Results 1 to 20 of 33
Thread: Temperature & voltage Problem in Gigabyte HD 5670
    • s.s.shuvo's Gadgets
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • G.SKILL FORTIS 16GB (2 x 8GB) DDR4 2400
      • Samsung 850 EVO 2.5" 250GB Sata III SSD
      • MSI GeForce GTX 1060 Aero ITX 6GB
      • Dual ASUS VN248H-P IPS 23.8" 5ms (GTG) with Mounted on VESA stand
      • Topping D30 DAC > Schiit Magni 3 headphone amp, xDuoo TA-01 DAC/Amp combo (Tube)
      • Polk Audio T15 through Nobsound TPA 3116 amp, Philips SHP9500, Monolith M1060 Planar
      • Generic Backlit
      • Rapoo Vpro
      • SeaSonic M12II 620 EVO Bronze 620W (Full Modular)
      • Sokol game motamuti chole r ki
      • Spectrum Time Warners Cable
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    Default Temperature & voltage Problem in Gigabyte HD 5670
    Hello everyone.
    I have a gigabyte HD 5670 gddr5 1gb card. It was perfectly normal few days ago. Idle temperature was around 40c, & load temp around 60-65c with catalyst control center autotuning. But a strange thing happened right after installing windows 7 64b in the pc. The idle temperature jumped all the way to 60c, even under load condition, the temp remains the same.
    to be honest, I didn't watch the vcore reading before this problem. When this started, vcore reading in both idle & load condition is 1.1v. Except for the high temp reading, there is no problem. Every game runs fine, pc is 100% ok. But this constant high temp is somehow reducing the lifespan of the card.Thats why I am tensed.
    Why is this happening? & is there any way to solve it? I've searched in almost every hardware forum to get a solution. But came up with nothing.
    Past : Full time gamer - Part time others
    Present : Full time others - Part time gamer
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    Default Re: Temperature & voltage Problem in Gigabyte HD 5670
    Which catalyst version do u use?
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • Generic Backlit
      • Rapoo Vpro
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    11.8 . Is there anything to do with catalyst version?
    Most Probably a driver problem. Incompatibility between 64-bit OS n Catalyst may cause this. Did u install the 64-bit driver?
    vcore reading ki ageo 1.1v cilo..before installing win764b?then amr mone hoe eta reading a kono problem.
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • Generic Backlit
      • Rapoo Vpro
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    Quote Originally Posted by EyE SpeeD | DeViL View Post
    i've installed catalyst 11.8 64b .
    ---------- Post added at 16:25 ---------- Previous post was at 16:25 ----------
    Quote Originally Posted by offcutter View Post
    64b install korar aage kokhono voltage reading dekhi nai vai.
    try 11.7 drivers.
    amr mne hoe na temp a kono problem ace...as reading constant ace i guess eta temp read korar shomosha..onno kno software d a temp ta check kore dekle valo hobe
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • Generic Backlit
      • Rapoo Vpro
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    Catalyst control center, hwinfo64,hwmonitor, gpuz. sobgula diyei same result dekhay.
    ---------- Post added at 18:14 ---------- Previous post was at 16:40 ----------
    try 11.7 drivers.
    ok bro . I've downloaded older versions & I'll give them a try.
    Quote Originally Posted by little.shuvo View Post
    use driver sweeper boot into safe mode then remove the old drivers using driver sweeper then boot back to normal mode & install old drivers.
    • SadIkMahdI's Gadgets
      • Gigabyte B85M-D3H
      • Intel Core i5 4590 @ 3.30 GHz
      • 4x4GB G.SKILL Ripjaws Series 240-Pin DDR3 SDRAM 1600 Bus Desktop Memory
      • Western Digital WD10EZEX 1 TB | SanDisk 2.5" 128GB SATA III Internal Solid State Drive
      • EVGA GeForce GTX 750 Ti FTW Edition with ACX Cooling
      • Samsung SB19B300B 18.5 LED
      • Built in Realtech HD
      • Altec Lansing VS2621 2:1 Channel Speakers
      • Newmen E370 Illuminated Keyboard
      • Bloody V3
      • Original Microsoft Xbox360 Controller for Windows (Wired Black)
      • Thermaltake Litepower 500W
      • Samsung S-ATA TrueDirect Super WriteMaster
      • SanDisk Ultra USB 3.0 Flash Drive 32 GB
      • Windows 7 Ultimate 64 Bit
      • 5.3 @ Windows 7 Benchmark
      • long way 2 go..
      • B.Net
      • 2.5 Mbps
    SadIkMahdI's Avatar
    Why dont u try 64bit 11.9?
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    Don't use driver sweeper.
    Just simply uninstall the 11.8 from the 'uinstall programs' , restart,the install 11.7 or 11.9whql....
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    Hello everyone.
    whats your gpu usage in idle and fan speed at idle/load???....1.10v is 5670's defult vcore so its OK...60c is quite safe but constant in both idle/load is very interesting....did u change fan speed from bios???
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • Generic Backlit
      • Rapoo Vpro
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    ok vai. Driver sweeper is a bit of complicated. Avoid korai better.
    ---------- Post added at 18:41 ---------- Previous post was at 18:39 ----------
    Quote Originally Posted by @nonymous View Post
    at idle, gpu use is 0~3% & fan speed 59% constant. at load, fan speed remains the same. I didn't do anything with the card except for opening the heatsink & cleaning it.
    I really don't get it at all.
      • A4Tech KRS-86
      • Antec VP450P
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    that means the problem appeared just after you've cleaned the heatsink ??? anyway reinstall driver & see what happens.....
    Sigh. Poor thermal contact.
    Here's what you need to do:
    a) Open the heatsink again
    b) Clean it again and remove the thermal compound (Paste) on the fan side with pure (or well, as close to pure as possible) isopropyl alcohol. Do not use water.
    c) Reapply thermal paste
    d) Tighten it firmly.
    Refrain from taking the cooler apart again. That's it. This is not a driver problem.
      • A4Tech KRS-86
      • Antec VP450P
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    Quote Originally Posted by Wintereise View Post
    lol...you quated my post for for @little.shuvo. it was just my question & he hasn't replied yet.....probably it's not the actual problem...
    ya u shud've mentioned it b4. anyway follow wintereise's suggestion.
    • Hemlock's Gadgets
      • ASUS P7P55D
      • Core i5 750 @ 3.81 GHz + Prolimatech Megahalems (Nidec Beta V Intake + Rosewill RFX120BL Exhaust)
      • 2X2 GB A-DATA XPG DDR3 @ 1520 MHz, 8-8-8-20 @ 1.55V
      • 500GB Samsung F3 + 250GB Hitachi Deskstar
      • Gigabyte HD5970 @ 850/1150 + XFX 9800GT for PHYSX
      • Samsung 22" 2233SW
      • VIA VT1828S
      • Gigaworks G500, HS-1000 X-fi Fatality USB Headset
      • A4Tech Generic
      • A4Tech XL747-H
      • ASUS 750W U-75HA || TT Spedo Advance Package || 4 X 12" Logisys Blue CCT
      • ASUS 22X DVD-RW
      • A4Tech XL-747H
      • Micro 2000VA - Failed
      • Windows 7 Ultimate 32bit Build 7600, 4GB Unlocked
      • 28363 3d Mark Vantage Score with cat 10.5, 31K possible with cat 10.6
      • ANUBIS 970 - "The Beast Unleashed"
    Hemlock's Avatar
    Jun 2010
    Muhammadpur,Dhaka
    If the fan speed and temps at idle and load are same the problem you most probably got there is that your GPU is not switching to lower (2D) clocks when it is in idle state. It could happen for a number of reasons. First thing you should try is another set of drivers and uninstall afterburner if you have it installed.
    Core i5 750 @ 3.81GHz | Prolimatech Megahalems Rev.B + Nidec Beta V + Rosewill RFX-120BL
    ASUS P7P55D |
    Gigabyte HD5970 @ 850MHz/1150MHz + XFX 9800GT for PHYSX
    2X2GB A-DATA DDR3 XPG @ 1520MHz, 8-8-8-20 | Samsung F3 500GB + Hitachi Deskstar 250GB
    Samsung 2233SW | Gigaworks G500 | Creative HS-1000 X-Fi Fatality USB Headset
    TT Spedo Advanced Package + 4X12" Logisys Blue CCT + Delta XTREME Airflow
    | ASUS 750W
      • AsRock AB350 Pro4
      • AMD Ryzen 5 1600
      • Generic Backlit
      • Rapoo Vpro
      • 7500
      • 2500
    s.s.shuvo's Avatar
    Buffalo
    I've done exactly this three times. Only one problem, the thermal paste is a cheap one. It remains all the same.
    ---------- Post added at 01:05 ---------- Previous post was at 01:02 ----------
    Quote Originally Posted by Hemlock View Post
    There is no OCing softs like afterburner is installed. Its entirely in simple condition. I made not a single modification in any setup in bios or any software related to gpu.
    Actually, that card is not in my hand right now. My 2nd pc is outside home, I'll go there tomorrow & try all the suggestions. I'll post the results. & thanks for the suggestions brothers.
  1. Replies: 9
    Last Post: January 15th, 2012, 22:02
  2. CPU temperature problem again :(
    By Badhon_raj in forum Technical Support
    Last Post: April 16th, 2011, 18:54
  3. Closed HD 5670 Gigabyte for sale
    By S1 in forum Shop - Gadgets
    Last Post: July 31st, 2010, 22:58
  4. Closed Gigabyte HD 5670 1 GB GDDR5
    By Reon in forum Shop - Gadgets
    Last Post: July 25th, 2010, 15:43
  5. E5200 temperature problem
    By shahriar in forum CPU
    Last Post: June 8th, 2009, 12:00
Page generated in 0.31615 seconds with 14 queries.
