apni create new apple id te click korben. country select korben US.erpor jokhon apnake payment medium dite bolbe select "none". ar address site hobe US er...jono kono US address dilei hobe.i would suggest apni j mono US university (e.g. stanford univ or UC at Berkeley ) er website e giye odr contact address diye new account create korben.then u can download all the free apps(legit)...but if u plan to buy any paid items as i had to do once for OS X update then i would suggest u to buy apple itunes US store gift cards,good news they are available in BD (gadget n gear/executive machines)
    i am assuming u need help only in creating valid apple id. if u need to jailbreak plz mention ur iOS version after that i can help u further. Hope it helps :-)
      • MSI GS60
      • 16 GB
      • SteelSeries
      • Windows 8 64 Bit
      • Verizon
      • 100 mb/s
      • 100 mb/s
    FǀL$'s Avatar
    Sep 2009
    NYC
    ur the best it worked....thnx a lot... i dnt knw wat to say..
    ami ipod theke direct app install disi...oi prob solved...
    ---------- Post added at 22:11 ---------- Previous post was at 22:02 ----------
    bro but kisu games amr age theke ase for ipod like pes 2011 oita import kore sync dile bole... authorize this computer... kintu akber to korsi wen installing ibooks..akhon ki korbo??
    ---------- Post added at 22:27 ---------- Previous post was at 22:11 ----------
    free apps chara jegula apps amr kase ager theke ase...oigula dilei authorize korte bole...like Pes11,flick soccer,moto gp 2010 aigula authorize kemne kori ??
    Oct 2011
    Dhanmondi
    ekethre apni j email id use kore apple id create korechen oi email diye apnake apnar computer authorize korte hobe.etar jonno itunes er store=>authorize this computer e click kore apnar new previously created apple id ta use korun. now u can just drag the games to iTunes & have them synced.u can authorize max 5 computers with same apple id. so i would suggest u do have two apple id's (as i have). Here the initial assumption again is that ur iPod is jailbroken. if not then its high time u do so :-)
      • MSI GS60
      • 16 GB
      • SteelSeries
      • Windows 8 64 Bit
      • Verizon
      • 100 mb/s
      • 100 mb/s
    FǀL$'s Avatar
    Sep 2009
    NYC
    ok...trying it...
    ar jailbroken korle ki ami kokhono aita baire use korte parbonah??? i mean US or Canada...
    ar jailbroken ki prob hoi??
    ---------- Post added at 19:45 ---------- Previous post was at 09:03 ----------
    jailbreak korte koto lage...ar oita korle ki shob prob solve hobe??
    Oct 2011
    Dhanmondi
    jailbreak e kono prob nai eta amadr desh e kortei hoi...unless u are willing to buy apps/games from apple.ar JB korle sob deshei chalano na.kono prb hoi na ar iDevice er full feature unlock kora jai. ar JB er jonno kono dokan eo jawar drkar nai....do some net search in google in see some JB videos in youtube we will be good to do it by yourself. i did it myself on my iPhone which also relays on unlock(though it is not your case)...u r on much safer side regarding JB.thats why i asked for ur iOS version. go to settings->generals->version. its very easy.so i would suggest take a day or two have some research on the net.build up ur confidence then if u need any help u know where to knock :-)
      • MSI GS60
      • 16 GB
      • SteelSeries
      • Windows 8 64 Bit
      • Verizon
      • 100 mb/s
      • 100 mb/s
    FǀL$'s Avatar
    Sep 2009
    NYC
    thnx bro....i will JB it myself...did u use redsnow or something else?? ar JB korle ki apps bhorar shomoy ar authorize korte hobenah...?? thnx again
    Oct 2011
    Dhanmondi
    authorize always korte hobe. redsn0w is now a good tool for JB. JB korle onno third party website theme iApp namiye easily sync kore use korte hoi. after jb search on google "how to sync pirated games on iPod" u will have the steps there. but before JB i would suggest u should have a wifi in ur house or go to a friends place or any place with wifi. if u can't have any of those then theres still a way :-) but i won't complicate things by discussing it right now first do the JB
      • MSI GS60
      • 16 GB
      • SteelSeries
      • Windows 8 64 Bit
      • Verizon
      • 100 mb/s
      • 100 mb/s
    FǀL$'s Avatar
    Sep 2009
    NYC
    i have wifi connection in my home....n the prob i face now is that wen i download free apps like skype,msn,yahoo,ibooks...it gets downloaded and runs perfectly...but when i give PES11,motogp or another .ipa which i did not download via itunes...they want to authorize those files...how do i authorize them??
    Oct 2011
    Dhanmondi
    have u jailbroken yet? if yes then search how to add pirated Apps in iPod in goggle.u will have to add some sources in cydia n install some tweaks.if you have not jailbroken yet then unless u do so u can't play those game :-)
      • MSI GS60
      • 16 GB
      • SteelSeries
      • Windows 8 64 Bit
      • Verizon
      • 100 mb/s
      • 100 mb/s
    FǀL$'s Avatar
    Sep 2009
    NYC
    my experiment on JB starts today then...
    ---------- Post added October 25th, 2011 at 17:09 ---------- Previous post was October 24th, 2011 at 19:26 ----------
    can u give me a good link frm youtube for jailbreaking my ipod 4G iOS4.3 ar redsnow ki je kono ver. use korle..cholbe..naki video te jeta diye korse..sheita...??
      • MSI GS60
      • 16 GB
      • SteelSeries
      • Windows 8 64 Bit
      • Verizon
      • 100 mb/s
      • 100 mb/s
    FǀL$'s Avatar
    Sep 2009
    NYC
    i decided not to JB... ill buy apps wid card..not that i got it...
    Oct 2011
    Dhanmondi
    if u want....then ok. but JB is not about putting pirated/unofficial apps but its about unlocking the full potential of ur iDevice :-P
      • MSI GS60
      • 16 GB
      • SteelSeries
      • Windows 8 64 Bit
      • Verizon
      • 100 mb/s
      • 100 mb/s
    FǀL$'s Avatar
    Sep 2009
    NYC
    ar ki ki potential ase i dnt knw.. plz tell me??
      • MSI GS60
      • 16 GB
      • SteelSeries
      • Windows 8 64 Bit
      • Verizon
      • 100 mb/s
      • 100 mb/s
    FǀL$'s Avatar
    Sep 2009
    NYC
    bro how i can download the firmware 4.3.3 size onk boro...
  1. ipod/iphone/ipad Apps & games
    By Md.Rezwanul Haque in forum Mobile Gaming
    Last Post: September 14th, 2011, 17:12
  2. Looking For Some OLD PS3 Copy Games . . .
    By GalibZ in forum PlayStation
    Last Post: July 8th, 2011, 11:20
  3. Replies: 1
    Last Post: August 27th, 2010, 03:56
  4. Want to Exchange Ipod USB Cable with iPOD Earphones
    By Hamilton in forum Shop - Gadgets
    Last Post: July 14th, 2009, 10:42
  5. How to Copy Tunes/Videos from iPod Direct to PS3
    By FARHAN-FX in forum PlayStation
    Last Post: April 20th, 2009, 22:23
Page generated in 0.29009 seconds with 15 queries.
