Results 1 to 12 of 12
Thread: [HELP] Headphone Repair.
    • NahyaN's Gadgets
      • Gigabyte H61M-S2V-B3/ Thermaltake Spacecraft VF-1 Chassis
      • Intel Core i5 2400 with Coolermaster Hyper 212 EVO
      • TeamElite 8GB (2 x 4GB) DDR3 1600MHz
      • Samsung 500GB (Primary)/ WD Caviar Green 2 TB (Storage)
      • Sapphire Radeon R9 380X Nitro
      • Samsung 19 Inch LED Monitor
      • AudioTechnica ATH-M40X
      • A4 Tech Multimedia Keyboard
      • Logitech G402
      • XBox 360 Controller
      • Delta 550w
      • LiteOn DVD-RW 22X
      • Transcend 250GB Portable HDD
      • Seren1ty gets the job done. Period.
      • Earth Telecommunications
      • ~2 Mbps
      • ~2 Mbps
    NahyaN's Avatar
    Feb 2009
    Default [HELP] Headphone Repair.
    So the left ear on my headphones do not give out sound any more. Right ear works fine.
    When I twist the wires near the left ear sometimes sounds comes sometimes it doesn't.
    But for the last 3 days no sound comes out of left ear at all no matter how much twisting I do.
    Looked at some videos on YouTube. Seems like an easy fix. But I am not sure where the problem actually is.
    Is it the wires or the magnetic speaker itself.
    Was hoping if someone could take a look and tell me if I could do anything to fix the problem. Thanks alot.
    • TaherTheRetard's Gadgets
      • CONSOLE MASTER RACE
      • 136
    Khilgaon
    u need multimeter to check wire and driver both, if u near mirpur i can help u.
    • Trave160's Gadgets
      • MSI B350M Mortar AM4
      • AMD Ryzen 5 1600
      • 16GB DDR4 3000Mhz
      • 3TB Western Digital red
      • ASUS Strix GTX 960 4G
      • Dell S2216H 22 Inch monitor
      • Logitech Speaker
      • TtEsports Knucker
      • PS4 Dualshock 4 controller
      • Pendrive 4GB
      • NunuCom Ltd, Penus group
      • Super San 200kbps
      • 105*2
    Trave160's Avatar
    A Secure Area
    I can vouch for Reed's repair, I got my Skullcandy and Razer Mouse fixed over there
    • NahyaN's Gadgets
      • Logitech G402
      • Delta 550w
      • LiteOn DVD-RW 22X
      • ~2 Mbps
      • ~2 Mbps
    NahyaN's Avatar
    Feb 2009
    Quote Originally Posted by Asif_R View Post
    I have access to a multimeter. Could you give a brief description as to how I should check wire/driver?
    Thanks for the responses. Got in touch with the guy at Reed's Repair. I hope its just a wiring issue and that the drivers are not dead.
    Edit:
    Would this be a good methodology?
    http://www.wikihow.com/Measure-Speaker-Impedance
    Quote Originally Posted by NahyaN View Post
    Edit:
    The methodology that is described on wiki-how is really nice.
    U should have good knowledge on headphone wire connection. Wire connection diagram is very simple for most of the HP. In most case there have 3 wire for HP (without mic), one for right driver, one for left driver and one common for both driver.
    1. Check continuity for the wires. If all the wires have continuity (impedance/resistance will be almost zero) then wire is good, if not then wire is bad, u need to change the wire.
    2. Check the continuity of the Driver (impedance/resistance will be more then 16-ohms, generally 32-ohms, check ur HP specification), if no impedance to the driver the driver is dead
    • Sybaris Caesar's Gadgets
      • Intel DH61WW B3 Rev.
      • Intel Core i5 2400 3.10 Ghz
      • Thermaltake Commander
      • Logitech G402
      • Original Xbox 360 Wireless
      • Cooler Master G550M
    Sybaris Caesar's Avatar
    Nowy Warsaw
    Atel polapain!!!
    My probable next build: Qisan MagicForce 68 (Outemu switch) / Teamwolf Zhuque+ 87 TKL (Outemu) / Monoprice Select series full size (Outemu/Gateron) / Drevo Gramr 84 TKL (Outemu) • Logitech G102 Prodigy • Deepcool Dukase V3 / Thermaltake Versa U21 • Superlux HD 681 • Creative Sound Blaster E1 • LG 22MP68VQ • SteelSeries QcK • Generic executive chair • others TBA
    djrock please don't bother me. You are in my ignore list so I don't have to see literal poop.
    Quote Originally Posted by Sybaris Caesar View Post
    Atel polapain!!!
    babu tumi ki kokhono on topic e thakte parba na?
    aar ei simple jinish janle kaure Atel boilo na, nijer nOObness re question koro.
    Inter 2nd year er physX thakle fail korba first 4 chapter, lab er kotha baad e dilam.
    Anyway on topic:
    Just try to figure out what has happened, a multimeter will come in handy here.
    Then try to repair it, try not to use regular soldering wire which might result in kinda bad quality audio.
      • Logitech G402
    Nowy Warsaw
    Anyway on topic:
    off topic:
    -_- one sentence: don't skip exams!!!
    What would be the best headphone within 2k?
    Quote Originally Posted by w20grippy View Post
    Xiaomi piston 2 earphones
    Quote Originally Posted by furiousTaher View Post
    Are headphone and earphone both the same thing?
  1. [Help]HDD repair
    By Mohiuddin in forum Technical Support
    Last Post: September 6th, 2012, 22:30
  2. Headphone buying + repair help
    By knroeoueqisk in forum Help - General Shopping
    Last Post: January 29th, 2012, 23:42
  3. Gpu repair
    By Raziel in forum GPU
    Last Post: October 21st, 2011, 19:15
  4. Repair GPU?
    By vergil007 in forum Technical Support
    Last Post: September 11th, 2011, 05:41
  5. Help!!!!where Can I Repair My Gpu????????
    By xk :: CranKpin in forum Technical Support
    Last Post: July 16th, 2008, 23:33
Page generated in 0.23069 seconds with 14 queries.
