Results 1 to 20 of 24
Thread: AMD PHENOM II x4 955 BE Stock Heat-sink noise problem !! :(
    • s.a_rocky's Gadgets
      • Gigabyte 970 A- DS3p
      • AMD PHENOM II X6 2.8Ghz [6Cores]
      • 4GB + 4GB +8GB TWINMOS 1600M DDR3
      • 1TB WD EZEX +1TB WD EZEX + 750GB Hitachi
      • Sapphire Radeon R7 260x OC 2GB DDR5
      • Dell FHD 22"
      • Built-in REALTECH HD
      • Delux DLX X501: 60W 2:1
      • A4tech A-Shaped Multimedia
      • NewMan 5x
      • Micro Kingdom Xbox Like Dualshok Gamepad
      • Thermaltech Lite Power 450W
      • Asus DVD RW 24X/Hp DVD rw
      • USB MULTI HUB+ Apacher 32GB USB 3 Flash Drive
      • PCPOWER 1200VA
      • Windows 10 Pro X64Bit
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    Default AMD PHENOM II x4 955 BE Stock Heat-sink noise problem !! :(
    Well, Here is my System Spec
    OS Windows 7 Ultimate x64
    CPU AMD PHENOM II X4
    Motherboard MSI p31
    Memory 4GB DDR3 1333
    SAMSUNG 1TB HDD
    Graphics Card Sapphire Radeon 4770HD
    Sound Card ViaTech HD Built in: with MICROLAB M-111 2.1 Speakers
    Monitor(s) Displays Greatwall 19" W & LG 15"W Parallel
    Screen Resolution 1400X900 & 1280X720
    the problem is, My stock CPU cooler gives noise during games and multitask.
    and the temp rises to 56 Degree and stays in 40-45 avg while no task is given.
    How can i reduce noise?
    or should i look for an aftermarket cooler?
    here is the stock cooler
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Default Re: AMD PHENOM II x4 955 BE Stock Heat-sink noise problem !! :(
    This cooler is awesome...dont need to change it.
    just tweek in your BIOS...you can reduce the noise significantly....one of my friends had the same problem.
    set the max fan speed to 50%-62.5% and the noise will go away.
    dont worry about the temp....yours is natural..this proc is gonna be golden even in 70C
    Once more into the fray
    Into the last good fight I’ll ever know
    Live and die on this day
    Live and Die on this day
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    Quote Originally Posted by Shamim_AX4_Rocky View Post
    Motherboard MSI p31
    SAMSUNG 1TB HDD
    from bios>HW monitor enable 'cpu smart fan' & set 'target temperature' at 60C....and turn on 'AMD cool'n quite' if it was disabled....
      • Dell FHD 22"
      • NewMan 5x
      • PCPOWER 1200VA
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    well i am using the MSI overclocking center from windows. which can set the game mood..
    can you show me the exact procedure of how to tweek the cpu fan speed from BIOS? my MOBO is MSI 760 GM P33
    ---------- Post added at 17:44 ---------- Previous post was at 17:33 ----------
    Quote Originally Posted by @nonymous View Post
    well, it worked dude.. but now my AVG temp is 45-50 and could not found the AMD COOL AND QUITE!
    • RonzDrive's Gadgets
      • ECS H61H2-M2 B3 Stepping
      • Intel Core i3 2100 SB
      • Transcend 2x2 GB DDR3
      • Hitachi 500 GB SATA 2
      • ECS GTX 550 Ti 1 GB DDR5
      • Acer 18.5'' LED
      • Creative Inspire 2500 2.1
      • PS2
      • PS2
      • Tt TR2 RX 450W (Modular)
      • External
      • Windows 7 Ultimate (64-bit)
      • 3DMark 11 Score P2740
      • Happy with it
    RonzDrive's Avatar
    I have the same mobo, and had the same noise issue from my CPU fan. here what i did to reduce the noise:
    in bios menu>HW monitor>CPU Fan target>(enabled @60)
    Cpu min fan speed @62.5%
    Cell menu> AMD cool'n'quite>enabled
    cool'n'quite mode is effective in power saver mode AFAIK
    in windows 7 user panel hardware and sound>power option>power plan>power saver mode(set the sleep and turn off display option to any custom settings)
    the noise should be low now and temps will be in reasonable state, mine is ~40C in idle and loads around ~60C while gaming while the little CPU fan spinning around 3.5k idle-4.5k load rpm(previously it even reached 6k rpm).
    hope this helps
    Salman bhaiya that cooler is too noisy, it reaches 7k RPM if a defined speed is not set! I still have mine max at 100%, since I game on headphones...but ammu majhe majhe bole, tor eta ki PC naki Jet engine xD
      • Dell FHD 22"
      • NewMan 5x
      • PCPOWER 1200VA
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    Quote Originally Posted by RonzDrive View Post
    hope this helps
    power saving mood reduces CPU working speed. games get slower then usual.. Hyper Browsing mood gets disabled. so i keep the HIGH PERFORMANCE MOOD.. and enabled the CPU FAN TARGET to 60.. but thanks for the add-on!
    • knroeoueqisk's Gadgets
      • Intel Core i5 750
      • Cosonic head phone
      • Perfect keyboard
      • Delux optical mouse
      • Normal Non brand gamepad
      • Thermalake TR2 500 watt
      • Samsung 22X Dvd Writer
      • i am happy with it.
      • 15 Kilobytes - 64 Kilobytes
      • 5-15 kilobytes
    Dec 2009
      • Acer 18.5'' LED
      • PS2
      • PS2
      • External
      • Happy with it
    RonzDrive's Avatar
    it is better to set cool'n quite to auto rather enabling it...if you directly enable it sometimes your cpu can be underclocked to protect itself from overheating under load...that means impact on game performence....but in auto mode it'll work only when it remains idle...
    OK, got it. Thanks for the info
      • A4Tech KRS-86
      • Antec VP450P
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    it is better to set cool'n quite to auto rather enabling it...if you directly enable it sometimes your cpu can be underclocked to protect itself from overheating under load...that means negative impact on game performence....but in auto mode it'll work only when it remains idle...
      • Dell FHD 22"
      • NewMan 5x
      • PCPOWER 1200VA
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    okey, lets see what i got!
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Set Amd Cool n quite enabled. kono problem hoy nai ei porjonto gaming e. here is my idle temp (lowest sighted 7 Degree idle & highest on load sighted 40 degree maybe mone nai)
    Oi person ta koi j amare giyan dichchilo j Cool 'n Quiet kono kajer na?
    Quote Originally Posted by hrishat View Post
    Incorrect reading, CPU temps can't go lower than ambient temperatures! 7C, is rather too cold here in BD
    I'd rather set that to "Enabled" ~ that way even if you OC, your CPU will get throttled, when idle! And CPU will only underlock if it's reaching too high temps, something like 85C+ & in this case, there's something wrong with either the cooler or too high OC. These Phenom-IIs work best at below ~75C, but the stock cooler can get noisy at times, if it's running at 100%.
    • Hemlock's Gadgets
      • ASUS P7P55D
      • Core i5 750 @ 3.81 GHz + Prolimatech Megahalems (Nidec Beta V Intake + Rosewill RFX120BL Exhaust)
      • 2X2 GB A-DATA XPG DDR3 @ 1520 MHz, 8-8-8-20 @ 1.55V
      • 500GB Samsung F3 + 250GB Hitachi Deskstar
      • Gigabyte HD5970 @ 850/1150 + XFX 9800GT for PHYSX
      • Samsung 22" 2233SW
      • VIA VT1828S
      • Gigaworks G500, HS-1000 X-fi Fatality USB Headset
      • A4Tech Generic
      • A4Tech XL747-H
      • ASUS 750W U-75HA || TT Spedo Advance Package || 4 X 12" Logisys Blue CCT
      • ASUS 22X DVD-RW
      • A4Tech XL-747H
      • Micro 2000VA - Failed
      • Windows 7 Ultimate 32bit Build 7600, 4GB Unlocked
      • 28363 3d Mark Vantage Score with cat 10.5, 31K possible with cat 10.6
      • ANUBIS 970 - "The Beast Unleashed"
    Hemlock's Avatar
    Jun 2010
    Muhammadpur,Dhaka
    Totally inaccurate readings. A common flaw in AMD CPU/mobos.
    Core i5 750 @ 3.81GHz | Prolimatech Megahalems Rev.B + Nidec Beta V + Rosewill RFX-120BL
    ASUS P7P55D |
    Gigabyte HD5970 @ 850MHz/1150MHz + XFX 9800GT for PHYSX
    2X2GB A-DATA DDR3 XPG @ 1520MHz, 8-8-8-20 | Samsung F3 500GB + Hitachi Deskstar 250GB
    Samsung 2233SW | Gigaworks G500 | Creative HS-1000 X-Fi Fatality USB Headset
    TT Spedo Advanced Package + 4X12" Logisys Blue CCT + Delta XTREME Airflow
    | ASUS 750W
      • A4Tech KRS-86
      • Antec VP450P
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    thats not cpu temperature...those are core temperatures. the TEMPIN0 in the screenshot indicates cpu/heatsink temperature which is 44C....usually core temperatures are pretty much difficult to report accurately....
      • Dell FHD 22"
      • NewMan 5x
      • PCPOWER 1200VA
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    Well HWmonitor reports CORE TEMPS are 0 C,
    and CPU TEMP is 51 C
    while OVERCLOCKING CENTER FROM MSI also SHOW 50 C Idle CPU temp.. while i start a game it maxed up to 56-57 C
    CPU FAN controller is set to min 60% [near 4500 RPM]
    AMD COOL n Quite is set to AUTO!!
    • Hemlock's Gadgets
      • ASUS P7P55D
      • VIA VT1828S
      • A4Tech Generic
      • A4Tech XL747-H
      • ASUS 22X DVD-RW
      • A4Tech XL-747H
    Hemlock's Avatar
    Jun 2010
    Muhammadpur,Dhaka
    They still aren 't supposed to be so highly inaccurate.
    Howevr, since the proc temp is 44, you may gues that the cores are at around 46-48C.
    ASUS P7P55D |
    | ASUS 750W
      • Dell FHD 22"
      • NewMan 5x
      • PCPOWER 1200VA
      • GAMINGzz PC
      • BROADBAND LOCAL
      • 300KBPS +
      • 100KBPS +
    s.a_rocky's Avatar
    Lakshmipur
    Quote Originally Posted by Hemlock View Post
    well, i never got a link that suggest a good temp for my cpu.
    and can i take a leap of faith by OC it??
      • A4Tech KRS-86
      • Antec VP450P
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    i haven't found a single software yet that can report accurate core temperature...almost all of them give me the same reading which are around 20C(my cpu temp remains 40-45C in idle) ...
    basically these softwares report somewhat like 15-20C less than the accurate temperatures......
  1. AMD Phenom II X6 1090T in BD
    By @nonymous™ in forum Tech News
    Last Post: March 29th, 2011, 00:50
  2. availability of phenom IIX4--955
    By pallab7 in forum Help - General Shopping
    Last Post: March 7th, 2011, 01:40
  3. AMD Phenom II X4 955 vs Intel i5
    By in_core in forum CPU
    Last Post: March 3rd, 2011, 17:50
  4. Heat sink for 8600GT
    By s.a_rocky in forum Miscellaneous Topics
    Last Post: June 25th, 2009, 10:44
  5. Replies: 0
    Last Post: April 30th, 2009, 01:16
Page generated in 0.33888 seconds with 15 queries.
