Results 1 to 20 of 40
Thread: Project: Cable Management
    • RonzDrive's Gadgets
      • ECS H61H2-M2 B3 Stepping
      • Intel Core i3 2100 SB
      • Transcend 2x2 GB DDR3
      • Hitachi 500 GB SATA 2
      • ECS GTX 550 Ti 1 GB DDR5
      • Acer 18.5'' LED
      • Creative Inspire 2500 2.1
      • PS2
      • PS2
      • Tt TR2 RX 450W (Modular)
      • External
      • Windows 7 Ultimate (64-bit)
      • 3DMark 11 Score P2740
      • Happy with it
    RonzDrive's Avatar
    Default Project: Cable Management
    Cable management is a part of hardware modding and important to keep PC neat,cool and retain its efficiency. Heavy cable mess as we all know hampers proper airflow inside the chassis which triggers PC hardware overheating, thus reducing their valuable lifespan. Being a part of hardware modding its also an art. With very little air ventilation and huge cable mass inside a PC, cooling fans cant use their full potential properly for aiding at PC cooling.
    There are lots of excellent and useful topics and discussions about hardware modding and cable management here in BG, and in this particular thread about cable management, we can share our skills and experiences regarding this matter, this way less experienced PC user can be benefited from more experienced PC users.
    Note:
    Any pics regarding cable management are welcome. Ratings(out of 10) on projects can be applicable by members. Advises,suggestions and comments are also appreciable as far as no off topic. Feel free to share.
    • Dee's Gadgets
      • Asus Maximus VIII Ranger
      • Intel Core i5 6600k
      • Dell S2216H
      • Cooler Master V650 Gold
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Default Re: Project: Cable Management
    My idea: Hiding unnecessary cables in empty drive bays, and routing all other cables behind the motherboard tray.
    This was with my old shitty PSU, the new one has more cables, it's impossible to make it look good without extension cables so I'm not posting the new pics.
      • Acer 18.5'' LED
      • PS2
      • PS2
      • External
      • Happy with it
    RonzDrive's Avatar
    Heres mine. Haven't done much except taping some power supply cables. I tried my best to routing psu and casing cables behind the mobo tray to look it a bit cleaner.
    Cable management: Before and After
Name:	Resize of 09062011837.jpg
ID:	13170   Click image for larger version.
Name:	Resize of 04062011911.jpg
      • Acer 18.5'' LED
      • PS2
      • PS2
      • External
      • Happy with it
    RonzDrive's Avatar
    @Dee very nice cable management, very neat. 9/10.
    Same here, my cable management was better then this in the previous case(could hide the psu wires behind mobo tray), but not with this case and psu, the cables are just too short.
    my cable management pic updated....
    • Dee's Gadgets
      • Dell S2216H
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Quote Originally Posted by RonzDrive View Post
    Thanks, I give you 6/10. You can still make a lot of improvements.
    • war1oc's Gadgets
      • Gigabyte H55M-USB3
      • Intel Core i5 760
      • 2 x 2GB 1333 Mhz
      • Samsung Spinpoint F3 [HD103SJ/B] 1TB
      • Leadtek GTX 560Ti cooled with Arctic Cooling accelero Twin Turbo II
      • Viewsonic VX1937
      • A4Tech HS-800
      • A4Tech XL-747H
      • XFX pro 650w
      • Apollo 800 VA
      • Windows 7 32-bit
    war1oc's Avatar
    Oct 2009
    Attachment 0Click image for larger version.
    advices are highly appreciated
    • Camouflage's Gadgets
      • Gigabyte Sniper B5 B85
      • Core i5-4460 3.2Ghz with Deepcool Mini Cooler in Thermaltake 'Versa-2'' Case
      • Corsair Vengeance DDR3 1600Mhz 2*4gb
      • WD Blue 1TB 7200rpm
      • MSI Gtx770
      • Samsung 22'' Wide Screen LED-1920*1080
      • Creative Sound blaster Audigy 2ZS
      • Microlab 5:1
      • HP keyboard
      • A4Tech X7 XL-747H Spider
      • Corsair-HX650W-52A in single 12V Rail with 4 (6+2) pin connectors
      • HP DVD writer
      • Transcend Jetflash-16gb & Sandisk Cruzer 4gb
      • Apollo 1200VA
      • Windows-7-64 bit Ultimate Edition
      • Pro-7.6,GPU-7.9-Windows7 benchmark
      • Satisfied what i have
      • Dhakanet,1mbps
      • 128 kbps
    Camouflage's Avatar
ID:	12987Click image for larger version.
ID:	12988Click image for larger version.
    Thanks to Dee for this cable managements.
      • Acer 18.5'' LED
      • PS2
      • PS2
      • External
      • Happy with it
    RonzDrive's Avatar
    @war1oc you can hide those psu cable behind the mobo tray if there is enough space, and the CPU power cable seems long enough so you can also route the CPU power cable behind the mobo tray and connect that over the mobo(my psu cables are too short to do that). your rig overall looks nice, btw whats that case?
    • war1oc's Gadgets
      • Intel Core i5 760
      • 2 x 2GB 1333 Mhz
      • Viewsonic VX1937
      • A4Tech HS-800
      • A4Tech XL-747H
      • XFX pro 650w
      • Apollo 800 VA
      • Windows 7 32-bit
    war1oc's Avatar
    Oct 2009
    @RonzDrive
    case: armor a60
    etai problem, cable gula onek kahini korar cheshta korsi, but kichui korte partesi na. ato cable dise!! ar mobo 24 pin ta route kora possible na, onek beshi mota -_-
    onno cable gula route korbo as u said behind the tray but cable ties nai, kinte hobe koyekta.
    • LizZzaRd's Gadgets
      • Asrock p67 fatal1ty performance series.
      • Core i5 2500k 3.30 Ghz.
      • 4x2=8 gig Ripjaw [1600 Mhz]
      • WD Blue 2TB, Samsung 1 TB[sata],Samsung 40GB[IDE], Zotack 128gb SSD
      • LeadTek 650Ti Boost 2GB
      • LG 22" LCD
      • On board.
      • Microlab 2:1/SteelSeries 7H fnatic edition
      • Corsair K65 RGB
      • Logitech 402 with SS QcK , Razer goli League of legends edition surface & SS Diablo 3 edition
      • PS2 Controller.
      • XFX pro core series:450watt.
      • Asus DvD rom.
      • A4 tech:Webcam,AData CH11 1TB[USB 3.0].
      • DigitalX.
      • Win 10 x64
      • Processor:7.5; Ram:7.8; Gpu:7.7; Hdd:5.9
      • If there's anythin exists on planet after my parents and gf,then my pc'll come first.
      • Next Gen
      • 130+
      • 80+
    LizZzaRd's Avatar
    Dhaka.
    want suggestion or advice to manage my cable..but there's some info about my case,
    There's no route to bring this cable from behind the mobo tray.so now what should i do with this??
      • Acer 18.5'' LED
      • PS2
      • PS2
      • External
      • Happy with it
    RonzDrive's Avatar
    ^ mentioning @Dee
    also check out my cable management pic is there any improvement i can do, suggestion needed.
    • Dee's Gadgets
      • Dell S2216H
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    Quote Originally Posted by th3_arm0r View Post
    Bring the Optical drive at the lowest bay, and put all other cables in the three upper bays. If you are worried about how the optical drive would look in the lowest bay, do a stealth mod. And use the zip tie that was provided with the PSU to tie all the unnecessary cables.
      • LG 22" LCD
      • On board.
      • Corsair K65 RGB
      • PS2 Controller.
      • Asus DvD rom.
      • DigitalX.
      • Win 10 x64
      • Next Gen
      • 130+
      • 80+
    LizZzaRd's Avatar
    Dhaka.
    @Dee ,take a look.already ami unused cable zipped kora.and please tell me something about STEALTH MOD in detail ...
    • Dee's Gadgets
      • Dell S2216H
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
    @th3_arm0r , have a look at this pic and follow the instructions. After you're done, post another pic. And about the stealth mod, perform a google search and you're gonna find hundreds of tuts on how to do it.
    • Dee's Gadgets
      • Dell S2216H
      • Link3 GATI
      • 2Mib/s
      • 2Mib/s
    Dee's Avatar
ID:	13567Click image for larger version.
ID:	13568Click image for larger version.
ID:	13569Click image for larger version.
ID:	13570Click image for larger version.
ID:	13571Click image for larger version.
      • Acer 18.5'' LED
      • PS2
      • PS2
      • External
      • Happy with it
    RonzDrive's Avatar
    @Dee your cable management looks better then before with the xfx powersupply unit
    if the interior were black, it would look even better in my opinion.
    hows your CPU and GPU idle and load temps?
    • Rubab's Gadgets
      • Gigabyte B85M-D3H
      • Intel Core i5 4570 3.2GHz
      • G.SKILL Ripjaws (2 x 4GB) DDR3 1600 Bus
      • Samsung 840 Evo 120 + Samsung HD103SJ 1TB
      • Sapphire Dual-X R9270X 2GB
      • Benq V2220HP
      • Realtek HD Built-In
      • Creative 2:1
      • Ortek Multimedia MCK-800
      • Logitech HD Optical Mouse
      • Corsair CX600
      • Lite-On DVD-RW / Asus-DVDROM
      • Power Tree 1250P Offline UPS
      • A decent rig. :)
      • NOT Link3
    Rubab's Avatar
    Apr 2009
    Wow, that looks really neat. Etaki pray shob casing ei kora jabe, naki nirdishto kichu kichu casing e kora jay?
    A. Degrading fellow human beings over the internet is the only way for social rejects to feel any sense of empowerment whatsoever
    B. If one party understands something that the other party doesn't, degrading that person leads to an enhanced self-perception of intelligence
    C. The internet is a clear depiction of our natural aggression towards each other as a species, that will undoubtedly wipe itself off the planet at some point in time.
    • faisal.amir.bd's Gadgets
      • ABIT IP35 Dark Raider
      • Intel Core 2 Duo [email protected]
      • 2GB Transcend AxeRam DDR-2 800+ @816MHz
      • 820GB (320GB Hitachi, 500GB Samsung)
      • Gigabyte Radeon HD5770 1GB DDR5 (Batmobile Cooler)
      • ASUS MS228H 1080p LED backlit
      • Creative Sound Blaster Live! 5.1
      • Creative Inspire 5200 (5.1)
      • XBOX 360 wired gamepad
      • Thermaltake TR2 600W
      • Rahim Afrooz 1000VA
      • Windows 7x86
      • 180kBps [1.5Mbps]
      • 180kBps [1.5Mbps]
    faisal.amir.bd's Avatar
    Atlanta
    Quote Originally Posted by Dee View Post
    I hate you! Eto kom wires ki bhabe thake!
    • emroz_2272's Gadgets
      • Xonar STX
      • Microsoft Sidewinder X4
      • Samsung 24x DVD-RW
      • Acme 1000VA
      • Windows 10 Professional x64
      • Not into benchmarking!
      • Makes me delirious! :) :p
      • Agni Online 3/6 Mbps
    emroz_2272's Avatar
    Gulshan, Dhaka
    @Dee
    hard drive cage kibhabe ghuraiso bhai???
    Quote Originally Posted by Ruβαβ View Post
    Casing, casing interior and PSU wiring er upor nirbhor korbey.
    Corsair PSU diye eto neatly wire lukano jai na -- oigular shaap-er moto taar ar connectors thakey.
  1. Cooling fans & Cable Management : A guide for Noobs by a Noob
    By s.s.shuvo in forum Hardware Modding
    Last Post: September 16th, 2011, 16:28
  2. Awsome cabe management and paint job
    By musvi in forum Hardware Modding
    Last Post: July 26th, 2011, 20:25
  3. Web Browser Showdown: Memory Management Tested.
    By salmanshah in forum Tech News
    Last Post: June 9th, 2011, 21:05
  4. My final year project submission _ Project Paharpur
    By ArchQuad in forum Programming
    Last Post: February 12th, 2011, 22:39
Page generated in 0.32829 seconds with 15 queries.
