Thread: power supply
    Default power supply
    Recently i m trying to buy a casing.I want to buy thermaltake tr2 RX 650 watt.Is there any problem with it?Can i use graphics card like hd 6970?
    • Rajmi's Gadgets
      • MSI H61M-E33 [B3]
      • Corei5 2500k
      • GSkill Ripjaws 2x2 => 4gb
      • intel 3000
      • 19" LCD LG Flatron
      • Creative 2.1
      • A4tech slim
      • Delux T6 :: Dragon
      • Delta 550W
      • BTCL - ADSL
      • 64KBps
      • 15KBps
    Rajmi's Avatar
    Default Re: power supply
    http://extreme.outervision.com/psucalculatorlite.jsp
    p
    c'r config boshaye dekhe nen...ekta estimate paben
    Member Raa's Avatar
    Jul 2011
    Sylhet
    Quote Originally Posted by Spider72man View Post
    tr2 rx 650w will easily handle hd6970.
    • war1oc's Gadgets
      • Gigabyte H55M-USB3
      • Intel Core i5 760
      • 2 x 2GB 1333 Mhz
      • Samsung Spinpoint F3 [HD103SJ/B] 1TB
      • Leadtek GTX 560Ti cooled with Arctic Cooling accelero Twin Turbo II
      • Viewsonic VX1937
      • A4Tech HS-800
      • A4Tech XL-747H
      • XFX pro 650w
      • Apollo 800 VA
      • Windows 7 32-bit
    war1oc's Avatar
    Oct 2009
    Thermaltake TR2 RX 750 W is, according to our methodology, a flawed product that must be avoided at all costs. It can’t deliver its labeled wattage at high temperatures, but this is not the worst of it: ripple and noise level are way above the maximum allowed when you pull 80% or more from the unit’s labeled capacity (i.e., 600 W and above), overloading your components (especially electrolytic capacitors from the motherboard and video cards), which can cause your PC to present an erratic behavior (crashes and random resets) and, under extreme conditions, damage components.
    source: http://www.hardwaresecrets.com/artic...y-Review/902/9
    • emroz_2272's Gadgets
      • Xonar STX
      • Microsoft Sidewinder X4
      • Samsung 24x DVD-RW
      • Acme 1000VA
      • Windows 10 Professional x64
      • Not into benchmarking!
      • Makes me delirious! :) :p
      • Agni Online 3/6 Mbps
    emroz_2272's Avatar
    Gulshan, Dhaka
    recommending the xfx core edition 650W. Single rail design, non-modular, 80+ certified, quality product, enough to "SATISFY" a HD6970!
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    i also heard negative reviews about Thermaltake TR2 RX series. as emroz suggested, Xfx Core is the best. go for it.
    • war1oc's Gadgets
      • Intel Core i5 760
      • 2 x 2GB 1333 Mhz
      • Viewsonic VX1937
      • A4Tech HS-800
      • A4Tech XL-747H
      • XFX pro 650w
      • Apollo 800 VA
      • Windows 7 32-bit
    war1oc's Avatar
    Oct 2009
    the xfx core editions ones are truly amazing, moreover made by seasonic, i have a 650w core. and i can vouch for the quality!
  1. Power Supply Buying Help .
    By GalibZ in forum Help - PC Buying
    Last Post: August 30th, 2011, 15:41
  2. Replies: 21
  3. Best Power Supply
    By EBL.Mantis in forum Others PC Hardware
    Last Post: January 9th, 2011, 01:14
  4. Power supply
    By sameev29 in forum Others PC Hardware
    Last Post: May 28th, 2010, 00:23
Page generated in 0.18962 seconds with 14 queries.
