Results 1 to 14 of 14
Thread: PC sound problems HELP D:
    • Ehsas's Gadgets
      • MSI Z97-G45
      • Intel Core i7-4790K 4.0GHz
      • G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3
      • Seagate Barracuda 3TB/Samsung Evo Pro (1TB SSD)
      • EVGA Superclocked ACX GTX 980 dual SLI
      • LG 34UM95
      • Asus Xonar
      • Razer Kraken Pro (green)
      • Rosewill STRIKER RK-6000
      • perrix mx(old one) not sure the model
      • xbox 360's controller
      • Snow Silent Seasonic 750w
      • Windows 7 64 bit
      • Mazeda BD
      • 38096
      • 9096
    Ehsas's Avatar
    Jul 2015
    Default PC sound problems HELP D:
    So i bought a new headset, tried it on my phone, laptop, sibling's pc's on all 4 of them it worked perfectly but not on my one. I could hear but at a VERY low volume. now i thought the setero and microphone jack at my pc was busted so i got a usb sound adapter and at the store i checked it out at their pc and my headset worked in that USB sound adapter as well but when i plug it into my pc it dosen't work D:
    Really at a mess here so any help is greatly appreciated. thanks
    • codename5302's Gadgets
      • Gigabyte X99-UD5 Wifi
      • Zotac 980Ti Amp Extreme
      • Fiio Andes E07K
      • Corsair RM850
      • 2 * Prollink 1200VA
      • Windows 7 64Bit
      • It works!!
      • 154
    codename5302's Avatar
    is this the problem with xonar? have you tried to uninstall and reinstall drivers? try to put your 3.5mm jack on rear channel or center/ sub woofer port. if you get sound from those then, your front channel port may be busted. there are 3rd party drivers, try those as well. also make sure your configure your card properly from the control panel (i know i sound foolish, still )
    • Ehsas's Gadgets
      • MSI Z97-G45
      • LG 34UM95
      • Asus Xonar
      • Windows 7 64 bit
      • Mazeda BD
      • 38096
      • 9096
    Ehsas's Avatar
    Jul 2015
    Don't think it's a sound card problem and yep did all that. i tried doing them on the rear channel but heard literally no sound, if i use that USB sound adapter then no sound either, if i put it at the front channel port then i hear sound on one ear and sometimes both but very faint. im sure the new headphones work btw since it works in preety much everyone's pc other than mine. So what do you think might be the problem?
    • Ahnaf_i7X's Gadgets
      • Gigabyte GA-Z77-D3H
      • Intel Core i7-3770K cooled by TT Frio Extreme
      • Corsair XMS 3 (4GBx4=16GB)
      • Western Digital Caviar Blue 1TB
      • Sapphire RX 580 Nitro+ OC Edition 8GB
      • Viewsonic 27 Inch 1080p (1920x1080)
      • Realtek Integrated Sound
      • A4Tech Headphones
      • A4Tech ComfortKey
      • Thermaltake eSports Talon Blu Gaming Mouse
      • PlayStation 4 DualShock 4 Gamepad
      • Gigabyte Pulse 650W 80+ Bronze
      • Samsung 22x DVD Writer
      • PS4 DualShock 4 Controller
      • I love my PC and my PC electrocutes me.
      • UCN
      • 88 MBps
      • 98 MBps
      • 127
    Ahnaf_i7X's Avatar
    Sep 2012
    Watching your back.
    Quote Originally Posted by Ehsas View Post
    sounds like a problem with the motherboard, do u have any warranty left? if so, get it RMAed
    Loved by few,
    Hated by many
    But respected by all!!
    • Muhammad Zunaid's Gadgets
      • ASRock H55M-LE
      • G Skill Ripjaws [4GBx2]=8GB
      • Samsung SyncMaster T220
      • Inbuilt Realtek Codec
      • Altec Lansing VS4121
      • Tt esports KNUCKER
      • Genius standard mouse
      • Canon Lide110 Scanner
      • RA 1000VA + Powertree 650VA
      • want to upgrade soon!
      • LINK3
    Muhammad Zunaid's Avatar
    is the new headset your only headset? do you have any other earphones or headsets? did you try those on your pc... and what about your speakers. do they work ok with ur pc.
    • Ehsas's Gadgets
      • MSI Z97-G45
      • LG 34UM95
      • Asus Xonar
      • Windows 7 64 bit
      • Mazeda BD
      • 38096
      • 9096
    Ehsas's Avatar
    Jul 2015
    Quote Originally Posted by zunaid View Post
    Just tried with my music headset...didn't work. and yes speakers work fine. just headsets don't.
    Quote Originally Posted by Ahnaf_i7X View Post
    are you sure? and yes i have warranty left so should i send it back?
      • A4Tech Headphones
      • A4Tech ComfortKey
      • UCN
      • 88 MBps
      • 98 MBps
      • 127
    Ahnaf_i7X's Avatar
    Sep 2012
    Watching your back.
    so, speakers work fine but headsets dont? tinker with the audio settings in windows maybe u might find a fix
    Loved by few,
    Hated by many
    • Ehsas's Gadgets
      • MSI Z97-G45
      • LG 34UM95
      • Asus Xonar
      • Windows 7 64 bit
      • Mazeda BD
      • 38096
      • 9096
    Ehsas's Avatar
    Jul 2015
    Yes D; speakers work fine but headsets don't at all. What audio settings could it be? i mean on all my sibling's pc's i just plugged it in and it worked right away(my headset) i set the default device and also communication&playback device to the headsets but it still dosen't work! yet in my laptop or anyone else's pc it works perfectly fine.
    my suggestion is to perform a clean installation of windows and install the drivers from beginning, i think this might work as your problems seems to be connected with lack of combination between hardware and drivers. you might try this. I don't know if ur motherboard is under defects, speaker can amplify sounds as well as headset should do so. so i can't say there is something creepy with your motherboard unless you perform a clean windows installation. try this and tell us if it works for you.
    You tried setting up multiple sound devices, so, be sure that one works only at a time.
      • ASRock H55M-LE
      • LINK3
    Is your speaker a 2:1 or some other variant. Did you try to completely disconnect all connection of your speaker, restart your computer (with all speaker audio connections disconnected) and after restarting PC, just connect ur headphone/headset and check. And are you using sound card or internal motherboard sound codec like realtek or sth...
    • Sybaris Caesar's Gadgets
      • Intel DH61WW B3 Rev.
      • Intel Core i5 2400 3.10 Ghz
      • Thermaltake Commander
      • Logitech G402
      • Original Xbox 360 Wireless
      • Cooler Master G550M
    Sybaris Caesar's Avatar
    Nowy Warsaw
    1. Right-click the speaker beside notifications.
    2. Choose "Playback Devices"
    3. Check if you've selected the correct device. If you've installed Realtek drivers, there should be three devices. Realtek Audio Device, Speaker/Headphone, Digital Output.
    3. Open an audio file via any media player.
    4. Set any of the three devices as default and see if you hear the audio.
    5. If the headphone works then you can stop here.
    6. If it doesn't but you hear faint noise, right-click on properties.
    7. In 2nd tab, tick disable all enhancements.
    8. In 3rd tab, untick program exclusivity option.
    9. Apply and OK.
    10. If still doesn't work, most likely a driver or hardware problem.
    My probable next build: Qisan MagicForce 68 (Outemu switch) / Teamwolf Zhuque+ 87 TKL (Outemu) / Monoprice Select series full size (Outemu/Gateron) / Drevo Gramr 84 TKL (Outemu) • Logitech G102 Prodigy • Deepcool Dukase V3 / Thermaltake Versa U21 • Superlux HD 681 • Creative Sound Blaster E1 • LG 22MP68VQ • SteelSeries QcK • Generic executive chair • others TBA
    djrock please don't bother me. You are in my ignore list so I don't have to see literal poop.
    • Ehsas's Gadgets
      • MSI Z97-G45
      • LG 34UM95
      • Asus Xonar
      • Windows 7 64 bit
      • Mazeda BD
      • 38096
      • 9096
    Ehsas's Avatar
    Jul 2015
    Quote Originally Posted by Sybaris Caesar View Post
    9. Apply and OK.
    Tried all of it. btw in the headphone properties it says it'll only work on the front audio jacks, and if i put it in the front one i hear sound but at a VERY low volume. if i use the rear port then no sound at all. and all drivers are updated btw. @zunaid tried that as well and no im not. Do you think it's because of the OS? didn't have much problems before.
      • Logitech G402
    Nowy Warsaw
    You upgraded to Windows 10?
    • Ehsas's Gadgets
      • MSI Z97-G45
      • LG 34UM95
      • Asus Xonar
      • Windows 7 64 bit
      • Mazeda BD
      • 38096
      • 9096
    Ehsas's Avatar
    Jul 2015
    no, i used Linux before.
  1. Sale (Used) Creative Sound Blaster X-Fi Titanium PCI Express Sound Card
    By areek in forum Shop - Gadgets
    Last Post: August 23rd, 2013, 23:34
  2. Xbox 360 Controller sound problems (PC)
    By alex4646 in forum Technical Support
    Last Post: July 20th, 2013, 18:21
  3. Sale (Used) Creative Sound Blaster X-Fi Titanium PCI Express Sound Card
    Last Post: December 30th, 2012, 17:27
  4. XBOX 360 Controller and Sound Problems
    By TheNutKicker in forum Technical Support
    Last Post: July 30th, 2012, 14:58
  5. Sale (Used) Creative Sound Blaster AUDIGY Value 7:1 Sound Card
    By Reventon in forum Shop - Gadgets
    Last Post: February 10th, 2011, 17:22
Page generated in 0.24875 seconds with 14 queries.
